    Bug when I add units in the value field[Resolved--not a bug]
    20 Posts 5 Posters 4.3k Views 5 Watching
      driven
      @erom said:
      I changed the preferences mac keyboard language (French keyboard , french numeric keyboard, American english ...) Nothing change.
      did you restart SU after that change?
      what do you get when you paste and enter this into 'Window' >> 'Ruby Console'
      Sketchup.get_locale
      if the keyboard changes have worked for SU, it should return... en-US...
      • E
        erom
        To be more exact, I work with French numeric keyboard .
        I have to type values ​​as [120;200] with ";" as separator.
        My os is maverick.
        Everything works fine as long as I do not type a letter corresponding to a keyboard shortcut.
        If I disable keyboard shortcuts "m" and "c" (Circle and Move) I can use values ​​with units again.
        A temporary solution would be to change the Circle and Move keyboard shortcuts.
        c'est pas un truc juste, c'est juste un truc!
          Is there any chance you're adding a space between the numeric and 'm'?
          • BoxB
            It sounds like you have a conflict between the regional settings of your computer and the version of SU you are using.
            Are you using an English version on a french system? Perhaps it's not locking out the keyboard because it's thinking it's something else. Usually the relevant keys are ignored when in a specific tool but others still jump to a shortcut.
            For example I think if you type 30z when drawing a circle it will jump to zoom, but 30s will change the number of sides as you know. So maybe the fringlish has it confused. I can't test my theory as I'm on my phone at the moment.
            • E
              erom
              Sketchup.get_locale
              I use a french SU version on a a french system with a french keyboard.
              Yes i restart SU after disable the pre-installed extensions and change keyboard pref.
              the ruby console displays this
              [attachment=0:32102rcp]<!-- ia0 -->Capture d’écran 2014-05-11 à 16.28.21.png<!-- ia0 -->[/attachment:32102rcp]
              @dave : I do not add a space between the numeric and 'm'
              @box : yes, type 30z when i draw a circle jump tool to zoom, and i can't enter "s" because it jump to scale tool!
              • BoxB
                If as you mentioned earlier this is a fresh install, I would be uninstalling and trying again.
                It sounds like a problem no one else has and I can't even come close to replicating it.
                A reinstall or even a repair might sort it for you.
                  driven
                  what if you use <shift>C<shift>M
                  does it work then
                    driven
                    @box there is nothing to repair or reinstall on the mac version, it's now a preconfigured drag and drop app...
                    it will be the same every time...
                    removing shortcuts plists, empty trash, then restart...
                    may help
                    356CM [using KEYLOCK] also works here...
                    • E
                      erom
                      @ box. I've uninstalled SU2014 (su + layout + style builder)last week with CleanMyMac2. I then reinstalled. The problem remained.
                      @ driven. "c" or "C" gives the same.
                      thank you for your dedication
                      • E
                        erom
                        Hi folks,
                        since I change my hard drive and reinstall my operating system from a backup, everything came back fine.
                        have a nice day
