    Rotate Extruder
    12 Posts 5 Posters 852 Views 5 Watching
    • Flippie123F Offline
      Flippie123
      Rotate extrude?
      It there a plugin that can rotate a section around an axis and extrude the shape along a curved line at the same time?
      What I want to achieve:
      1: divide a curved line into equal parts.
      2: take any flat shape and extrude it along the curved line.
      3: but when it extrudes the shape must rotate around it's central axis. A certain amount of degrees.
      Something similar like a torus, but not round.
      Is there someone who can write me a plugin who can do that, or is there already a plugin like that available?
      Cheers!
      Phill
      Curve get's divided into 400 equal pieces.
      Section get's extruded along every point and get a angle.
      Every section get's connected.
      An example of the complex shape which I want to make at the end.
      • cottyC Offline
        cotty
        The plugin component stringer should help you here.
        (don't double post)
        my SketchUp gallery
          Flippie123
          (don't double post)
          The component stringer does not work for this. Please have a look at the attached picture. That is the result after using component stringer
          • massimoM Offline
            massimo Moderator
            Have you already tried this one?
            404 Not Found
            (sketchucation.com)
            I don't use it myself so I can't say if it will work for you.
            And here is the related thread.
            404 Not Found
            (sketchucation.com)
            • BoxB Offline
              That is one possible result. Move the axis of you component to the center of the shape and align the blue axis with your path. Choose the option of no scaling, can't remember what it's called and I'm on my phone. Chose the rotation and you should get something very close to your image.
              • cottyC Offline
                cotty
                Like this...
                stringer.skp
                my SketchUp gallery
                • cottyC Offline
                  cotty
                  http://sketchucation.com/pluginstore?pln=Far
                  Watching at the last image of the first post, this might be the better way...
                  my SketchUp gallery
                    Flippie123
                    [attachment=0:3b604wyj]<!-- ia0 -->far.jpg<!-- ia0 -->[/attachment:3b604wyj]
                    I'm using the 'follow me and rotate' plugin now. It seems to work fine for a simple shape but with a more complex shape it get's difficult.
                      This one LLSToolbar by Kirill2008 ?
                        Or this one by Albertsoft ?
                        Albert
                          Flippie123
                          This plugin works very well. I divided the my lines into 10 pieces before using the 'follow me and rotate' to make the shape more smooth. Next thing I will do is try to make a more complex shape.
                            Flippie123
                            This is very close to what I wanted to make. Thanks guys!
                            I will have a look at that 'Helix' plugin too! It looks interesting. 😍
