    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 183.0k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Great, I'm glad it works.
      Maybe you tried just after installing the plugin, before restarting SU?
        jiminy-billy-bob
        Thanks for the donation, glro, I appreciate it! 😉
        • F Offline
          fountainhead
          I've had some strange behaviour creep in with layers panel recently. At least once a day, possibly more, the layers dialogue ends up blank, with no layers showing at all. When I chose the recent history dialogue, only one of multiple layers is restored. The only solution for me is to close Sketchup, remove both the jbb_layers_panel folder, and the jbb_layers_panel.rb, then reload Sketchup, and reinstall the .rbz file. Once that is done, all of the layers show up again...until the next sudden disappearance. I need to point out that the layers don't disappear from an .skp file that is currently open, only when opening an existing .skp file initially. The behaviour also repeats itself with the same .skp file over and over. In the last 3 days, I have had to unload/reload layers panel on the same .skp file on 4 separate file opening occasions. Any ideas?
          • F Offline
            fountainhead
            A little more information. Opened an skp file this morning, no layers. Unloaded and re-loaded layers panel, all good. Opened a second, different skp file, no layers in that one, then I decided to open the previous skp file, directly from the open skp file. Since the previous file was open on the desktop, Sketchup warned me "file is open, open read only blah blah", as soon is a picked no, to cancel the load of the previous file, boom, all of the layers in 'layers panel' loaded up in the currently open file, where they, just seconds ago, were unavailable.
            Not sure if that helps figure out what could be going on.
              jiminy-billy-bob
              • Are you running on windows or MAC?
              • If windows, what's your Internet Explorer version?
              • What's your Sketchup version?
              • When the dialog is blank, are you able to use its buttons? For exemple, does the "Add layer" button adds a new layer in Sketchup's layers window?
              • Could you try with all other plugins disabled? (Rename the plugins folder to "Plugins2", and create a new "Plugins" folder with only Layers Panel files in it)
              (Please answer all questions, thanks)
                glro
                i have too
                sketchup just freezed when i clicked on "select highlighted layer"
                the plugin would be very useful, but it doesn't seem stable
                  jiminy-billy-bob
                  Any more detail which could help me identify the issue?
                    glro
                    nothing much to say
                    i had created some scenes previously, and then i launched layers panel plugin to select one layer, and it freezed the computer
                    i shall give it another try, and try to atch better the next time i have a bug
                    • JQLJ Offline
                      JQL
                      Hi Jiminy,
                      I have another feature request for your layers panel.
                      Delete layer's content while keeping layer.
                      It's handy in a lot of situations, for me, for instance it's nice so I can delete the content on layers on my template file. It's also good to clean a "trash" layer I have sometimes, where I put a lot of stuff on that trash layer so I can fall back to it later on... I can imagine a lot of useful scenarios like deleting certain layers to share a file by email.
                      I hope you'll be able to do it and thanks once again,
                      João
                      www.casca.pt
                      Visit us on facebook!
                        jiminy-billy-bob
                        I'll add it to my todo list.
                        • JQLJ Offline
                          JQL
                          Thanks Jiminy, that's great!
                          www.casca.pt
                          • F Offline
                            fountainhead
                            Sorry for the late reply, was away for holidays.
                            OS is Windows 8.1 update 1
                            IE version is 11.0.9600.17239
                            SketchUp 2014 14.1.1282
                            The add layer functionality does not work when the dialogue opens blank.
                            Empty plugins folder, layers panel only, works. So time to start process of elimination, or do you have some well known offenders I could start the weeding out process with?
                              jiminy-billy-bob
                              I have no idea, but you could send me your whole Plugins folder, and I'll investigate when I have time. (In at least two weeks)
                              • danchoD Offline
                                dancho
                                Hi jiminy-billy-bob,
                                I like your plugin but I found some strange thing.
                                There is a differende between content of builn in layer window
                                and your plugin. In the built in there is sometimes more layer
                                than in yours.
                                OS_win7 home prem. x64
                                IE_11.0.9600.17239
                                SU_2014 latest
                                BR.
                                Daniel
                                difference
                                • F Offline
                                  fountainhead
                                  The offending plugin is eneroth 3D rotate. With associated . rb file removed, no layer loading issues.
                                    glro
                                    i have strange behaviours with Layers panel, and i use eneroth 3D rotate too...
                                    any suggestion to modify one or both plugins to make them work together?
                                      jiminy-billy-bob
                                      New version 1.2.1 !
                                      Changelog :
                                      • Fixed a major issue that could corrupt the model (Caused by SU14 and below)
                                      • Fixed States dialog
                                      • Added API methods
                                      Download in the plugin store !
                                        glro
                                        New version 1.2.1 !
                                        Changelog :
                                        • Added API methods
                                        thank you
                                        i give it a try to check if it solves the issues i had
                                        when i launch the plugin for the first time in a model made before the installation, an almost empty layers panel window opens, with only one layer, and i get a message "layers panel needs to be fixed"; i click "OK"
                                        An html windows pops up, saying no issues are detected...
                                        I close the pop up window and the empty layers panel window
                                        The next time i open the layers panel window, all layers are shown
                                        close the model, open it again ...
                                        everything seems to be working fine...
                                        no issues detected
                                          jiminy-billy-bob
                                          This is normal behaviour. It is triggered by the fact that there are existing layers that need to be identified by LP. This is a one-time thing, and won't trigger again (unless there are layers created while LP is disabled).
                                          Maybe I should change it to say that issues have been fixed, not only that there are no issues. It may be misleading as is.
                                          Do you guys still have issues with Eneroth's Rotate3D? I can't reproduce your errors.
                                            glro
                                            yes, maybe the message is not totaly accurate ; there is no problem;it is just that the existing layers must be registered by layers panel plugin
                                            somebody suggested that there was a conflict between Eneroth's Rotate 3D and your plugin, but gave no evidence; so i don't know about it; i shall be using layers panel in the coming daus, and i also run Rotate 3D code, so if i notice something wrong, i shall report it
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
