    Sketchup and ArcGis
    6 Posts 3 Posters 585 Views 3 Watching
      mack
      Hi guys,
      I've modelled a whole city in SU and now I want to import in ArcGis 10.2.2.
      If I use skp version 6 the entire model is imported as only one feature, while I need one feature for each building/group.
      Does anyone know a tool or script for batch saving (or export at least) a SU model consisting of many groups in many single files?
      Please help since I don't really want to do it manually!!!
      Thanks,
      Marco
        If they were components instead of groups you could save them as a collection of components in a single directory. They'd save out as individual SKP files. No need for any plugins to do it, either.
        • BoxB Offline
          I'm not quite sure what you are wanting but Tig has a plugin that saves all components from a model separately into relevant folders.
          http://sketchucation.com/forums/viewtopic.php?p=530343#p530343
            mack
            Thanks Box and Dave R, that sounds really interesting.
            I need exactly something like this, the only thing is that I probably need to convert manually each group in a component, unless there's a plugin also for this...
            Marco
            • BoxB Offline
              You could try the confusingly named plugin, Groups to Components. πŸ˜‰
              http://sketchucation.com/forums/viewtopic.php?p=257578#p257578
                mack
                πŸ˜‰ Tahnks Box, next time first I will search then I will speak!
