    Rotate Extruder
    12 Posts 5 Posters 795 Views 5 Watching
    • cottyC Offline
      cotty
      The plugin component stringer should help you here.
      (don't double post)
      my SketchUp gallery
      • Flippie123F Offline
        Flippie123
        (don't double post)
        The component stringer does not work for this. Please have a look at the attached picture. That is the result after using component stringer
        • massimoM Offline
          massimo Moderator
          Have you already tried this one?
          SketchUp Plugins | PluginStore | SketchUcation
          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
          (sketchucation.com)
          I don't use it myself so I can't say if it will work for you.
          And here is the related thread.
          http://sketchucation.com/forums/viewtopic.php?p=94888#p94888
          • BoxB Offline
            That is one possible result. Move the axis of you component to the center of the shape and align the blue axis with your path. Choose the option of no scaling, can't remember what it's called and I'm on my phone. Chose the rotation and you should get something very close to your image.
            • cottyC Offline
              cotty
              Like this...
              stringer.skp
              my SketchUp gallery
              • cottyC Offline
                cotty
                http://sketchucation.com/pluginstore?pln=Far
                Watching at the last image of the first post, this might be the better way...
                my SketchUp gallery
                  Flippie123
                  [attachment=0:3b604wyj]<!-- ia0 -->far.jpg<!-- ia0 -->[/attachment:3b604wyj]
                  I'm using the 'follow me and rotate' plugin now. It seems to work fine for a simple shape but with a more complex shape it get's difficult.
                    This one LLSToolbar by Kirill2008 ?
                      Or this one by Albertsoft ?
                      Albert
                        Flippie123
                        This plugin works very well. I divided the my lines into 10 pieces before using the 'follow me and rotate' to make the shape more smooth. Next thing I will do is try to make a more complex shape.
                          Flippie123
                          This is very close to what I wanted to make. Thanks guys!
                          I will have a look at that 'Helix' plugin too! It looks interesting. 😍
