    Video Texture
    64 Posts 11 Posters 48.5k Views 11 Watching
    • KrisidiousK
      Krisidious
      it's uploading... be a few minutes.
      By: Kristoff Rand
      • KrisidiousK
        Krisidious
        Here's my first test. Stuttering is my screen capture software. it sucks.
        By: Kristoff Rand
          Yep i will try in V8 because in V6 it don't find the main.rbs
          who is well existing! ๐Ÿ˜„
          Edit : Sorry no more chance in the v8 !
          Maybe in the 2014 ๐Ÿ˜„
            Seems works in 2014 ๐Ÿ˜„
            But some crashes of the window Loading Video! ๐Ÿ˜ฎ
            With a simple Gif animated! ๐Ÿ˜„
            Is that the same for you ? โ“
            Works after closing the numerous crash windows! ๐Ÿ˜„
            The crashes windows are with this simple gif animated! ๐Ÿ˜‰
              schnydix
              Hi Pilou
              I just tested it on
              WinXp Sketchup 8
              Win7 Sketchup 2013
              Win7(64) Sketchup 2014
              Win7(64) Sketchup 2015 (64bit)
              ... and it works everywhere for me (with the gif file you provided)
              I have however to admit that with such 1-second anigifs, there are a bit large breaks between the repetions. Maybe we can improve for such situations one day. But it works.
              To make it loop/repeat you must enable the loop button (rightmost button of the 7 buttons per video) which looks kind of like a recycling button ๐Ÿ˜„ If its light green its on and it will loop , if its off (dark blue) it will play only once.
              Hmmm maybe we can never guarantee that ffmpeg will be happy on every cpu, with every video file in every format it supports. I guess there are too many combinations. (But note that ffmpeg has the problem, which is a 3rd Party application , and not invented/developed by us, only packaged)
              Maybe Converting the file to a different format would help for you.
                schnydix
                Hello Pilou
                I Think the plugin dont like bananas as well is a children please try some other Fruits.
                Banana work fine for me in SU 2014 and 2015 wihout crash but work not in SU 8.
                First Proplem/Bug Ani Gifs run not all (The Fruit make no difference) in SU 8 and SU 2013
                ๐Ÿ˜„
                esense 3d
                  Ah ok the automatic replay was on the other Window! ๐Ÿ˜ณ
                    Marc Schnyder
                    No need to be "embarrassed", we have User Manuals not yet available, that excuses anything from your side ๐Ÿ˜„
                      Ah damned! I am very unlucky with your plugin! ๐Ÿ˜ฎ
                      Total general crash with a little smiley animated of the forum
                      Result = Analyse + repairs of the Hard disc + cold nervous shivers! ๐Ÿ˜•
                      I have losted an half hour! ๐Ÿ˜ข
                      I believe that your plugin is not enough saftety for my case! ๐Ÿ˜’
                      I am desolated of this! ๐Ÿ˜ข
                        Marc Schnyder
                        Hello Pilou
                        Let me start like that: Sorry that your system crashed, but:
                        The Plugin as well as ffmpeg does nothing that would go so "deeply" into your system that it could crash your whole system.
                        Some theoretical theories:
                        • If you have unstable graphics drivers , it may crash your system... And maybe playing videos on textures "stresses" the system a bit more than showing static images.
                        • If your System crashes , you should check the overall system stability, as no application at all is supposed to be able to crash the whole system like that.
                        During development while programming around in the Plugins code , i had Sketchup hang and Sketchup crash , but only the application , not the whole System that you need to reboot and do a disk check.
                        I would still believe if someone says it hangs or crashes his sketchup (and in that case just uninstall the plugin) , but i totally dont see how this should crash your system.
                        Unless by stressing it more , but a stable system can deal with some stress.
                        With reasonable Graphics Acceleration and not too complex 3d-Modells, the application shouldnt be stressy at all for a system at all btw...
                        Your system does 30 min disk checks? Not sure when ive seen that last since Windows 98. What Windows System do you have? I like to mention that shortly i saw a Windows 8 Terminate itself , while all other systems felt fine... Without my plugin or sketchup anywhere ๐Ÿ˜„
                          schnydix
                          A lot people download , install and start the plugin
                          No Feedback we need it Please.
                            schnydix
                            Hello all i downloadet the crash Gif s without the Pilou effect
                            Running easy on my system.
                            esense 3d
                            • KrisidiousK
                              Krisidious
                              I'm running gifs on 2015-64 fine.
                              By: Kristoff Rand
                              • olisheaO
                                olishea
                                I need a mac version so bad!! I can't test unfortunately. There is so much you could do with this plugin! I wish SU would natively render animated gifs as textures. ๐Ÿ˜ž
                                oli
                                  Windows 8, new computer!
                                  It's the first time that it's completly blocks!
                                  I have hundred of differents progs with no problem! ๐Ÿ˜„ Fortunatly! ๐Ÿ˜„
                                  It's the bad luck!...and the mystery of the new technologies! ๐Ÿ˜‰
                                    schnydix
                                    Short How to
                                    Russian and Chinese
                                      schnydix
                                      Some People like to have a first step video
                                      Here is one
                                      esense 3d
                                      • G
                                        goga63
                                        in Russian it would be so :
                                          schnydix
                                          Sketchup Video Texture Export with Scenes
                                          uses the native Sketchup exporter and animatet gif
                                          Its the ani gif made with png pictures - transparency is supportet to
                                          I tinkeret around with the anigif for this video i slowed down to 2 Frames per second
                                          Without slow down the anigif is freaking out
                                          esense 3d
                                            driven
                                            can see them now... cheers
                                            • 2 / 4
