    Can´t change frame rate in Keyframe Animation
    7 Posts 3 Posters 328 Views 3 Watching
      LARV
      I´ve downloaded the Keyframe Generator trial version. I´ve done an animation that I want to export to video. But I can´t change the frame rate in the KG settings from 10. With 10 it´s "choppy" as hell. I probably need 40 or something. Anyway; I can´t change it. It stays at 10. What am I doing wrong?
        LARV
        300 000 members and no reply? Someone must know? 😉
        • massimoM Offline
          massimo Moderator
          Sorry I don't use this plugin. Anyway, I moved the topic to the plugins's section so, maybe, you can have more feedback. Btw, you mean "Keyframe animation", right?
            LARV
            Oh sorry, yes, Keyframe Animation
            • massimoM Offline
              massimo Moderator
              Ok, I edited the subject of the topic.
                Did you try contacting the author through his site? It seems to me that of the 300,000 members of SCF, he'd be the mostly likely to have the solution for you.
                  LARV
                  Yes, I em-mailed him, but thought I might as well post the question here if others use the plug-in, or in case he doesn´t answer.
