    [REQ] copy paste camera
    10 Posts 6 Posters 559 Views 6 Watching
    • soloS Offline
      I'm in need of a way to copy a scene/camera in one instance of SU and open another instance and paste it.
      All I need is the camera location in the least however if the shadow/sun info can also be copied it would be a bonus.
      Anything like this available or possible to achieve?
      • sdmitchS Offline
        sdmitch
        Have you seen this
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=47385%26amp;p=526201%26amp;hilit=camera#p423805
        http://sdmitch.blogspot.com/
        • soloS Offline
          @sdmitch said:
          Have you seen this
          I have it installed and it seems to export cameras but not import them.
          Thus a simple right click from one scene and paste in a new instance would be nice if possible. The thing is I need to set up over 200 scenes for separate products which makes a copy paste method so much more convenient if possible.
          • fredo6F Offline
            Solo,
            You could try the Camera Memory by Eneroth3. Simple but terribly efficient. It is in the PluginStore.
            http://sketchucation.com/pluginstore?pln=ene_camMemory_v1.0.0
            • soloS Offline
              @fredo6 said:
              Solo,
              ๐Ÿ‘
              Awesome, just what I needed.
              Thanks.
              • fredo6F Offline
                Solo,
                By the way, it is possible to build a plugin that would take the scenes from one skp model and transfer them to another skp. This may be easier if you have 200 views! Maybe this has been done already.
                  Rick Wilson has something at Smustard.com [$5?] BUT I think that always uses inches...
                  [But I use my own 'fixed' version]
                  http://www.smustard.com/script/PageExIm
                  BUT 'inches' might not be an issue for you US-dino's ?
                  • soloS Offline
                    @fredo6 said:
                    Solo,
                    Actually all the models are separate skp's so I want to render them all from the same view, so it is not 200 views, 200 models with one view needed, your last suggestion works like a gem as it's fast.
                    • tt_suT Offline
                      tt_su
                      You can use Advanced Camera tools to copy and paste cameras.
                      • Dan RathbunD Offline
                        Dan Rathbun
                        @solo said:
                        Actually all the models are separate skp's so I want to render them all from the same view, ...
                        Actually the correct protocol would be to create a template skp with the desired view.
                        Then use that template to create the model skps.
                        I'm not here much anymore.
