    Masking entities drawn in layout
    layout
    5 Posts 3 Posters 943 Views 3 Watching
      Bruce Watt
      Hello,
      I have drawn some entities in layout over my inserted skup model to show gas/ electric/ foul runs etc. I would now like to make the same drawing but have the scale larger, I do this by adjusting the sketchup model and scaling the entities accordingly. I group entities and model together, alls good up to now. I would now like to mask out the part of the enlarged drawing that go over the page size. I can mask inserted drawings and pictures but can not mask out the entities drawn in Layout. So my question is, Is there a way to mask out grouped entities drawn in Layout? I hope the attached will explain more.
      Mask
      SKUP PRO 2021 latest version / update
      Windows 10 Pro
      Dell Alienware Aurora R10 AMD
      AMD Ryzen™ 9 3900X
      NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
        If I understand correctly, you want to mask the red lines that extend out side of the border. When I have need to mask things that way I draw a rectangle or other shape making sure it is in front of the lines to be masked. I set the fill to white and turn off strokes so there's no edge on the shape.
        Alternatively, you could just cut those lines at the border with the knife tool and erase what you don't need.
          By the way, if you are going to run things out to the border like that, you might find it useful to put the border on a layer first in the list so the border is automatically over everything else. then your red lines and the masking shapes will run under the border. It's a lot easier than masking right up to but not overlapping the border.
            Bruce Watt
            Thanks Dave,
            I did think that would the answer. It would be nice if mask did work on grouped entities draw in Layout, perhaps next version!
            Thanks again for your super quick response.
            Windows 10 Pro
            AMD Ryzen™ 9 3900X
            • RichardR Offline
              Richard
              Dave is NUMBER ONE!!! when it comes to quick (and accurate) responses! If we could grant medals to sketchucation contributors, he's top of my list!
              [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
