    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 48.9k Views 24 Watching
    • EdsonE Offline
      Edson
      as an early buyer who complained about the lack of tutorials and guides it is only fair that I come here to say that the Skalp people have been posting very instructive short videos and in large number, covering many aspects of the plugin. at this rate, they will surely cover all of it.
      besides, the latest user guide is superb in that it covers in detail all the features and tells us things that are not (yet?) in the videos.
      skalp is a hugely useful plugin and is worth every cent you pay for it.
      http://www.mahfuz.arq.br
      • SkalpS Offline
        Skalp
        Thank you Edson. We appreciate this comment very hard.
        More videos tutorials will follow daily until we cover every aspect of Skalp.
        Skalp for SketchUp Video Tutorials
        We continue to work hard to make Skalp even beter. We just made a breakthrough in sectioning non-solids in SketchUp! Watch out to the upcoming betas...
        We develop Skalp full-time with 2 people. It's our goal to make it the best section plugin there is.
        The Skalp Team.
        Skalp
        http://www.skalp4sketchup.com
        • EdsonE Offline
          Edson
          you are welcome and deserving of this praise.
          a lengthy tutorial on the advanced use you describe from page 25 of the user guide would be very appreciated. everyone using Skalp professionally would thank you for that.
          best regards.
          • SkalpS Offline
            Skalp
            best regards.
            Edson,
            It's my own favorite way of working which we use must of the time in our architectural office. Special for you I will make my next Video Tutorial on this advanced way of working.
            The Skalp Team.
            Skalp
            • EdsonE Offline
              Edson
              Great!
              • SkalpS Offline
                Skalp
                On special request a Video Tutorial about Skalp Pattern Layers (color by layer).
                Skalp Pattern Layers uses an undocumented feature of Color by Layer in combination with the hidden line render mode to create an architectural section with everything white in the model except the section.
                Skalp
                • EdsonE Offline
                  Edson
                  very good! I know this was explained in the user guide but seeing you do it completes the information.
                  if I may suggest another topic for a video, how about one on how to save skalp settings to a sketchup template?
                  regards.
                  • SkalpS Offline
                    Skalp
                    regards.
                    Edson,
                    After you setup a full Skalp model you can delete all entities, except the section planes and save it in a standard sketchup template.
                    The Skalp Team.
                    Skalp
                    • EdsonE Offline
                      Edson
                      regards.
                      Edson,
                      The Skalp Team.
                      so the template will have a couple of section planes that section nothing? like ghost section planes? how does one deal with those section planes in a new model?
                      • SkalpS Offline
                        Skalp
                        @edson said:
                        regards.
                        Edson,
                        The Skalp Team.
                        Edson,
                        From the moment you model something and the section plane intersect with the new model it will section the model. You can easy activate the different sections from the dialog box even if they don't section elements.
                        The Skalp Team.
                        Skalp
                        • jiminy-billy-bobJ Offline
                          jiminy-billy-bob
                          I see in your video that you add a bunch of layers. I guess you can get to high numbers of layers if you have a lot of different section patterns?
                          Maybe you could make your plugin work with Layers Panel, to automatically put all those layers in a layer group, and automatically collapse it so that they don't take much space in the dialog.
                          You can use LP's API for that : http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=57777
                          • SkalpS Offline
                            Skalp
                            Thank,
                            Sounds like a good idea and we will look at it.
                            The Skalp Team.
                            Skalp
                              jiminy-billy-bob
                              @skalp said:
                              Thank,
                              The Skalp Team.
                              I just realised I haven't added the "collapse_group" method, yet. I'll add it in the next version. And I broke "nest_into" like an idiot by renaming some methods in v1.2.0. So the below code is designed to run on version higher than v1.2.0, sorry about that.
                              You can do something like this in SU2014 (Skalp only works in 2014, right?):
                              <span class="syntaxdefault">begin </span><span class="syntaxcomment">#In a rescue block so that it will silently not run if Layers Panel is not installed<br /></span><span class="syntaxdefault">    if Gem</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Version</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">JBB_LayersPanel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">version</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> Gem</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Version</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'1.2.0'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> <br />        groupID </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> JBB_LayersPanel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Skalp"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        skalp_layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">layer</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">            layerID </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> JBB_LayersPanel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_layerID</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">layer</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">            JBB_LayersPanel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nest_into</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">layerID</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> groupID</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">        JBB_LayersPanel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">collapse_group</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">groupID</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end</span><span class="syntaxcomment">#if<br /></span><span class="syntaxdefault">rescue<br />end</span>
                              • EdsonE Offline
                                Edson
                                after realising how this method works I immediately thought of creating a group for the Skalp layers in LP. if this can be made automatically so much the better.
                                  bsfranza
                                  hey guys - what about the demo?
                                  i would love to try and see for myself how your product is keeping up=)
                                  • KrisidiousK Offline
                                    Krisidious
                                    Skalp only works in 2014?
                                    By: Kristoff Rand
                                    • SkalpS Offline
                                      Skalp
                                      Yes Skalp only works in SketchUp 2014 Make or Pro.
                                      Skalp
                                      • O Offline
                                        otb designworks
                                        Wow, this plugin looks excellentI do have a quick question about how Skalp works in layout, though, before I think about buying it.
                                        For Skalp to be really useful for me, I would need it's sections to be recognized by the inference engine in Layout, so I could pull dimensions from the section cuts. I have been assuming that the Skalp sections don't work like that in Layout, but I didn't really start investigating this until yesterday and I couldn't find an answer on the website.
                                        Could someone explain how these sections could be used in Layout, other than for just visualization?
                                        Cheers, Chuck
                                        OTB Designworks is on Youtube
                                        • O Offline
                                          otb designworks
                                          Well that is pretty flipping awesome.
                                          I'm buying this right now and will report back! Thanks for taking the time to make the demo vid.
                                          Cheers, Chuck
                                          • SkalpS Offline
                                            Skalp
                                            Chuck,
                                            The Skalp section is standard SketchUp geometry. Using the inference engine in Layout is no problem at all. I made a little video to illustrate.
                                            The Skalp Team.
                                            Skalp
                                            • 2 / 9
