    Move tool does not move toward in Z axes
    7 Posts 3 Posters 2.3k Views 3 Watching
    • L
      littleche
      Hi ...
      in this model , move tool does not work in Z axes for Box marked .
      This problem is resolved with copy of the box and Moving Copy Box... but This is a bug.
      Is correct my assumption ?
      move Bug.skp
      • BoxB
        Without even looking at your model, Right Click on the component and select Unglue from the context Menu.
        • massimoM
          massimo Moderator
          ... but This is a bug. Is correct my assumption ?
          No. Your object is just glued. Select it-->right click-->unglue.
          • L
            littleche
            What a mistake ! I was not aware of this ,Thanks for your help .
            One other question!
            How the model is affected in this way?
            Is this the same component settings? Why not solve the problem in component setting?
            • BoxB
              Yes indeed, why not. Either change it in the settings, or right click and unglue. There are many ways to skins cats.
              • L
                littleche
                thank you again ... 👍
                • BoxB
                  Just be aware that gluing isn't a problem to be fixed but a useful feature. It allows you to easily place components on different faces at various angles and move with those faces.
