    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 357.4k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
      http://sdmitch.blogspot.com/
      • deaneauD Offline
        deaneau
        that would be great,
        if you need a sketchup file i can send this via PM
        can i use this in a curve,too?
        thank you dean
        • sdmitchS Offline
          sdmitch
          thank you dean
          Please do. I hate trying to guess.
          • deaneauD Offline
            deaneau
            Suggestion for different Texture Packs.
            what do you think about different texture pack.
            in the texture folder i have different folders with diferent textures.
            this could be selected via dropdown.
            thank you Dean
            • deaneauD Offline
              deaneau
              Hallo is this possible?
              green arrows mean only this direction(s) i want
              selected multiple face doing this in one step
              here what i have choose in preferences
              the wall in the backbround is a curved object.
              the result is this
              reason could be that a curved face is splitted in smaller face like this
              the wall part i want produce have an exact width of 1200mm (3' 11")
              or have anybody an other solution?
              download this file here
              Page Not Found
              Web word processing, presentations and spreadsheets
              (drive.google.com)
              the curved face havnΒ΄t the exaxt width πŸ˜•
              thank you
              • sdmitchS Offline
                sdmitch
                Sorry but FloorGenerator only works on faces not surfaces. Even if hidden geometry is not displayed, when you pick a point on the surface you select just one of the faces that make up the surface.
                You could create a face with the overall dimensions of the surface. Then use Shape Bender to produce the curved surface after applying the tile pattern. A bit of work but all I can offer at this time.
                • deaneauD Offline
                  deaneau
                  yes this i have try before i asking here, with Fredo Scale ( Radial Bending)
                  what you mean is Chris Fullmer Shape Bender.
                  i have never tried it before.
                  ok, this work.
                  now i have a problem. the segments have not the exact lenght.
                  your plugin AddPts2Curve was my help, to see where on the curve is the 1,2m point and the next etc.
                  I will try step by step all your plugins.
                  Helper like plugins will every time be welcome.
                  thank you
                    tomot
                    @sdmitch Its the first time I see HTML code embedded in a Ruby script. Thanks for not using .rbs
                    It gives me some confidence and a template to redo some of my scripts incorporating HTML. πŸŽ‰
                    Finally I have an example & see how with HTML I can place pictures next to my drop-down boxes.
                    cheers!
                    [my plugins](http://thingsvirtual.blogspot.ca/)
                    tomot
                    • sdmitchS Offline
                      sdmitch
                      That's the way I learned what little I know.
                      • deaneauD Offline
                        deaneau
                        Hello Sam,
                        is it possible to insert the feature that tiles is grouped?
                        actually if i generate a floor i have only a main group.
                        when tiles is grouped i can do random rotate with mover2.
                        this will look a little bit more inperfect.
                        in mover i can use random rotation in x,y or z axis and can insert the degree by value.
                        thank you
                        Dean
                        • sdmitchS Offline
                          sdmitch
                          @deaneau said:
                          Hello Sam,
                          Do you mean each individual brick is a group?
                          That is what the "Random Imperfections" option is for. That feature was fixed and enhanced in the last update on 21-Sep
                          thank you
                          Dean
                          [attachment=1:1zcdcsd3]<!-- ia1 -->_2014.10.07_23h12m17s_019_01006.jpg<!-- ia1 -->[/attachment:1zcdcsd3]
                          [attachment=0:1zcdcsd3]<!-- ia0 -->_2014.10.07_23h29m06s_020_01007.jpg<!-- ia0 -->[/attachment:1zcdcsd3]
                          • deaneauD Offline
                            deaneau
                            i have seen your plugin "Random Rotation".
                            in this plugin you could insert 3 checkmarks for x y z-axis.
                            so i have the control for axis. actually looks that the rotation work in all axis.
                            like this
                            • deaneauD Offline
                              deaneau
                              the random inperfection rotate in all axis.. some times i would have only a rotation in z-axis. a value in degree is helpful.
                              when all tiles would be in own group..so i could work with mover2 and in the last step ungroup this tiles.
                              ungrouping go faster than grouping if i have tiles more than 1000+ .
                              thank you
                              • sdmitchS Offline
                                sdmitch
                                like this
                                [attachment=0:2bd2nz7e]<!-- ia0 -->_2014.10.09_09h12m14s_003_01011.jpg<!-- ia0 -->[/attachment:2bd2nz7e]
                                That plugin is for rotating whole components or groups not individual entities within the component or group.
                                • deaneauD Offline
                                  deaneau
                                  yes ..ok no problem
                                  • deaneauD Offline
                                    deaneau
                                    Hello Sam,
                                    i have a project for this i would use your FloorGenerator.
                                    i know that you have a random textur feature in this plugin.
                                    what do you think about to integrate a feature that doing follow:
                                    i have 10 different pattern and i would use 10 different texture packs.
                                    a approach to solving this problem could be that all textures have a prefix.
                                    for example.
                                    A_Texture1,A_Texture2,A_Texture3 etc
                                    B_Texture1,B_Texture2,B_Texture3 etc.
                                    A_ B_ C_ etc is the prefix.
                                    Texture1, Texture2 is a placeholder for my own given name.
                                    when i use in the first step the Tile Pattern and i will use a texture pack A_
                                    dropdown menue let me choose the Prefix A_
                                    in the next step i would use Brick Pattern with TexturePack B_
                                    i choose only in the dropdown the Prefix B_
                                    this textures with a given Prefix i want use for your Random texture feature.
                                    actually i must change the textures in the texture folder when i want have different textures in the next step.
                                    if the floor is generated i would have all parts in own groups.
                                    actually the floors is only in one main group.
                                    why i would have this features.
                                    the workflow after integrating this feature would be more faster and when the objects is in own groups i can animate this in other programs.
                                    download here
                                    Page Not Found
                                    (drive.google.com)
                                    thank you
                                    p.s.component is better than groups i think
                                    • deaneauD Offline
                                      deaneau
                                      Hello,
                                      i have had a problem with random texture.
                                      my result was this:
                                      after renaming all textures with a prefix i have solve this problem
                                      result:
                                      here a example for file renaming:
                                      and here a freeware to remame files with your favorit prefix etc.
                                      Download for Windows and Mac - Advanced Renamer
                                      Download the batch renamer, Advanced Renamer for Windows and macOS.
                                      (www.advancedrenamer.com)
                                      πŸ‘ πŸ‘ many thanks at Sam for the hard work for the Floor Generator πŸ‘ πŸ‘
                                        deadakos
                                        I was looking for such a tool for SketchUp so long! Thanks for it!
                                        I'm playing with the plugin now, and I have a questions:
                                        • is there a way to limit the used quantity of the colors in "Rand_clr" mode?
                                        • sdmitchS Offline
                                          sdmitch
                                          Sorry but no.
                                            logan683
                                            What is the latest version of this plugin? This is different than the one downloaded straight from the SketchUcation store in SU.
                                            Also, you can't change the size of the pattern?? I want to set a 10' long wood board pattern, but it's stuck on 10" and won't accept any changes.
                                            Does this work correctly at all?
                                            • 16
                                            • 17
                                            • 3 / 17
