SketchUp 2015 Wishlist
Thanks! I'll look at the SCF tools. However can't the developers of SU control/prohibit a particular action of a plugin? Isn't it the function of SU that allows the plugin toolbar to show in the first place?
And, of course, I think you realize, that although I can add managers and plugins to improve my use of SU (and I am glad of suggestions), it doesn't change a wish that the application were better out of the box, if only for the new user who doesn't have the plugins to solve their frustrations. I mostly find the extensions window a pain because it is SO poorly designed and is never improved, not that I haven't learned to live with it.
Have been working in sketchUP on a couple of complex architectural and landscape project just now and thought it will be worse to update a wish list.
GENERAL
1A. Xref or other proper Reference system with Project folder setup.
So you can see all References in the Master model and been able to open them start from the master model make changes in separate file,
then save and update the master model1B. Some kind of team work please
X64 for big complex project
Texture folder. Each SketchUp file will have a separate Texture folder inside a project folder. To keep all organise.
Faster Viewport using modern OpenGL technologies. Nice representation , colours , anti-aliasing , soft shadows, nicer fog and light.
Groups for Layers
High Quality Google Maps with option to grab bigger locations
X64 and FASTER Layout
I think it is time to introduce wall, slab, window/door, curtain wall, elements
Components to be able to cut through walls ( two faces )
Better lines and curves. Able to see centre point of each curve. Able to see tangent points.
Line types (without using plugin)
OSX
Material list
Show total area of material in a model by right click on the material inside the material browser. Yo can do it on Windows
Better UI
Full screen
Just wanted to ask is there any official way to submit our wish lists to Trimble directly? Of cause they work hard to deliver better program but they quite close from the community.
Updates are very rear. No information is given unfortunately .Cheers
ArtPen. Nice list.
On the XREF idea (it would be great if this were handled to save MB's), I have method that is similar, if you haven't tried it. I often use a component for a whole building, especially accessory buildings in site. I get the footprint laid out then I save the component (contextual menu) as SU file. I then do my work on the building in that file. I can "reload" (contextual menu) anytime into the main site file. It usually comes right in exactly where the old version was (occasionally I do something to throw it off, but it's easily fixed). You can make a file for the structure/ shell of the building that is used both in the site model, for exteriors, and in another model that has only interior elements for that building--so you are not compiling large models with useless geometry.
Very nice list, ArtPen. It just summarizes everything that SU has to have.
I want it all... and I want it now!
"- Stop the Esc key from quitting dialogs!!!!!!"
Yes, yes, yes !!!!!!!!!!!!!!! -
Pbacot thanks for the tip. I should try it.
Another though: Why not put SketchUP on App Store for Mac users?
GENERAL
Groups for Layers
Cheers
good list artpen..
i disagree with #3 though.. i'd way rather have the textures stored in the .skp (as they are now).. otherwise, for every .skp i have, i'd also have a texture folder? sounds harder to organize.. not easier (for me at least)
#8.. hmm.. what are you imagining for that? a library of components? parametric components?
people from the sketchup team read these forums from time to time but they generally won't engage in a thread like this.
trimble has a discourse though:
http://forums.sketchup.comthere's a 'feature request' category available.
well, they do yearly updates these days so those long waiting periods seem to be over now.. but yeah, i don't think i can recall someone from the team saying "expect this in the next release" (or whatever).. that's just how they are.
1: it would need to be more expensive than the Windows version and negate all the approved resellers...
2: it may have to remove the ability to add Plugins, to comply with the App Store guidelines...
I don't think we want either of those.
Sketchup curtain walls. Check this out:
@derei said:
I WISH...
Arcs with variable number of segments (sides). Option to either set number of segments for arc (eg. 12), or to set the length of one segment and the total number of segments to be approximated depending on total length of the arc.
It also could be a nice plugin... I tried a piece of code, but I could not figure out how to make the inference, so I gave up.you can sorta do this already
• draw arc
• right-click arc -> Divide
• move cursor around arc.. notice the pop up displays segment length and # of segments--- (optional steps -- the above draws the correct geometry but destroys the su arc_ness)
• note the number of segments needed for the desired length
• esc out of the divide command
• right-click arc -> Entity info
• enter the correct number of segments -
then save and update the master model...
- Texture folder. Each SketchUp file will have a separate Texture folder inside a project folder. To keep all organise.
Groups for Layers
- Better lines and curves. Able to see centre point of each curve. Able to see tangent points.
Take a look at Inteloide's component manager plugin. Does that exactly;
There is a plugin that sort of does that too.
Jiminy's Layer Panel Plugin
Sketchup 2014 Classifier (IFC 2x3) predifineable does that already. Then you can do an IFC export.
http://www.sketchup.com/products/sketchup-pro/2014-features#interoperability
- Even if I'm sure this is less than you ask for... there is a plugin for finding center points on exploded arcs and circles (the others you can already) there is also a plugin for true tangents and perpendiculars to arcs and circles.
If Trimble take us, users, seriously...they make complex object handling faster....much much much faster....
• custom toolbar shows plugin icons upon launching the application (mac)
now that this is fixed (su2015), it almost seems like it's a new feature instead of a fix for a pesky little thing that's been following sketchup around since ruby was introduced..
regardless, i truly appreciate you (@suTeam) squashing it.. thank you.
@jeff
Auto Activate Paint Tool is also fixed... -
I cannot view a thumbnail view of my (mac) Sketchup 2015 files in Finder. I've read many of the work arounds, tried downloading GraphicsConverter to view the thumbnails, but no luck. I noticed that i can view a very low res thumbnail of files made with earlier versions of Sketchup, >2013. Thanks.
Actually, The problems with Sketchup aren't the items you mentioned. In fact I do believe you are right. You gre out of Sketchup and should more on to zbrush, blender etc. All which have robust tools for bones, animation and rigging.
I don't need that.
What I actually want is intersect to actually intersect. Now five step bs. I want to take a component and shove it into another and they become one. Thats intersect. I want axis arrows on move so I can select the axis and move only in that direction (like Second life has. Its sad that a 10yr program has better 3d movement but they do). I want the protractor to die. I want the bounding box to turn into a sphere when you rotate and again select a axis and only rotates that way. I rotate to be ONLY rotate. Copy can go elsewhere. If I wanted to copy I would click copy.
These minor issues is what I think needs to be fixed. -
Click and hold on the rotation axis, drag and select rotation axis, release and rotate...
@betazero said:
A wish list is nice but it seems like Sketchup development has hit a standstill for the last 5 years or so. I will share my wish list but I think it would be better spent just learning ZBrush. Anyways here it goes just for the heck of it...
( This is for the Mac. I can't speak for the PC version )
Bug fixes
- The tool palettes are a mess. Layers need to be easily accessible from the toolbar and the color palette need to be streamlined...
- Zooming can be a nightmare. You can get stuck zooming super small or way to fast. There are some workarounds like exporting the component your working on then then importing but why is this still a problem?
- Models get broken way to easily and you spend so much time cleaning stuff up (maybe I just suck at Sketchup??).
- DWG importing into layout. I call this a bug because it just seems like it should have always been there...
Wish list
- Lights and emitting surfaces (duh...) . Why has this not been added yet??
- Bones, rigging, animation the whole nine yards.
- Zbrush like clay modeling
- 3D painting
I think Sketchup better get moving on its development. With Zbrush now having Sketchup-like tools and Autodesk Fusion 360 being a pretty cool 3d program (still needs a little work) , Sketchup could become a dead piece of software.
- Yes. On a Mac there needs to be some option to dock the windows and keep some order, especially session to session. To me GIMP is a good example. You have all sorts of choices on what to do with the palettes. For the colors I think they are hampered by Apple to some extent but I can't believe a written listing can't be worked in.
- Don't see a problem with zoom. I think when one zooms over empty space and too close to a surface there should be some failsafe to keep it from forcing ridiculously fast or slow zoom. "Unnecessary Zoom!!!"
Your wishlist items are outside of Sketchup IMO. Actually you can add lights with Twilight etc that become part of the model. I want to paint too and hope there's a plugin someday, but I bet this would be too much for most users (and the SU core).
good stuff..
