Vray for Sketchup Pro 2015 OSX 64 bit
Hi Guys:
I look in the Download area for users in Chaosgroup and as many of you I try to download the version 64 bit for Sketchup Pro 2015, well I can't find the link. I email chaos and I am still waiting for a razonable response about that. Does anybody have the same issue in the folder of 64bit is only the Windows version, either if the version is misplaced in the 32 bit It should be corrected and put back to the right place. Any Ideas?
Thanks.
Gonzalo.
Sketchup 2015 is 64bits only on OSX, so I guess the same goes for Vray.
It is listed in the wrong area, we are moving it to the 64bit section. It is a 64bit version, as jiminy-billy-bob mentioned, SU 2015 is 64bit only on OSX only.
I have the same question so now: is the one listed as the win 64bit version actually the osx version? Because its the only one listed in this area? Or has it not been moved yet?
Edit: OK i see the .exe so definitely not the osx file
Well... I guess we just have to wait for the file to be moved to the proper place. -
it's in the wrong spot, but it's fine. For SU 2015 on OSX, you want the build that says:
"Nov 14, 2014 2.00.25244 sketchup_2015_osx 32bit "
even though it's actually 64bit. There was confusion over the changes between the latest service release for SU 2013, 2014, and 2015 on OSX. They all only have one platform that they support, but the 2015 version is 64bit only, whereas the other builds are 32bit only. On the windows side, there is a 32bit and 64bit version for 2015.
We will move it soon, but in the meantime, there's nothing wrong with the build, other than where it's being listed on the website.
