    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.9k Views 109 Watching
      glro
      @fountainhead said:
      I've had some strange behaviour creep in with layers panel recently.
      i have too
      sketchup just freezed when i clicked on "select highlighted layer"
      the plugin would be very useful, but it doesn't seem stable
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Any more detail which could help me identify the issue?
          glro
          nothing much to say
          i had created some scenes previously, and then i launched layers panel plugin to select one layer, and it freezed the computer
          i shall give it another try, and try to atch better the next time i have a bug
          • JQLJ Offline
            JQL
            Hi Jiminy,
            I have another feature request for your layers panel.
            Delete layer's content while keeping layer.
            It's handy in a lot of situations, for me, for instance it's nice so I can delete the content on layers on my template file. It's also good to clean a "trash" layer I have sometimes, where I put a lot of stuff on that trash layer so I can fall back to it later on... I can imagine a lot of useful scenarios like deleting certain layers to share a file by email.
            I hope you'll be able to do it and thanks once again,
            João
            www.casca.pt
            Visit us on facebook!
              jiminy-billy-bob
              I'll add it to my todo list.
              • JQLJ Offline
                JQL
                Thanks Jiminy, that's great!
                www.casca.pt
                • F Offline
                  fountainhead
                  Sorry for the late reply, was away for holidays.
                  OS is Windows 8.1 update 1
                  IE version is 11.0.9600.17239
                  SketchUp 2014 14.1.1282
                  The add layer functionality does not work when the dialogue opens blank.
                  Empty plugins folder, layers panel only, works. So time to start process of elimination, or do you have some well known offenders I could start the weeding out process with?
                    jiminy-billy-bob
                    I have no idea, but you could send me your whole Plugins folder, and I'll investigate when I have time. (In at least two weeks)
                    • danchoD Offline
                      dancho
                      Hi jiminy-billy-bob,
                      I like your plugin but I found some strange thing.
                      There is a differende between content of builn in layer window
                      and your plugin. In the built in there is sometimes more layer
                      than in yours.
                      OS_win7 home prem. x64
                      IE_11.0.9600.17239
                      SU_2014 latest
                      BR.
                      Daniel
                      difference
                      • F Offline
                        fountainhead
                        The offending plugin is eneroth 3D rotate. With associated . rb file removed, no layer loading issues.
                          glro
                          i have strange behaviours with Layers panel, and i use eneroth 3D rotate too...
                          any suggestion to modify one or both plugins to make them work together?
                            jiminy-billy-bob
                            New version 1.2.1 !
                            Changelog :
                            • Fixed a major issue that could corrupt the model (Caused by SU14 and below)
                            • Fixed States dialog
                            • Added API methods
                            Download in the plugin store !
                              glro
                              New version 1.2.1 !
                              Changelog :
                              • Added API methods
                              thank you
                              i give it a try to check if it solves the issues i had
                              when i launch the plugin for the first time in a model made before the installation, an almost empty layers panel window opens, with only one layer, and i get a message "layers panel needs to be fixed"; i click "OK"
                              An html windows pops up, saying no issues are detected...
                              I close the pop up window and the empty layers panel window
                              The next time i open the layers panel window, all layers are shown
                              close the model, open it again ...
                              everything seems to be working fine...
                              no issues detected
                                jiminy-billy-bob
                                This is normal behaviour. It is triggered by the fact that there are existing layers that need to be identified by LP. This is a one-time thing, and won't trigger again (unless there are layers created while LP is disabled).
                                Maybe I should change it to say that issues have been fixed, not only that there are no issues. It may be misleading as is.
                                Do you guys still have issues with Eneroth's Rotate3D? I can't reproduce your errors.
                                  glro
                                  yes, maybe the message is not totaly accurate ; there is no problem;it is just that the existing layers must be registered by layers panel plugin
                                  somebody suggested that there was a conflict between Eneroth's Rotate 3D and your plugin, but gave no evidence; so i don't know about it; i shall be using layers panel in the coming daus, and i also run Rotate 3D code, so if i notice something wrong, i shall report it
                                    glro
                                    I have been using your "layers panel.rb" for 2 or 3 days, it worked fine
                                    but today, it proved to be not compatible with a plugin containing rotate3D code
                                    i am not skilled enough to say why, but it seems to confirm there is a problem...
                                    too bad, it improves a lot the sketchup native layers panel
                                      jiminy-billy-bob
                                      Did you get an error message?
                                      What happened exactly?
                                        glro
                                        sketchup stopped suddenly, and that was it
                                        bugsplat
                                        i tried to remove some newly installed extensions, and this way i found out that "Layers panel" was involved
                                        I can't write more since i don't understand what's happening; your plugin might be perfect; i just know that if i remove it, i don't have the problem
                                        • tt_suT Offline
                                          tt_su
                                          Did you submit that BugSplat? Did you enter any info in the Description or Name field we can use to look it up by?
                                            glro
                                            No
                                            but if you think it might help, i shall
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 34 / 34
