    Bug when I add units in the value field[Resolved--not a bug]
    20 Posts 5 Posters 4.2k Views 5 Watching
      driven
      is the label changing, when you use 'Scale', and does it stay like it when you type?
      mine is like this when I type...
      • E
        erom
        I changed the preferences mac keyboard language (French keyboard , french numeric keyboard, American english ...) Nothing change.
        @driven : yes the label change when i move the scale handles. But i don't understand the second part of your sentence. I can not type a double value with scale ❓
        c'est pas un truc juste, c'est juste un truc!
          driven
          sorry, what I mean is the Title looks like that before and as I type my 25cm...
          the two scale factors disappear as I type...
          maybe a better example, is after I type...
          moved with a corner handle, then typed...
          I'm still in the tool...
          it hasn't changed back to Measurements yet...
          once is has [changed back to Measurements], my shortcut keys work...
          are you using a mouse or trackpad?
          anything else you changed?
            driven
            did you restart SU after that change?
            what do you get when you paste and enter this into 'Window' >> 'Ruby Console'
            Sketchup.get_locale
            if the keyboard changes have worked for SU, it should return... en-US...
            • E
              erom
              To be more exact, I work with French numeric keyboard .
              I have to type values ​​as [120;200] with ";" as separator.
              My os is maverick.
              Everything works fine as long as I do not type a letter corresponding to a keyboard shortcut.
              If I disable keyboard shortcuts "m" and "c" (Circle and Move) I can use values ​​with units again.
              A temporary solution would be to change the Circle and Move keyboard shortcuts.
                Is there any chance you're adding a space between the numeric and 'm'?
                • BoxB
                  It sounds like you have a conflict between the regional settings of your computer and the version of SU you are using.
                  Are you using an English version on a french system? Perhaps it's not locking out the keyboard because it's thinking it's something else. Usually the relevant keys are ignored when in a specific tool but others still jump to a shortcut.
                  For example I think if you type 30z when drawing a circle it will jump to zoom, but 30s will change the number of sides as you know. So maybe the fringlish has it confused. I can't test my theory as I'm on my phone at the moment.
                  • E
                    erom
                    Sketchup.get_locale
                    I use a french SU version on a a french system with a french keyboard.
                    Yes i restart SU after disable the pre-installed extensions and change keyboard pref.
                    the ruby console displays this
                    [attachment=0:32102rcp]<!-- ia0 -->Capture d’écran 2014-05-11 à 16.28.21.png<!-- ia0 -->[/attachment:32102rcp]
                    @dave : I do not add a space between the numeric and 'm'
                    @box : yes, type 30z when i draw a circle jump tool to zoom, and i can't enter "s" because it jump to scale tool!
                    • BoxB
                      If as you mentioned earlier this is a fresh install, I would be uninstalling and trying again.
                      It sounds like a problem no one else has and I can't even come close to replicating it.
                      A reinstall or even a repair might sort it for you.
                        driven
                        what if you use <shift>C<shift>M
                        does it work then
                          driven
                          @box there is nothing to repair or reinstall on the mac version, it's now a preconfigured drag and drop app...
                          it will be the same every time...
                          removing shortcuts plists, empty trash, then restart...
                          may help
                          356CM [using KEYLOCK] also works here...
                          • E
                            erom
                            @ box. I've uninstalled SU2014 (su + layout + style builder)last week with CleanMyMac2. I then reinstalled. The problem remained.
                            @ driven. "c" or "C" gives the same.
                            thank you for your dedication
                            • E
                              erom
                              Hi folks,
                              since I change my hard drive and reinstall my operating system from a backup, everything came back fine.
                              have a nice day
