    Skalp for SketchUp: Holiday Sale 25% off (until August 10)
    8 Posts 3 Posters 1.4k Views 3 Watching
    • SkalpS Offline
      Skalp
      Skalp Holiday Sale. Get 25% off until August 10, with the following coupon code HOLIDAY
      Skalp has been designed and built as an easy to use yet powerful Live Section Tool. It represents the key missing features needed to realize a long standing dream: Create your stunning plans and elevations inside SketchUp.
      The Skalp development Team has its roots in architecture and 3D software, but that doesn't mean Skalp is for architects or Pro users only. SketchUp is being used in so many disciplines nowadays. Which is why we intended Skalp to be as 'generic' as possible. This means we do not want to change or disrupt your specific workflow.
      We feel Skalp should just try to respect whatever and however you're doing in SketchUp and simply boost your ability to create superb drawings.
      [highlight=#4080bf:3s3gf17q]Buy Skalp for SketchUp[sup:3s3gf17q[/sup:3s3gf17q]][/highlight:3s3gf17q]
      Introduction Movie:
      [flash 640,360:3s3gf17q]http://youtube.com/v/5WKKWbm5cg8[/flash:3s3gf17q]
      The Skalp Team
      Skalp
      http://www.skalp4sketchup.com
      • sfto1S Offline
        sfto1
        Are you going to offer the first non-beta release to beta purchasers for no charge?
        • pbacotP Offline
          In some posts you mention elevations. What features does Skalp have to help in making elevations? The poor control of lineweight in LO is my main concern. The edges needed for good models are often counter to the sort of clarity and emphasis needed in elevations.
          • SkalpS Offline
            Skalp
            Maybe we should place this a little bit more clearly, but you can read in our disclaimer:
            Ordering this beta entitles you to all 1.x updates.
            Of course you get the final version, and all 1.x updates for free if you buy today. The price of the final version will be higher than the beta version.So there is no reason to wait until tomorrow!
            The Skalp Team
            Skalp
            • sfto1S Offline
              sfto1
              Thanks for the reply. I will give it serious consideration.
              • SkalpS Offline
                Skalp
                We mention elevation, because you can use the Skalp patterns created with the Skalp Pattern Designer very easy also in elevation. The Skalp Pattern Designer generates tileable textures from autocad pattern files. This textures (patterns) can be used in the section or like a normal SketchUp material to be painted on the faces.
                The Skalp Team
                Skalp
                • pbacotP Offline
                  Thanks! That would be nice. How about is there a way to make custom hatches if you don't own AutoCAD? Your list in the post says "build your own from scratch", so I suppose it is somehow supported within the plugin and SketchUp.
                  • SkalpS Offline
                    Skalp
                    The net is full of pat files that you can use. In version 1.0 you can edit the size, line color, fill color and lineweight. A full pat builder will come in version 1.1 (free update)
                    The Skalp Team
                    Skalp
