    Quicker architectural modeling + construction documentation
    extensions
    32 Posts 13 Posters 9.8k Views 13 Watching
      I don't see how I will be using this in the parameters above
      It was just for maybe speed modeling in particular cases! Organic walls or other crazzy repetitve forms! πŸ˜„
        kaas
        @juju said:
        I'm looking into getting a plugin (or multiple plugins, as the case may be) to help speed up architectural modeling and construction document creation. ...
        If I may ask, what kind of projects do you work on?
        Having another look on your list:
        Immediate needs:
        • model walls (solid / cavity / drywalls), ->profile builder. For cavity walls I use a workaround (see pic) with a connection at the top that I remove immediately after creation of the cavity wall. Hoping in the new version this won't be necessary anymore.
        • model foundations (options obviously important),-> profile builder
        • model doors (flexibility in creation is important), -> create a personal library OR have a look at Windowizer OR pay somebody make a ruby-plugin for you, tailored to your needs
        • model windows (flexibility in creation is important), -> ditto
        • model roof structures (trusses / rafters / lattice girders, purlins), -> profile builder, instant roof?
        • model roofs quicker (if additional functionality is available, great) -> instant roof? I have never tried it though.
        • model stairs with handrails, -> some plugins are available. depends on the level of detail you want. No suggestions.
        • something to facilitate workflow in Layout, have not used it since it's second iteration I must admit, -> I tend to do as much as possible in Sketchup. Even the dimensioning and hatches. Layout to me is just for adding some final texts and doing the layout of the individual views. Why? It doesn't crash on me, you can create Ruby plugins to assist with some stuff and its more fun.
        • jolranJ Offline
          jolran
          Not sure if this will be of any help, 2dboolean.
          (It's free so you can have a look at no expense, and see if it's useful)
          http://sketchucation.com/forums/viewtopic.php?p=350557#p350557
          Could be used not only for fitting 2d components to a face, but also in the creation of extruded sheet metals for walls etc. Or any other pattern you can come up with.
          (manual is on same page)
          • pbacotP Offline
            if your time is being bought and sold, ValiArchitect scripts pay off right away. I especially like the Fence and rail to eliminate tedious work. The results are not accurate for close ups but they can be modified for most rendering or construction model needs.
            I like InstantRoof too, but find it doesn't help me in design as it does not quite create the roof details I use. It can slap a good looking roof on in no time though. I tend to build more of a massing shape now and add eave details after, due to design work flow.
            As to the subscription, the biggest drawback is I have to refresh the license almost every session I wish to use the tool by going online to the VA site before using. I have one computer but the scripts know if I am logging on at home or work and won't recognize the computer.
            • KrisidiousK Offline
              Krisidious
              First and foremost... You want the SketchUcation Plugin Installer. Don't leave home without it. It's your doorway to plugin control, updates and instant installs.
              Plugin Store Download | SketchUcation
              Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
              (sketchucation.com)
              Architecturally speaking The ValiArchitect plugin set 'Instant Architecture' one fee, one time per year, discounted, is indispensable... If you're going to do architecture in Sketchup you need to have it. look at it again, read through the PDF's and look at the power it holds. It's going to save you way more than $120 in time... I promise.
              Instant Architecture | Vali Architects | Instant Scripts
              (www.valiarchitects.com)
              If you're into detail, then 1001bit tools pro is a great addition. It's very affordable. And a one time fee. Again, look deep into it. It has many tools and is very powerful. I would say it's more aimed at commercial, but it's useful to residential as well.
              1001bit.com - Architectural Tools for Sketchup
              (www.1001bit.com)
              Garry K has a few great plugins. His curved stairmaker is the bomb... It will save you a lot of time. He also has a really fantastic cabinet making plugin and another called DoorMaker
              CabMaker32CabMaker32 – Kitchen and Bathroom Cabinet software
              (cabmaker32.com)
              Skalp, Fantastic Sections... requires 2014 Pro. has a free version called Rich Sections
              Skalp for SketchUp
              Skalp (www.skalp4sketchup.com)
              For Topographical map importing and building Toposhaper by Fredo is a fantastic plugin.
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52039
              LSSZone by Kirill B is a powerful tool for making labels and material lists for sketchup.
              https://sites.google.com/site/lssoft2011/home/lss-toolbar
              PlusSpec is a full BIM system for Sketchup plus an architectural drafting assistant... Too much power to list here. You'll have to check it out. Right now it's mostly metric but Imperial is in the works.
              PlusSpec – Innovative CAD technology for Virtual Design & Construction
              (www.plusspec.com)
              BuildEdge is another BIM system, less expensive than Plusspec but also less powerful. Still very useful for stand residential and commercial architecture.
              (www.buildedge.com)
              Revizto is a Static Render/Live Render Walkthrough presentation system that is another on top of my list. I couldn't live without it now. it really does wonders for working with a client and giving them powerful tools to sell or to understand a project better. Cuts down on changes later in the project.
              301 Moved Permanently
              (revizto.com)
              Landscaping wise, 3D treemaker is a Free/Pay (inexpensive) custom plant/tree making plugin.
              Tig is a SU guru... he has so many plugins I can't count. Tig has a few I can't live without...
              Mirror
              http://sketchucation.com/forums/viewtopic.php?t=31410
              CutnFill
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55250
              http://www.3darcstudio.com/downloads-files/24-3d-tree-maker-sketchup-plugin.html
              I could go on all day... There's more and then these geniuses are always coming up with something to blow your mind. I can't even imagine what's in store for us down the road. Tig, ThomThom and Fredo are some of the guys who have so many valuable plugins that I could never hope to describe them all. i suggest after you get the PluginStore downloaded, you search by author and look at each plugin they've made. you'll probably want most of them. Of course there are many, many other plugin authors that have contributed tons of stuff over the years. Most of them can be found there in the plugin store as well.
              By: Kristoff Rand
              • jujuJ Offline
                juju
                Thanks for all the feedback so far!
                Skalp is a plugin I have also acquired, I'll take a look at some of the others...
                Has anybody have any experience with TOMOT's door/window making ruby scripts?
                  Krisidious
                  I have... I use them. they're handy as well.
                  Andersen windows and doors has a big program with a plugin connecting it to sketchup.
                  http://sketchucation.com/forums/viewtopic.php?t=27574
                  By: Kristoff Rand
                  • utilerU Offline
                    utiler
                    PlusSpec [as Kris pointed too much to mention everything here but it is 'THE' most advanced BIM plugin for SketchUp there is. As for back up, I know the guys there have a number of developers on staff for customer feedback and continued development. Still some work to be done [I guess that could be said for all programs] but nothing else comes close. Period.
                    Just Curious...
                      Krisidious
                      Agreed... it's very powerful. Testing it right now. One thing I really like about it; it's as BIM as you want it to be. You can go full tilt and make your own custom BIM objects or just use the HUGE selection they have... or just build great houses with their modeling system. It seems to cover the amateur to expert range well.
                      By: Kristoff Rand
                      • aadbuildA Offline
                        aadbuild
                        I wrote a Plugin that would be right up your alley.
                        https://www.plusspec.com/
                        I started as a carpenter, builder, designer in the residential industry. I need to be able to design quickly yet estimate with precision. I needed to be able to conceptualise using Sketchup yet validate the design with construction attributes. I can not see the point in designing and then manually quantifying so essentially I employed 3 developers to write a plugin to do exactly that. It took me 7 years and the original intention was to keep it in house as it gave me an advantage over my competitors locally.
                        PlusSpec will add multiple dynamic window types into multiple wall types including cavity walls, add rooves, floors, concrete add textures The new version that is due to be released soon will enable you to create your own walls from your own textures and add pricing and wastage. There is too much to list in this post yet the Plugin comes with 36 tutorials and an interactive tutorial that talks to you inside of Sketchup.
                        PlusSpec is far more expensive than your everyday plugin yet there is good reason for this $395 (about $370 US dollars). It is super powerful and will cut your design and estimating time 10 fold.
                        PlusSpec is parametric so you can change on the fly. All the windows and doors can be moved and deleted and the structural components will change to suite. You will also notice PlusSpec comes with a library of over 750 individual models that are free and they are low poly, which keeps you models easy to navigate on a low spec computer.
                        There is a 30 day money back guarantee as well.
                        Here is an example of one of the jobs AAD Build just completed with PlusSpec.
                        This is the completed job
                        This is the model we estimated from, drafted from and collaborated with the client.
                        Rendered PlusSpec model in Sketchup and Thea.
                        BTW I am hearing a lot of good things about Thea render from many Sketchup pro users. I personally outsource my rendering Pete (Solo). Pete makes my homes easy to sell and it saves me a lot of time also. πŸ˜„
                        Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                        • jujuJ Offline
                          juju
                          [attachment=1:2cavdd70]<!-- ia1 -->Dons road complete.jpg<!-- ia1 -->[/attachment:2cavdd70]
                          [attachment=2:2cavdd70]<!-- ia2 -->Designed with PlusSpec and and Sketchup.png<!-- ia2 -->[/attachment:2cavdd70]
                          [attachment=0:2cavdd70]<!-- ia0 -->LinkedIn PlusSpec.png<!-- ia0 -->[/attachment:2cavdd70]
                          Hi, thanks. How much is the renewal after 12 months?
                          • jujuJ Offline
                            juju
                            thanks for this link, the program / plugin seems really great, the type of thing that I could get used to, it's a pity it won't be of use to me in South Africa - we don't use Anderson fenestration products here
                            • aadbuildA Offline
                              aadbuild
                              Currently the resubscription is the $395 Yet we have really only been live for 3 months so we still have 9 months to come up with a more suitable ongoing payment method. Ill keep you posted on changes. If the Aussie dollar keeps going down like it is you will probably pick it up for 5 bucks. πŸ˜„
                              • SkalpS Offline
                                Skalp
                                Skalp for SketchUp
                                A little correction RichSection is not the free version of Skalp.
                                Skalp
                                http://www.skalp4sketchup.com
                                • SkalpS Offline
                                  Skalp
                                  @juju said:
                                  I've decided I want to move on, in the near future, to using SketchUp (Pro 2014) for creating construction documents in addition to being a visualization tool. I recently got the following three books and am busy working my way though them, free time is limited so it could take a while: "SketchUp to Layout" (Matt Donley), "The Sketchup Workflow for Architecture" (Michael Brightman) and "SketchUp 2014 for Architectural Visualization" (Robin de Jongh + Thomas Bleicher). I will probably get "Rendering in Sketchup" (Daniel Tal) as well, there are a few others I am considering, but free time isn't something I have a lot of lately. Hopefully I'll get enough tips and what-not from the first three.
                                  I'm looking into getting a plugin (or multiple plugins, as the case may be) to help speed up architectural modeling and construction document creation. I've looked around a little, it seems as though there is the odd few individual plugins that may handle what I'm mainly interested in, and then there are plugins (let's call this collective plugins for now) that do a couple of things at a time.
                                  Immediate needs:
                                  • I will probably discover other things I need as time passes, but can cover these as they come along.
                                  Modeling:
                                  • 1001 bit pro v2 (US $48): no new updates for a while, a little worrying
                                  • Buildedge PLAN v3.2 (US $29): an update seems to be coming soon, would love to know what the updates would be
                                  • Dibac (49 euro): seems like there is a language barrier and support problem, and did I mention expensive?
                                  • any other suggestions?
                                  Construction Documentation:
                                  • Condoc Tools ($150) - seems very helpful, I hate the annual renewal license though, seems like it will cut you off if you don't renew at the full price after a year (yikes!)
                                  Obviously if I can get the functionality that one would require in a free plugin it would be super as funds are primarily being diverted to raising my son (recent addition, very humbled and extremely excited) at the moment.
                                  Licensing should be straight forward, if I pay for the plugin the license must preferably not be on an annual / monthly / whatever renewal basis (I call it ransomware). If I pay for it I'd like to keep on using it until such time as I choose to upgrade or quit using it.
                                  I'd like to know what the community experience and recommendations would be.
                                  Take a look a Skalp for SketchUp it's the missing part for making real construction drawings with SketchUp and Layout. Michael Brightman and Matt Donley describe a full workflow on how you can create 2D drawings from your models. They wrote a big part in there books about it because there isn't a standard way for doing this in SketchUp... until we developed Skalp.
                                  Skalp is easy to use out of the box, as well as giving it the power and flexibility to do more advanced tricks as people get used to it.
                                  Skalp Creates fully hatched live sections which can be used in Layout for making construction documents. Every section can have multiply representation in different scenes.
                                  We started creating Skalp about 5 years ago for our own architectural firm. Because we liked working with SketchUp and I didn't like to do double work in my cad package. Later when Layout was introduced we started to use Layout instead of our cad program to make our drawings.
                                  skalp is a hugely useful plugin and is worth every cent you pay for it.
                                  Skalp is not free and it's not really cheap, but we spend a lot of time in this product and we have still lot of good ideas to make Skalp even better in the near future. Skalp saves you a lot of time (= money) on creating construction documents compared to the workflows described by Michael and Matt (These workflows they are very clever work arounds for missing features of SketchUp and Layout)
                                  The Skalp Team
                                  Skalp
                                  • jujuJ Offline
                                    juju
                                    Immediate needs:
                                    Modeling:
                                    The Skalp Team
                                    Thanks for the input, as mentioned earlier, I've already acquired a Skalp license (just over 3 months ago). I've been bogged down with work, regular CAD stuff so have not really had a chance to take it for a spin (I have the latest build though, beta 8 I believe). I'll have to figure out and see if there will be problems when using it with something like Michael's ConDoc Tools.
                                    I am really wanting to make the shift to using SU+LO for everything from conceptual to construction, but I'm not rushing it as I need to finish reading at least Matt and Michael's books. After that it's figuring out model organisation, then only the move across I think. Up until now I've mostly used SU for conceptual and visualization, model organisation has played a role, but not much so since the process did not depend on it so much, will have to get it right (or as close as possible) or I'll just be wasting my own time.
                                    • EdsonE Offline
                                      Edson
                                      hi juju,
                                      below I post a list of "must have" plugins; they happen to be the ones I use most. yes, 1001bit Tools is immensely useful. two other plugins I strongly recommend are Skalp and Layers Panel.
                                      Sketchucation Plugin Store from Sketchucation
                                      Selection Toys from EW
                                      Rotate Rectangle from EW
                                      Path Copy from Smustard
                                      Weld from EW/Smustard
                                      Profile Builder from EW/Smustard
                                      Artisan from EW
                                      Selection Memory from EW
                                      Instant Site Grader Nui from Vali Architects
                                      Instant Roof Nui from Vali Architects
                                      Instant Road Nui from Vali Architects
                                      Instant Grade Nui from Vali Architects
                                      CFL Repeat Copy from EW
                                      Layers Panel from Sketchucation
                                      Extrude Tools from Sketchucation
                                      Round Corner from Sketchucation
                                      Repaint Face from EW
                                      Fredo6 Tools from Sketchucation
                                      CLF Tools from EW/Sketchucation
                                      Tig Tools from Sketchucation
                                      1001bit Tools from EW
                                      Skalp
                                      http://www.mahfuz.arq.br
                                      • utilerU Offline
                                        utiler
                                        NIce list of plugins, Edson.... I'll add one.
                                        PlusSpec.
                                        Just Curious...
                                        • jujuJ Offline
                                          juju
                                          @edson said:
                                          hi juju,
                                          Artisan from EW
                                          Skalp
                                          Hi Edson, thanks for the input! Much appreciated. Quite a list there, I'll have to take a look and work my way through.
                                          • mwdsM Offline
                                            mwds
                                            Generally: Great tips from all the contributor.
                                            However, The main thing on the list for me was - model walls (solid / cavity / drywalls)
                                            Surely there is a plugin that gives us a multi-element wall system (say brick veneer) with the ability to specify wall height, thickness and element composition (ie outer thickness, cavity and inter thickness, all with assigning various layer to each).
                                            Yes, there are some very cool and trick plugins out there and I would have to agree with many that I do not like yearly renewals.
