    Video Texture
    64 Posts 11 Posters 49.6k Views 11 Watching
      Ah ok the automatic replay was on the other Window! ๐Ÿ˜ณ
        Marc Schnyder
        No need to be "embarrassed", we have User Manuals not yet available, that excuses anything from your side ๐Ÿ˜„
          Ah damned! I am very unlucky with your plugin! ๐Ÿ˜ฎ
          Total general crash with a little smiley animated of the forum
          Result = Analyse + repairs of the Hard disc + cold nervous shivers! ๐Ÿ˜•
          I have losted an half hour! ๐Ÿ˜ข
          I believe that your plugin is not enough saftety for my case! ๐Ÿ˜’
          I am desolated of this! ๐Ÿ˜ข
            Marc Schnyder
            Hello Pilou
            Let me start like that: Sorry that your system crashed, but:
            The Plugin as well as ffmpeg does nothing that would go so "deeply" into your system that it could crash your whole system.
            Some theoretical theories:
            • If you have unstable graphics drivers , it may crash your system... And maybe playing videos on textures "stresses" the system a bit more than showing static images.
            • If your System crashes , you should check the overall system stability, as no application at all is supposed to be able to crash the whole system like that.
            During development while programming around in the Plugins code , i had Sketchup hang and Sketchup crash , but only the application , not the whole System that you need to reboot and do a disk check.
            I would still believe if someone says it hangs or crashes his sketchup (and in that case just uninstall the plugin) , but i totally dont see how this should crash your system.
            Unless by stressing it more , but a stable system can deal with some stress.
            With reasonable Graphics Acceleration and not too complex 3d-Modells, the application shouldnt be stressy at all for a system at all btw...
            Your system does 30 min disk checks? Not sure when ive seen that last since Windows 98. What Windows System do you have? I like to mention that shortly i saw a Windows 8 Terminate itself , while all other systems felt fine... Without my plugin or sketchup anywhere ๐Ÿ˜„
              schnydix
              A lot people download , install and start the plugin
              No Feedback we need it Please.
                schnydix
                Hello all i downloadet the crash Gif s without the Pilou effect
                Running easy on my system.
                esense 3d
                • KrisidiousK
                  Krisidious
                  I'm running gifs on 2015-64 fine.
                  By: Kristoff Rand
                  • olisheaO
                    olishea
                    I need a mac version so bad!! I can't test unfortunately. There is so much you could do with this plugin! I wish SU would natively render animated gifs as textures. ๐Ÿ˜ž
                    oli
                      Windows 8, new computer!
                      It's the first time that it's completly blocks!
                      I have hundred of differents progs with no problem! ๐Ÿ˜„ Fortunatly! ๐Ÿ˜„
                      It's the bad luck!...and the mystery of the new technologies! ๐Ÿ˜‰
                        schnydix
                        Short How to
                        Russian and Chinese
                          schnydix
                          Some People like to have a first step video
                          Here is one
                          esense 3d
                          • G
                            goga63
                            in Russian it would be so :
                              schnydix
                              Sketchup Video Texture Export with Scenes
                              uses the native Sketchup exporter and animatet gif
                              Its the ani gif made with png pictures - transparency is supportet to
                              I tinkeret around with the anigif for this video i slowed down to 2 Frames per second
                              Without slow down the anigif is freaking out
                              esense 3d
                                driven
                                can see them now... cheers
                                  schnydix
                                  Hello
                                  Testing the new scene render Export
                                  Sketchup Video Texture Plugin
                                  NEW
                                  Scene Animation Real Time and
                                  Scene Animation Export
                                    schnydix
                                    Sketchup Video Texture Plugin + Model Animation export with the Video Plugin
                                    The Walk is made with Scenes
                                    Any Scene is 0,05 Sec long
                                    model by Scifilcious
                                    esense 3d
                                    Video Window
                                    Preferences Window
                                    Render Export Window
                                      schnydix
                                      Hello Version 1.0.329 out now
                                      including real time scene animation support and
                                      scene export with video textures (any Resolution
                                      Works with Dynamic Components to
                                      Download http://www.marcschnyder.ch/vtp/download.php
                                      esense3d
                                      • KrisidiousK
                                        Krisidious
                                        Very kool esense 3d... that's a great use of the plugin. great that you're making full export support too.
                                        By: Kristoff Rand
                                        • olisheaO
                                          olishea
                                          I agree
                                          oli
                                          • KrisidiousK
                                            Krisidious
                                            I guess it would be unreasonable to ask for a system that allowed me to choose several materials from my sketchup model or material browser that would be made into a small movie file to be used in conjunction?
                                            because this could be done with each of the materials on a house. If you could perhaps choose the duration of each material and the length of transition.
                                            By: Kristoff Rand
                                            • 3 / 4
