    Video Texture
    64 Posts 11 Posters 49.6k Views 11 Watching
      Ah damned! I am very unlucky with your plugin! ๐Ÿ˜ฎ
      Total general crash with a little smiley animated of the forum
      Result = Analyse + repairs of the Hard disc + cold nervous shivers! ๐Ÿ˜•
      I have losted an half hour! ๐Ÿ˜ข
      I believe that your plugin is not enough saftety for my case! ๐Ÿ˜’
      I am desolated of this! ๐Ÿ˜ข
        Marc Schnyder
        Hello Pilou
        Let me start like that: Sorry that your system crashed, but:
        The Plugin as well as ffmpeg does nothing that would go so "deeply" into your system that it could crash your whole system.
        Some theoretical theories:
        • If you have unstable graphics drivers , it may crash your system... And maybe playing videos on textures "stresses" the system a bit more than showing static images.
        • If your System crashes , you should check the overall system stability, as no application at all is supposed to be able to crash the whole system like that.
        During development while programming around in the Plugins code , i had Sketchup hang and Sketchup crash , but only the application , not the whole System that you need to reboot and do a disk check.
        I would still believe if someone says it hangs or crashes his sketchup (and in that case just uninstall the plugin) , but i totally dont see how this should crash your system.
        Unless by stressing it more , but a stable system can deal with some stress.
        With reasonable Graphics Acceleration and not too complex 3d-Modells, the application shouldnt be stressy at all for a system at all btw...
        Your system does 30 min disk checks? Not sure when ive seen that last since Windows 98. What Windows System do you have? I like to mention that shortly i saw a Windows 8 Terminate itself , while all other systems felt fine... Without my plugin or sketchup anywhere ๐Ÿ˜„
          schnydix
          A lot people download , install and start the plugin
          No Feedback we need it Please.
            schnydix
            Hello all i downloadet the crash Gif s without the Pilou effect
            Running easy on my system.
            esense 3d
            • KrisidiousK
              Krisidious
              I'm running gifs on 2015-64 fine.
              By: Kristoff Rand
              • olisheaO
                olishea
                I need a mac version so bad!! I can't test unfortunately. There is so much you could do with this plugin! I wish SU would natively render animated gifs as textures. ๐Ÿ˜ž
                oli
                  Windows 8, new computer!
                  It's the first time that it's completly blocks!
                  I have hundred of differents progs with no problem! ๐Ÿ˜„ Fortunatly! ๐Ÿ˜„
                  It's the bad luck!...and the mystery of the new technologies! ๐Ÿ˜‰
                    schnydix
                    Short How to
                    Russian and Chinese
                      schnydix
                      Some People like to have a first step video
                      Here is one
                      esense 3d
                      • G
                        goga63
                        in Russian it would be so :
                          schnydix
                          Sketchup Video Texture Export with Scenes
                          uses the native Sketchup exporter and animatet gif
                          Its the ani gif made with png pictures - transparency is supportet to
                          I tinkeret around with the anigif for this video i slowed down to 2 Frames per second
                          Without slow down the anigif is freaking out
                          esense 3d
                            driven
                            can see them now... cheers
                              schnydix
                              Hello
                              Testing the new scene render Export
                              Sketchup Video Texture Plugin
                              NEW
                              Scene Animation Real Time and
                              Scene Animation Export
                                schnydix
                                Sketchup Video Texture Plugin + Model Animation export with the Video Plugin
                                The Walk is made with Scenes
                                Any Scene is 0,05 Sec long
                                model by Scifilcious
                                esense 3d
                                Video Window
                                Preferences Window
                                Render Export Window
                                  schnydix
                                  Hello Version 1.0.329 out now
                                  including real time scene animation support and
                                  scene export with video textures (any Resolution
                                  Works with Dynamic Components to
                                  Download http://www.marcschnyder.ch/vtp/download.php
                                  esense3d
                                  • KrisidiousK
                                    Krisidious
                                    Very kool esense 3d... that's a great use of the plugin. great that you're making full export support too.
                                    By: Kristoff Rand
                                    • olisheaO
                                      olishea
                                      I agree
                                      oli
                                      • KrisidiousK
                                        Krisidious
                                        I guess it would be unreasonable to ask for a system that allowed me to choose several materials from my sketchup model or material browser that would be made into a small movie file to be used in conjunction?
                                        because this could be done with each of the materials on a house. If you could perhaps choose the duration of each material and the length of transition.
                                        By: Kristoff Rand
                                        • olisheaO
                                          olishea
                                          you can just do that by making a slideshow animation of SU exports.....but obviously wouldn't be able to rotate or orbit etc.
                                          oli
                                          • KrisidiousK
                                            Krisidious
                                            I know it can be done outside of the SU system... and I know how. I'm suggesting putting it in this plugin. automating the process and making it a tool of the plugin.
                                            By: Kristoff Rand
                                            • 3 / 4
