[Plugin] Eneroth Railroad System (v 0.1.21)
@box said:
A fantastic plugin, but it does have something that bothers me. I like to use a limited number of toolbars and only open them up when I need them. Your toolbar, no matter which way you close it, will always reopen on startup unless you have actually disabled the plugin. Could you look at removing this behavior.
The plugin should run toolbar.restore within a 0 timer t avoid some bug (apparently called 2902434) but for some reason my code uses .show instead
. It'll be fixed for the next release but you can manually change it an line 1248 in main.rb now if you want to. I think this was the solution for a bug in SU 8 which doesn't support the plugin so it's probably not needed at all.
Thanks, it was only a tiny thing in an otherwise superb plugin.
WELCOME BACK <joke> JCE (sound like jaycey)</joke> Eneroth3.
i have find some bugs and eastereggs in your plugin.
more about this via PM.
dean
@eneroth3 said:
By 'Translate camera', do you mean moving the camera relative to the train but without rotating and by 'Rotate around selection' the current behavior?
Hi Christina,
Easier to explain with sample. Here are some functions I used, to be called at each frame.
Feel free to integrate/customize/mix as you want within your plugin.Here is the ruby file:
camera_animation.rbAnd samples:
rotate around
target
follow
Pascal
So, you created the animations in your videos with your own animation script?
Have you published it anywhere other in that comment here? GitHub? -
Yes for the cameras, not for the trains that are moved by Christina's Railroad plugin.
No. Its only few lines of code, that could/should be optimized... and adapted to custom needs. If any of the good developers that are here wants to improve it to make a more complete library it may be great...
In fact I think those features are really missing to SU. -
I'd encourage GitHub to publish code where you invite collaboration and enhancements from the community.
I have just downloaded the Railroad plugin, but there are no selections in the "Add Track" box. Is there a link to other components?
Pascal: The animations look great and I really like the 0.95 ratio thing to make it smoother. It looks just as filmed with a real stadicam. I think this library could grow and be used for much more than the train simulator. I agree with Thomthom about putting it on Github for more people to work on, then I can also add a link to it from the documentation of my plugin
That's really odd. What Sketchup version are you using? 2013+ is needed.
I'm having the same problem. I use SU 2013 and 2014 and in neither of them can I place track in a new drawing. When I open your example drawing however I am able to place track - it is as if a library was not loading but perhaps is already loaded in the example drawing.
Also in SU 2013 I get a script error - see attached photo. I'm using your latest version 1.13 I think dated the 9th of this month.
thanks though for this awesome plugin! I am really impressed and can't wait to place a train track throughout some new building model I want to show off to a customer!
Jon
Jon
Hi Jon
This sounds very similar to an error on Mac that's one user has reported but that didn't occur for others. Can you add this code "puts js" to line 376 in track_insert_tool.rb and post the text printed in the console?
Here an intresting links:
for all ENE-RR-Fans ( eneroth3railroad)
http://gritton.org/greg/rail/docs/clearance/
http://gritton.org/greg/rail/docs/clearance/AAR_plates_with_UIC.gif
this is a svg file UIC & AAR clearance.
for all non railroader.
this is the room that need the train without crash with other objects along and alongside the Track ( /bridge/tunnel/catenary/signals/and other trains.)
http://en.wikipedia.org/wiki/Loading_gauge
for more search results: insert in google
aar clearance (american) AND/OR uic clearance (european+br)
----here a way to go to a simulator (sketchup to trainz(auran.com))
sometimes i work/play with this, too.
AND
railworks (Trainsimulator 2012/2013/2014/2015)
Dovetail Games
Dovetail Games. 21,466 followers · 6 talking about this. By Enthusiasts, For Enthusiasts Developer of Train Sim World, Train Simulator Classic and Metro...
(www.facebook.com)
sorry not a sketchup plugin avaiable only for blender/3dsmax.
and here my historical project for this games.sorry german language however with pictures.
this is not an egoshooter!!!
dean
(loco driver student/retired)all parts was build with original blueprints!!!
@eneroth3 said:
Hi Jon
Julia,
see attached screenshots.
In the ruby console what you see is left from me running some other plugin - so you can see the console is working. Actually, none of your tools writes anything to the console. You can see I've started the track tool here and nothing shows - except the script error dialog.
The other screenshot is showing where I put the "puts.js"
Another strange thing - while I was looking for track_insert_tool.rb I noticed there was only an instance of this file in the Program files etc SU 2013 Plugins folder, not in the SU 2014 folder. Is the plugin not compatible with 2014 or am I looking in the wrong place? I looked under ProgramData as well and searched c:\
Maybe the install process did not work properly?
thanks
Jon
Jon,
Sorry, I gave you the wrong line number because I've added more code above it in my local copy. The code needs to be on line 393 and without quotes:
puts jsI've never installed a plugin from the Pluginstore so I don't know if it puts the files in the wrong location, however if it does the plugin shouldn't open at all.
It seems like something goes wrong when creating the javascript that is later executed in the web dialog so I'd like to know what code is executed (the variable named js). I really have no idea how this can work in my example model but not in new models. That is really odd.
Dean,
These links are quite inspiring. I've actually drawn 2 structural gauges (European ones) as rolling stocks included in the plugin that can be used to test tracks.
Do you know any online resources for original drawings?
@eneroth3 said:
Dean,
Yes i know, however your audience / targed group is bigger.
i think you will that all continents of the world know your plugin.Trainz is an australian game with routs in AUS,USA,GBR,SWE,GER,FRA,RUS etc.
the Game TS 2014 (2015) have routs in USA GBR,;FRA,CHN and in the next version YPN,too.yes i know some. however only open blueprints.
you must know that blueprints of the GERMAN ICE is not opensource and normally you must pay a license when you show the ICE in your plugin.
i think the best way is to contact DB Deutsche Bahn and ask.
you must tell, that your project isn´t commercial and you will show kids how i build my railroad in 3d.
AND you and the kids love the ICE.
the same you must write to the british railway etc. this sound in the ears better when you doining somethings with passion and love.
you must know that i was loco driver student and this was very difficult to become any pages in pdf etc.
i would would therefore recommend that you contact any users in the rail-sim.de forum or in the main auran forum.
you can find there a woman ( Sandra-Marion/rail-sim.de). when you need support for a german translation for letters and contact i could help you...however you must do it by your self.
i dont know what you need.normally the first address for me is the 3d warehouse than safe all side views with measures as pictures and build your loco,airplain,ship or what ever.
some designer for games that give away freeware parts you could contact,too.
here i could help in german language,too.
however some designers could tell you, freeware is not free..you can this use for free in the game, its strictly forbidden to recompile etc.
you must know, that i have 2-3 years to investigate,research for the BerlinWallProject.
i have contacted Soldiers of the EAST GERMAN BORDER PATROLS to become any background knowhow about this.
ok this is and was a very sad political theme/topic.normally, a Berlin People don´t search contact to the soldiers of the(Grenztruppen ( East German Border Patrol).
my target was, all kids must see and know what is it the Wall, what feeling before and behind the wall etc.ok i could visuallize a LIMES, however i cant ask a roman soldier about this
i have contacted the producer of the movie Walled-in (Art-Com)
every time when i see this movie, it´s like the same under a very cold water shower or rolling icecubes over my back.
blueprints for buildings you must visit libraries or museums about architecture.
the mother of all locos "The Rocket" you could find in Nurmberg (Germany) and in England
ok when you have more questions you could ask.
do you know the innotrans in Berlin?
in september 23-26 you can see the newest locos
i will pay a ticket in the next month.
when you will come to berlin with your boyfriend or girlfriend etc. i could ask the owner off my appartment. he have appartmats for visitors, not so expansive like a hotel, i hope. otherwise we have many hotels/hostels and motels.
ok cu
dean
@eneroth3 said:
Jon,
... I really have no idea how this can work in my example model but not in new models. That is really odd.
Christina don´t be shy and ask the big T´s and F´s (TIG/Thomas/Fredo etc.)
if you stay in the rain i would say, all will have a umbrella for you. i mean, nobody would tell you, "that your plugin...help your self"
the first step you must doing your self, politly request help is a good idea. what i say/tell you..this you know by your self.
regards dean
p.s. i´ll hope this will not sound like teacher or a a talk between father and daughter
my slogan is:
To laugh often and much,
to win the respect of intelligent people
and the affection of children,
to earn the appreciation of honest critics
and endure the betrayal of false friends,
to appreciate beauty, to find the best in others,
to leave the world a bit better,
whether by a healthy child,
a garden patch, or a redeemed social condition;
to know even one life has breathed easier because
you have lived.This is to have succeeded!
@eneroth3 said:
Jon,
Julia,
I am trying this on my mac laptop now (the last two emails were re my win7 desktop). I am having the same problem and am a little puzzled that no-one else is? I am using SU 2014 and the tool works like a dream when using in your example file - see attached screenshot, ruby coming out ok - but in a new document no activity at all just like in my Win 7 version.
Note I did not attach a screenshot of it not working. You can imagine - nothing whatsoever on the ruby console, the track tool opens the "add track" dialog but both "from scratch" and "from selection" are blank, just like the screenshots I sent before.
I went ahead and added "puts js" correctly (
you can tell I am no programmer!) into line 393 (which is blank, is that right?):js << "form.onkeyup = push_changes;"puts js
#Show dialogYou can see it here between the lines above/below.
But it didn't help - didn't produce any better / more results.
I've never had an issue with plugin install before. I went preferences > install plugin >chose the .rbz file, said yes I did trust it etc etc.
And of course it works A+ with the example file.
Have you tried a new file from scratch?
JB
Dean: Unless this specific bug occurs to any of those developers I don't know what they can do about it. I's probably something that is fixed really easily once it's found but it can only be found on a computer it occurs on.
Jon: That's the right place
. Did you activate the add track tool after adding this code?
