    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      Have happy discovery of this amazing plugin! β˜€
      • McGyverM Offline
        McGyver
        I will have lots of fun using this, thanks Pilou!
        The billboards I made looked terrible when rendered in Poser, but the PNGs look okay in SketchUp... So, just in case anyone wants to use them for something in SketchUp, here are the smaller versions I used in SU... They are very simple... it was just for a test, so sorry if they look a little cartoon-like.
        [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
        • OxerO Offline
          Oxer
          Hi McGyver, I have installed the last version 2.1.0 on Mac and the fur-web dialogues are showing correctly the sliders.
          Web Dialogues
          For me the Crowd never has worked on Mac, it creates always a group with little triangles.
          Crowd on Mac
          Mac OSX 10.9.3 & SU2014
            Jorgensen
            First thank you very much for this very nice plugin!
            I'm trying to create a grassfield using the Make Crowd function, but I find the density to low.
            What I do -
            I select the face
            Set the density to max (20)
            Select my grass component
            This generate some instances, but not enough to give the impression of a grassfield.
            Is there a way to rise the density or do I do something wrong?
            Thanks πŸ˜„
              There is no Max! Or in any case more than 20! πŸ˜‰
              Seems numbers of object = Density * 10 so be careful!
                Jorgensen
                hi pilou
                it seems to make no difference if i select a density of 5 or 20, the polygons never get more than 10017.
                i'm properbly do something wrong, but i don't know what πŸ˜•
                  Jorgensen
                  My fault - i set density to high.
                    amos_miers
                    Has anyone experienced the generation of the items heavily in some portions and light in others, following hard diagonal lines dividing the place? I cannot seem to apply the script evenly in most of my spaces. I am using 2014.
                      If they are visible : Cleanup by Thomthom : Merge Coplanar Faces
                      If they are invible, Enable Hidden Geometry : Selection Toys by Thomthom
                      Select Soft or Smooth Edges then kill them
                      • hajkardiH Offline
                        hajkardi
                        I have problem on slope terrain with plugin. I try to change all parameters but no luck?! Some parts of terrain is cover properly, but some have lack of grass. I download last version of plugin 2.1.0 and I have Sketch 2013 pro.
                        http://i.imgur.com/k02tm7X.jpg
                          Ayomidotun
                          Thanks Bro!
                            tak2hata
                            Hi,haikardi.
                            Sorry for my reply too late.
                            I guess the problem is "MaxNumber(/Face)".
                            Please set high value to "MaxNumber(/Face)".
                            "MaxNumber(/Face)" is limit for creating too much fur.
                            by TAK2HATA
                            • soloS Offline
                              I love this plugin, really helps me to distribute grass proxy's. I do have one request, sometimes even the lowest values are too much, I'd really like to distribute (make crowd) with .5, .2 values.
                              Oh!v a distribution brush would also be most welcome.
                              • jiminy-billy-bobJ Offline
                                jiminy-billy-bob
                                What do you mean by that?
                                Something like Components Spray?
                                • V Offline
                                  Vincy_PC
                                  how to install in skp 2014?
                                    Read the first post of this thread.
                                    • V Offline
                                      Vincy_PC
                                      how install in skp 2014
                                      • BoxB Offline
                                        [screenr:27dfvywo]o3nN[/screenr:27dfvywo]
                                          jiminy-billy-bob
                                          how play the video
                                          • cottyC Offline
                                            cotty
                                            play good
                                            my SketchUp gallery
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 32
                                            • 33
                                            • 25 / 33
