    WebDialog parameters passed to callback cause .to_l error
    29 Posts 7 Posters 1.8k Views 7 Watching
    • jolranJ Offline
      jolran
      Yes John. Still on 8. I havent had time to test the new good stuff..
      Btw .to_s.gsub(".", ",").to_l worked for me in the node editor. But I can't remember if I did an eval on a hash_String before running that..
      I havent touched the JS for a while...
      Now seeing this I wonder if I got it all wrong, it seemed to work properly 😕
      edit: puts "1.0".to_l don't work(for me) on 2014 either. But it never has so I'm suprised you made it work. Maybe because your on Mac ?
      Oh yeah and even how ugly it may look this works: eval("+1.0").to_s.gsub(".", ",").to_l
      Then again I believe TS is not interested in hacks..
        Jim
        Really? Does "1,0".to_l work?
        • jolranJ Offline
          jolran
          Yes.
            Jim
            A begin..rescue clause can be used to test this. For a one-off:
            len = begin
              "1,2".to_l
            rescue
              "1.2".to_l
            p len
            But obviously it would be better to write a method to handle this for more cases.
            • jolranJ Offline
              jolran
              heh 😄 yeah that works to.
              Don't know if it's prettier than a gsub, but if it works..
              Does the code pass through transparently if no errors, or does this add overhead?
              It might be interesting to do a speed comparing against gsub variant.
              Yeah, but sometimes one run into corners where direct evaluation is necissary.
              Like get_element_value at some odd place where not possible to go through normal routine.
              • jiminy-billy-bobJ Offline
                jiminy-billy-bob
                I use this :
                <span class="syntaxdefault"><br />def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">decimal_separator<br />        </span><span class="syntaxstring">'1.0'</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br />        return </span><span class="syntaxstring">'.'<br /></span><span class="syntaxdefault">    rescue ArgumentError<br />        return </span><span class="syntaxstring">','<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#def<br /><br /></span><span class="syntaxdefault">def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(/\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">+/,</span><span class="syntaxstring">''</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(/(\.|,)/,</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">decimal_separator</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_l<br />end</span><span class="syntaxcomment">#def<br />&nbsp;</span><span class="syntaxdefault"></span>
                This allows me to handle pretty much anything the users enters.
                  driven
                  isn't it faster to test for true
                  def self.decimal_separator
                      [1.1].length ==  2  ?  ',' | '.'
                  end#def
                  • jolranJ Offline
                    jolran
                    Guys 👍
                    This place is a great source of information.
                      jiminy-billy-bob
                      Maybe 😄 It's widely fast enough for my use (Parsing one string at a time entered by the user)
                      • tt_suT Offline
                        tt_su
                        > end#def
                        You never know for sure until you profile the code. And in Ruby you get many surprises. That being said - unless you have a noticeable performance issue there is little need to pre-optimize.
                          Jim
                          > end#def
                          Maybe I do not know off-hand. This is code you would run at most one time in a plugin to determine which separator to use so it isn't terribly important to optimize.
                          The code that actually performs the conversion may need optimized especially if there are many conversions to do.
                            Jim
                            Had this idea today:
                            separator = (1/Float(2)).to_s[1]
                              driven
                              even shorter
                              separator = Float(1).to_s[1]
                                But that Ruby float as a string is ALWAYS going to return "1.0", so it always sets as "." even when the user's day-to-day decimal-separator is ","
                                The issue is how the user input of "1,0" is correctly read as a float or a length.
                                In the UI 'input' the default input type pretty much sorts that out.
                                Since 1.0.m displays as 1.000m or 1,000m depending on the user's locale [and of course the model's unit settings]
                                In a webdialog it's more awkward, because all input is a string that needs 'interpreting'.
                                So the earlier posts' trickery using lengths etc to get the real separator would help...
                                Certainly when initially populating the webdialog with decimal values...
                                Like sep = (begin;'1.0'.to_l;'.';rescue;',';end)
                                So if sep==',' we present decimal numbers differently using something like tr('.',',')?
                                But surely some leeway could be used...
                                What if a user first inputs x = 1.0 then x = 2,3 ?
                                Should BOTH be acceptable ?
                                So assuming they are expected as floats...
                                if sep=='.' x.tr!(',','.') else #',' x.tr!('.',',') end
                                For the display-side this makes either typed in separator suit the the 'locale', but on the Ruby-side, it's always x_float = x.tr(',','.').to_f
                                For inputted 'lengths' it is different, because the Ruby-side expects it to be in the locale separator format...
                                The first sep==...tr... still applies to ensure it's locale friendly... BUT then the x_length = x.to_l must be used Ruby-side...
                                • 2 / 2
