    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 276.9k Views 110 Watching
    • F Offline
      fountainhead
      I've had some strange behaviour creep in with layers panel recently. At least once a day, possibly more, the layers dialogue ends up blank, with no layers showing at all. When I chose the recent history dialogue, only one of multiple layers is restored. The only solution for me is to close Sketchup, remove both the jbb_layers_panel folder, and the jbb_layers_panel.rb, then reload Sketchup, and reinstall the .rbz file. Once that is done, all of the layers show up again...until the next sudden disappearance. I need to point out that the layers don't disappear from an .skp file that is currently open, only when opening an existing .skp file initially. The behaviour also repeats itself with the same .skp file over and over. In the last 3 days, I have had to unload/reload layers panel on the same .skp file on 4 separate file opening occasions. Any ideas?
      • F Offline
        fountainhead
        A little more information. Opened an skp file this morning, no layers. Unloaded and re-loaded layers panel, all good. Opened a second, different skp file, no layers in that one, then I decided to open the previous skp file, directly from the open skp file. Since the previous file was open on the desktop, Sketchup warned me "file is open, open read only blah blah", as soon is a picked no, to cancel the load of the previous file, boom, all of the layers in 'layers panel' loaded up in the currently open file, where they, just seconds ago, were unavailable.
        Not sure if that helps figure out what could be going on.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          • Are you running on windows or MAC?
          • If windows, what's your Internet Explorer version?
          • What's your Sketchup version?
          • When the dialog is blank, are you able to use its buttons? For exemple, does the "Add layer" button adds a new layer in Sketchup's layers window?
          • Could you try with all other plugins disabled? (Rename the plugins folder to "Plugins2", and create a new "Plugins" folder with only Layers Panel files in it)
          (Please answer all questions, thanks)
            glro
            i have too
            sketchup just freezed when i clicked on "select highlighted layer"
            the plugin would be very useful, but it doesn't seem stable
              jiminy-billy-bob
              Any more detail which could help me identify the issue?
                glro
                nothing much to say
                i had created some scenes previously, and then i launched layers panel plugin to select one layer, and it freezed the computer
                i shall give it another try, and try to atch better the next time i have a bug
                • JQLJ Offline
                  JQL
                  Hi Jiminy,
                  I have another feature request for your layers panel.
                  Delete layer's content while keeping layer.
                  It's handy in a lot of situations, for me, for instance it's nice so I can delete the content on layers on my template file. It's also good to clean a "trash" layer I have sometimes, where I put a lot of stuff on that trash layer so I can fall back to it later on... I can imagine a lot of useful scenarios like deleting certain layers to share a file by email.
                  I hope you'll be able to do it and thanks once again,
                  João
                  www.casca.pt
                  Visit us on facebook!
                    jiminy-billy-bob
                    I'll add it to my todo list.
                    • JQLJ Offline
                      JQL
                      Thanks Jiminy, that's great!
                      www.casca.pt
                      • F Offline
                        fountainhead
                        Sorry for the late reply, was away for holidays.
                        OS is Windows 8.1 update 1
                        IE version is 11.0.9600.17239
                        SketchUp 2014 14.1.1282
                        The add layer functionality does not work when the dialogue opens blank.
                        Empty plugins folder, layers panel only, works. So time to start process of elimination, or do you have some well known offenders I could start the weeding out process with?
                          jiminy-billy-bob
                          I have no idea, but you could send me your whole Plugins folder, and I'll investigate when I have time. (In at least two weeks)
                          • danchoD Offline
                            dancho
                            Hi jiminy-billy-bob,
                            I like your plugin but I found some strange thing.
                            There is a differende between content of builn in layer window
                            and your plugin. In the built in there is sometimes more layer
                            than in yours.
                            OS_win7 home prem. x64
                            IE_11.0.9600.17239
                            SU_2014 latest
                            BR.
                            Daniel
                            difference
                            • F Offline
                              fountainhead
                              The offending plugin is eneroth 3D rotate. With associated . rb file removed, no layer loading issues.
                                glro
                                i have strange behaviours with Layers panel, and i use eneroth 3D rotate too...
                                any suggestion to modify one or both plugins to make them work together?
                                  jiminy-billy-bob
                                  New version 1.2.1 !
                                  Changelog :
                                  • Fixed a major issue that could corrupt the model (Caused by SU14 and below)
                                  • Fixed States dialog
                                  • Added API methods
                                  Download in the plugin store !
                                    glro
                                    New version 1.2.1 !
                                    Changelog :
                                    • Added API methods
                                    thank you
                                    i give it a try to check if it solves the issues i had
                                    when i launch the plugin for the first time in a model made before the installation, an almost empty layers panel window opens, with only one layer, and i get a message "layers panel needs to be fixed"; i click "OK"
                                    An html windows pops up, saying no issues are detected...
                                    I close the pop up window and the empty layers panel window
                                    The next time i open the layers panel window, all layers are shown
                                    close the model, open it again ...
                                    everything seems to be working fine...
                                    no issues detected
                                      jiminy-billy-bob
                                      This is normal behaviour. It is triggered by the fact that there are existing layers that need to be identified by LP. This is a one-time thing, and won't trigger again (unless there are layers created while LP is disabled).
                                      Maybe I should change it to say that issues have been fixed, not only that there are no issues. It may be misleading as is.
                                      Do you guys still have issues with Eneroth's Rotate3D? I can't reproduce your errors.
                                        glro
                                        yes, maybe the message is not totaly accurate ; there is no problem;it is just that the existing layers must be registered by layers panel plugin
                                        somebody suggested that there was a conflict between Eneroth's Rotate 3D and your plugin, but gave no evidence; so i don't know about it; i shall be using layers panel in the coming daus, and i also run Rotate 3D code, so if i notice something wrong, i shall report it
                                          glro
                                          I have been using your "layers panel.rb" for 2 or 3 days, it worked fine
                                          but today, it proved to be not compatible with a plugin containing rotate3D code
                                          i am not skilled enough to say why, but it seems to confirm there is a problem...
                                          too bad, it improves a lot the sketchup native layers panel
                                            jiminy-billy-bob
                                            Did you get an error message?
                                            What happened exactly?
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
