    [plugin] realSection v0.6 Béta (Updated 9/8/2014)
    87 Posts 37 Posters 68.6k Views 37 Watching
      amores
      Any time i wont select Define realSectionmaterial a window apear sing real section is expired.
      Can someone help me?
      • EdsonE Offline
        Edson
        perhaps we should remove from the index any plugins that are no longer functional. this one has not been working for anyone and the author seems to have deserted the forum.
        http://www.mahfuz.arq.br
        • jim smithJ Offline
          jim smith
          Is there anyone on the forum living in or near Antwerp that could knock on his door? I have e-mailed him several times with no response. He has an active web page. I got this info from the web easy enough
          Architectuurburo Wydouw
          Address : Hoevensebaan 238, 2950 Kapellen
          Phone:
          033279567
          http://www.wydouw.be
          I hope he is okay and hope he could either unlock the plug-in as is, give us an update or put a price tag on it. This was very useful. There is at least one other similar plugin around, but I found this one easy to use and worth having.
          "Out of clutter find simplicity,
          from discord find harmony,
          In the middle of difficulty lies opportunity"
          Albert Einstein
            GWD
            At this moment realsection is only working at our own office and we don't have the time to make a public version of it. But I will try to build a new public version in a couple of weeks.
            Regards,
            Guy.
              jim smith
              Thank you Guy,
              sorry to seem to be a pest, but you have quite a few fans that miss your good work!
              Albert Einstein
                GWD
                Thanks. I try do it as quick as possible. The problem is that the plugin we use at our office can't be used by others because there are a lot of hardcoded things in it and I need to do a special cleanup of the code to send it outside.
                • H Offline
                  Hansatle
                  Does it work with Mac?
                  • H Offline
                    hotice123
                    thank you~~
                      siusanglai
                      its a nice and very useful plugin.
                      But it not work in my sketchup 2013. even it can show the SECTION MATERIALS box on right click!!??
                      thanks for reply.
                      • SkalpS Offline
                        Skalp
                        realSection is become a commercial product called Skalp for SketchUp
                        The Skalp Team
                        Skalp
                        http://www.skalp4sketchup.com
                          tonywilton
                          I remember having this working at one time but it just creates an error now, referring to the helper file.
                          Error Loading File toggleWindows.rb
                          Error: #<NameError: uninitialized constant PLATFORM>
                          C:/Users/tonywilton/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/toggleWindows.rb:4:in `<top (required)>'
                          Any clues would be gratefully received.
                          I want to be able to define section material by group. Real section did just that.
                          Scalp is much more than I need.
                            GWD
                            Indeed Skalp can do a lot more, but if you like you can use Skalp just the same simple way like Real Section and define the materials by group. Take a look at the following video tutorial to see how it works:
                            Skalp for SketchUp
                              Simorgh
                              Thank you for the plugin.
                              After almost an hour of trying different things, I realized this plugin wont work on a Mac machine, am I right?
                              It would be great if it did.
                              Anyways, thank you for the plugin.
                              Maybe I can purchase Skalp in the future, but for 100 bucks Canadian, a bit to pricey.
                                GWD
                                realSection isn't supported anymore.
                                • 5 / 5
