    Video Texture
    64 Posts 11 Posters 49.6k Views 11 Watching
      schnydix
      Hi Pilou
      I just tested it on
      WinXp Sketchup 8
      Win7 Sketchup 2013
      Win7(64) Sketchup 2014
      Win7(64) Sketchup 2015 (64bit)
      ... and it works everywhere for me (with the gif file you provided)
      I have however to admit that with such 1-second anigifs, there are a bit large breaks between the repetions. Maybe we can improve for such situations one day. But it works.
      To make it loop/repeat you must enable the loop button (rightmost button of the 7 buttons per video) which looks kind of like a recycling button ๐Ÿ˜„ If its light green its on and it will loop , if its off (dark blue) it will play only once.
      Hmmm maybe we can never guarantee that ffmpeg will be happy on every cpu, with every video file in every format it supports. I guess there are too many combinations. (But note that ffmpeg has the problem, which is a 3rd Party application , and not invented/developed by us, only packaged)
      Maybe Converting the file to a different format would help for you.
        schnydix
        Hello Pilou
        I Think the plugin dont like bananas as well is a children please try some other Fruits.
        Banana work fine for me in SU 2014 and 2015 wihout crash but work not in SU 8.
        First Proplem/Bug Ani Gifs run not all (The Fruit make no difference) in SU 8 and SU 2013
        ๐Ÿ˜„
        esense 3d
          Ah ok the automatic replay was on the other Window! ๐Ÿ˜ณ
            Marc Schnyder
            No need to be "embarrassed", we have User Manuals not yet available, that excuses anything from your side ๐Ÿ˜„
              Ah damned! I am very unlucky with your plugin! ๐Ÿ˜ฎ
              Total general crash with a little smiley animated of the forum
              Result = Analyse + repairs of the Hard disc + cold nervous shivers! ๐Ÿ˜•
              I have losted an half hour! ๐Ÿ˜ข
              I believe that your plugin is not enough saftety for my case! ๐Ÿ˜’
              I am desolated of this! ๐Ÿ˜ข
                Marc Schnyder
                Hello Pilou
                Let me start like that: Sorry that your system crashed, but:
                The Plugin as well as ffmpeg does nothing that would go so "deeply" into your system that it could crash your whole system.
                Some theoretical theories:
                • If you have unstable graphics drivers , it may crash your system... And maybe playing videos on textures "stresses" the system a bit more than showing static images.
                • If your System crashes , you should check the overall system stability, as no application at all is supposed to be able to crash the whole system like that.
                During development while programming around in the Plugins code , i had Sketchup hang and Sketchup crash , but only the application , not the whole System that you need to reboot and do a disk check.
                I would still believe if someone says it hangs or crashes his sketchup (and in that case just uninstall the plugin) , but i totally dont see how this should crash your system.
                Unless by stressing it more , but a stable system can deal with some stress.
                With reasonable Graphics Acceleration and not too complex 3d-Modells, the application shouldnt be stressy at all for a system at all btw...
                Your system does 30 min disk checks? Not sure when ive seen that last since Windows 98. What Windows System do you have? I like to mention that shortly i saw a Windows 8 Terminate itself , while all other systems felt fine... Without my plugin or sketchup anywhere ๐Ÿ˜„
                  schnydix
                  A lot people download , install and start the plugin
                  No Feedback we need it Please.
                    schnydix
                    Hello all i downloadet the crash Gif s without the Pilou effect
                    Running easy on my system.
                    esense 3d
                    • KrisidiousK
                      Krisidious
                      I'm running gifs on 2015-64 fine.
                      By: Kristoff Rand
                      • olisheaO
                        olishea
                        I need a mac version so bad!! I can't test unfortunately. There is so much you could do with this plugin! I wish SU would natively render animated gifs as textures. ๐Ÿ˜ž
                        oli
                          Windows 8, new computer!
                          It's the first time that it's completly blocks!
                          I have hundred of differents progs with no problem! ๐Ÿ˜„ Fortunatly! ๐Ÿ˜„
                          It's the bad luck!...and the mystery of the new technologies! ๐Ÿ˜‰
                            schnydix
                            Short How to
                            Russian and Chinese
                              schnydix
                              Some People like to have a first step video
                              Here is one
                              esense 3d
                              • G
                                goga63
                                in Russian it would be so :
                                  schnydix
                                  Sketchup Video Texture Export with Scenes
                                  uses the native Sketchup exporter and animatet gif
                                  Its the ani gif made with png pictures - transparency is supportet to
                                  I tinkeret around with the anigif for this video i slowed down to 2 Frames per second
                                  Without slow down the anigif is freaking out
                                  esense 3d
                                    driven
                                    can see them now... cheers
                                      schnydix
                                      Hello
                                      Testing the new scene render Export
                                      Sketchup Video Texture Plugin
                                      NEW
                                      Scene Animation Real Time and
                                      Scene Animation Export
                                        schnydix
                                        Sketchup Video Texture Plugin + Model Animation export with the Video Plugin
                                        The Walk is made with Scenes
                                        Any Scene is 0,05 Sec long
                                        model by Scifilcious
                                        esense 3d
                                        Video Window
                                        Preferences Window
                                        Render Export Window
                                          schnydix
                                          Hello Version 1.0.329 out now
                                          including real time scene animation support and
                                          scene export with video textures (any Resolution
                                          Works with Dynamic Components to
                                          Download http://www.marcschnyder.ch/vtp/download.php
                                          esense3d
                                          • KrisidiousK
                                            Krisidious
                                            Very kool esense 3d... that's a great use of the plugin. great that you're making full export support too.
                                            By: Kristoff Rand
                                            • 2 / 4
