    Screengrab in SU
    23 Posts 8 Posters 1.3k Views 8 Watching
    • BoxB Offline
      Much like my impression of the whole Mac thingy. ๐Ÿ˜ฒ
      • oldskoolflashO Offline
        oldskoolflash
        @slbaumgartner said:
        Dave,
        Thanks for the suggestion. I took a quick look at the Snagit site and it left me with the same question I had about the native tools. Namely, if the tool requires you to use a mouse action to designate the target to capture (click a window or drag out a rectangle) how do you cause the Mac to retain the original application's cursor in the screen capture?
        Steve
        Yes, in my extensive (10 mins) experience the keyboard shortcut in Snagit it key to this as it freezes the screen in it's current state and, as Dave states, gives you a new cursor to perform the grab.
          oldskoolflash
          @box said:
          I haven't used a mac for a long time, but from memory isn't there a timer option in the grab app so you can set up what you want and it will grab the cursor too. I've been known to be wrong.
          I tried this but the cursor is still removed (presumably by the OS).
            After you start the timer you have to click back in the SketchUp window and then wait for the timer to run out.
              oldskoolflash
              [attachment=1:1triv1io]<!-- ia1 -->GrabApp.png<!-- ia1 -->[/attachment:1triv1io]
              The problem is (for me anyway) is that the cursor is either removed or substituted for a default one (see image below (Left is with grab, right is with Snagit).
                My error. The cursor isn't picked up. We'll stick to SnagIt and avoid the problem altogether. I tend to keep SnagIt open all the time. It puts a little tab over on the right side of the screen but it isn't in the way.
                • BoxB Offline
                  Move along, nothing to see here.
                  D'oh I'm wrong yet again.
                    dtrarch
                    Take a look at Faststone Capture
                    http://www.faststone.org/FSCaptureDetail.htm
                    Very slick and affordable.($19.00 US)
                    IMO the only one you will ever need. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    dtr
                      slbaumgartner
                      dtr
                      Provided you are on Windows - I see no Mac version.
                      Steve
                        driven
                        The native Quicktime Player records the cursor changes...
                        I'll upload a demo to youtube as you can't post videos directly here... [or can you???]
                        with_cursor.mov
                          driven
                          • sketch3d.deS Offline
                            sketch3d.de
                            you may want try the free Lightshot for Mac OS too.
                            Norbert
                              driven
                              If you use applescript, [which every mac user should, IMHO]...
                              you can launch Quicktime from a plugin button or menu item, which saves a bit of time...
                              one I just made...
                              You still need to deselect, highlight cursor in QuickTime drop-down tad if you want 'only' SU cursors
                              you click the button to run, drag the area you want, stop using the normal QT top menu button [will be the first on right hand side]
                              Save and then share, you need to close any QT windows before it will run from start again...
                              here's one I just made...
                              try it if you dare...
                              • kenK Offline
                                ken
                                Don't mean to hijack this thread. However, for Windows, I use PicPick for capturing screen shots or parts of the screen for procedures.
                                Since I write the procedures in Word, I just set my cursor in the word document where I wish to place the image, and just tell PicPick to send to Word, and presto, the image is there.
                                OK, back to the original subject, screen grab for Mac.
                                Ken
                                  driven
                                  sorry everyone, I was thinking Screen Recording...
                                  you can use the native screencatpture, from Ruby Console
                                  NAME
                                  screencapture โ€” capture images from the screen and save them to a file or the clipboard SYNOPSIS
                                  screencapture [ โˆ’SWCTMPcimswxto] file DESCRIPTION
                                  The screencapture utility is not very well documented to date. A list of options follows. โˆ’c Force screen capture to go to the clipboard.
                                  โˆ’C Capture the cursor as well as the screen. Only allowed in non-interactive modes.
                                  โˆ’i Capture screen interactively, by selection or window. The control key will cause the screen shot to go to the clipboard. The space key will toggle between mouse selection and window selection modes. The escape key will cancel the interactive screen shot.
                                  โˆ’m Only capture the main monitor, undefined if -i is set.
                                  โˆ’M Open the taken picture in a new Mail message.
                                  โˆ’o In window capture mode, do not capture the shadow of the window.
                                  โˆ’P Open the taken picture in a Preview window.
                                  โˆ’s Only allow mouse selection mode.
                                  โˆ’S In window capture mode, capture the screen instead of the window.
                                  โˆ’t <format> Image format to create, default is png (other options include pdf, jpg, tiff and other for- mats).
                                  โˆ’T <seconds> Take the picture after a delay of <seconds>, default is 5. โˆ’w Only allow window selection mode.
                                  โˆ’W Start interaction in window selection mode.
                                  โˆ’x Do not play sounds.
                                  โˆ’a Do not capture attached windows.
                                  โˆ’r Do not add screen dpi meta data to captured file.
                                  files where to save the screen capture, 1 file per screen BUGS
                                  Better documentation is needed for this utility.
                                  SECURITY CONSIDERATIONS
                                  To capture screen content while logged in via ssh, you must launch screencapture in the same mach bootstrap hierarchy as loginwindow:
                                  PID=pid of loginwindow
                                  sudo launchctl bsexec $PID screencapture [options]
                                  HISTORY
                                  A screencapture utility first appeared in Mac OS X v10.2.
                                  Mac OS June 16, 2004 1
                                    driven
                                    ok,
                                    if any ones interested, I can't find a native way of capturing, only the SU window and the current cursor, so I used the QuickTime movie and did screen grabs from it...
                                    my conclusions, is that it's not doable directly with native tools, but a qt movie and then a screen grab from that using grab, screencapture or other is easier...
