    Is it possible to ...
    4 Posts 3 Posters 442 Views 3 Watching
    • I
      IAho
      Is it possible to stamp a piece just click on it to simple text. see the picture
      Thanks for your help
      design
      part of the dxf file
      • sketch3d.deS
        sketch3d.de
        ... use descriptive subjects?
          Not without a plugin, or a convoluted workflow...
          If the component has a logical name then you can copy that onto the clipboard from its Entity Info.
          Then edit the instance if you want the text inside the component.
          Place some 3dText and paste the text string in the dialog.
          Set it to be flat, no-extrusion, give it a color etc
          OR you could use a piece of 2dText [from my 2dTools] to place some similar 'flat' text onto a surface.
          The advantage of that method is the 2dText string is editable later, via the context-menu...
          • I
            IAho
            Thanks for your answers
            Is there a simple one-line text style ..?
            TIG 2dTex tool, or other tools ...
