    WebDialog parameters passed to callback cause .to_l error
    29 Posts 7 Posters 3.1k Views 7 Watching
      Jim
      A begin..rescue clause can be used to test this. For a one-off:
      len = begin
        "1,2".to_l
      rescue
        "1.2".to_l
      p len
      But obviously it would be better to write a method to handle this for more cases.
      • jolranJ
        jolran
        heh 😄 yeah that works to.
        Don't know if it's prettier than a gsub, but if it works..
        Does the code pass through transparently if no errors, or does this add overhead?
        It might be interesting to do a speed comparing against gsub variant.
        Yeah, but sometimes one run into corners where direct evaluation is necissary.
        Like get_element_value at some odd place where not possible to go through normal routine.
        • jiminy-billy-bobJ
          jiminy-billy-bob
          I use this :
          <span class="syntaxdefault"><br />def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">decimal_separator<br />        </span><span class="syntaxstring">'1.0'</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br />        return </span><span class="syntaxstring">'.'<br /></span><span class="syntaxdefault">    rescue ArgumentError<br />        return </span><span class="syntaxstring">','<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#def<br /><br /></span><span class="syntaxdefault">def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(/\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">+/,</span><span class="syntaxstring">''</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(/(\.|,)/,</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">decimal_separator</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_l<br />end</span><span class="syntaxcomment">#def<br />&nbsp;</span><span class="syntaxdefault"></span>
          This allows me to handle pretty much anything the users enters.
            driven
            isn't it faster to test for true
            def self.decimal_separator
                [1.1].length ==  2  ?  ',' | '.'
            end#def
            • jolranJ
              jolran
              Guys 👍
              This place is a great source of information.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Maybe 😄 It's widely fast enough for my use (Parsing one string at a time entered by the user)
                • tt_suT
                  tt_su
                  > end#def
                  You never know for sure until you profile the code. And in Ruby you get many surprises. That being said - unless you have a noticeable performance issue there is little need to pre-optimize.
                    Jim
                    > end#def
                    Maybe I do not know off-hand. This is code you would run at most one time in a plugin to determine which separator to use so it isn't terribly important to optimize.
                    The code that actually performs the conversion may need optimized especially if there are many conversions to do.
                      Jim
                      Had this idea today:
                      separator = (1/Float(2)).to_s[1]
                        driven
                        even shorter
                        separator = Float(1).to_s[1]
                          But that Ruby float as a string is ALWAYS going to return "1.0", so it always sets as "." even when the user's day-to-day decimal-separator is ","
                          The issue is how the user input of "1,0" is correctly read as a float or a length.
                          In the UI 'input' the default input type pretty much sorts that out.
                          Since 1.0.m displays as 1.000m or 1,000m depending on the user's locale [and of course the model's unit settings]
                          In a webdialog it's more awkward, because all input is a string that needs 'interpreting'.
                          So the earlier posts' trickery using lengths etc to get the real separator would help...
                          Certainly when initially populating the webdialog with decimal values...
                          Like sep = (begin;'1.0'.to_l;'.';rescue;',';end)
                          So if sep==',' we present decimal numbers differently using something like tr('.',',')?
                          But surely some leeway could be used...
                          What if a user first inputs x = 1.0 then x = 2,3 ?
                          Should BOTH be acceptable ?
                          So assuming they are expected as floats...
                          if sep=='.' x.tr!(',','.') else #',' x.tr!('.',',') end
                          For the display-side this makes either typed in separator suit the the 'locale', but on the Ruby-side, it's always x_float = x.tr(',','.').to_f
                          For inputted 'lengths' it is different, because the Ruby-side expects it to be in the locale separator format...
                          The first sep==...tr... still applies to ensure it's locale friendly... BUT then the x_length = x.to_l must be used Ruby-side...
                          • 2 / 2
