    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 168.3k Views 41 Watching
    • ppoublanP
      ppoublan
      Here is the track that makes strange result with short tracks.
      custom track directory
      Yours
      Pascal
      • eneroth3E
        eneroth3
        Pascal: I've updated the Add Track Tool to avoid the problems with the control vector pointing the wrong way. The Lego tracks should work after you've replaced the file in the plugin with the one attached 😄 .
        I've also been working on adding the new references in the balise code. last_run and last_train is really simple but I was wondering how you imagined the custom data. It's quite hard to save it between sessions if it contains other classes than what can be written as attributes (trains for instance). Is it enough to save the custom data within the session only?
        Btw: I really love the idea of making Lego trains 😄 😄
        Edit: The scale of the arrows in the switch tool and height of the coupling points in the coupling tool are still adapted for trains at the scale 1:1. However it now all should function even if not visually pleasing at other scales.
        track_insert_tool.rb
        My website: http://julia-christina-eneroth.se/
        • ppoublanP
          ppoublan
          There is no problem for me if the balise states/variables are not saved from one session to the other. Maybe I would prefer if the code typed into advanced animation dialog could be saved, it would be great.
          In fact I’m looking for the best way to prevent from collisions… I did not found yet the ideal way.
          Maybe I missed another wish, a function or track property that will return if another train is already on the same track ? or a kind of special balise that can act as a signal based on where trains are.
          I have used last_run and last_train to reduce speed of current train and accelerate the previous one if time between 2 trains is too small. This is already a cool way to regulate traffic, but It looks to be insufficient when two different tracks merge into one. If you have any idea.
          • tt_suT
            tt_su
            "This video is private" 😞
            /me wants LEGO!
            • ppoublanP
              ppoublan
              Oops, is it better now ?
              • tt_suT
                tt_su
                • eneroth3E
                  eneroth3
                  I can hardly believe my eyes when seeing the video. It's really cool!
                  I think I can add the settings for how to follow a rolling stock in the advanced animation settings. I don't want to clutter the context menu since it makes it a lot more time consuming to find in it when drawing.
                  By 'Translate camera', do you mean moving the camera relative to the train but without rotating and by 'Rotate around selection' the current behavior?
                  I can add a reference called session_data to the balises where user can store any data they like during a the Sketchup session.
                  Btw, custom signals have been added for the next version:).
                  • ppoublanP
                    ppoublan
                    Hi Christina,
                    Thanks for the fix for small tracks. It works great.
                    I played a little bit with the SU camera target and eye attributes and put the code to be executed between frames.
                    Here is a sample of what can be obtained with that :
                    It’s very simple code, but hardcoded, and no idea of any user interface.
                    I will try at least to “package” some functions so they can be called easily from railroad at each frame call.
                    Basically I’m thinking of :
                    • Follow selection
                    • Rotate around selection
                    • Zoom in / Zoom out
                    • Translate camera
                      With any train that can be selected as any other object.
                      If others want to play and add more detailed/fun rolling stocks, here is the basic Lego pack used in this video to unzip in the Plugins directory (simple track + locomotive and freight):
                      ene_railroad.zip
                    Yours
                    Pascal
                    • BoxB
                      A fantastic plugin, but it does have something that bothers me. I like to use a limited number of toolbars and only open them up when I need them. Your toolbar, no matter which way you close it, will always reopen on startup unless you have actually disabled the plugin. Could you look at removing this behavior.
                      • eneroth3E
                        eneroth3
                        The plugin should run toolbar.restore within a 0 timer t avoid some bug (apparently called 2902434) but for some reason my code uses .show instead 😲 . It'll be fixed for the next release but you can manually change it an line 1248 in main.rb now if you want to. I think this was the solution for a bug in SU 8 which doesn't support the plugin so it's probably not needed at all. 😕
                        • BoxB
                          Thanks, it was only a tiny thing in an otherwise superb plugin.
                          • deaneauD
                            deaneau
                            WELCOME BACK <joke> JCE (sound like jaycey)</joke> Eneroth3.
                            i have find some bugs and eastereggs in your plugin.
                            more about this via PM.
                            dean
                            • ppoublanP
                              ppoublan
                              Hi Christina,
                              Easier to explain with sample. Here are some functions I used, to be called at each frame.
                              Feel free to integrate/customize/mix as you want within your plugin.
                              Here is the ruby file:
                              camera_animation.rb
                              And samples:
                              rotate around
                              target
                              follow
                              Pascal
                              • tt_suT
                                tt_su
                                So, you created the animations in your videos with your own animation script?
                                Have you published it anywhere other in that comment here? GitHub?
                                • ppoublanP
                                  ppoublan
                                  Yes for the cameras, not for the trains that are moved by Christina's Railroad plugin.
                                  No. Its only few lines of code, that could/should be optimized... and adapted to custom needs. If any of the good developers that are here wants to improve it to make a more complete library it may be great...
                                  In fact I think those features are really missing to SU.
                                  • tt_suT
                                    tt_su
                                    I'd encourage GitHub to publish code where you invite collaboration and enhancements from the community.
                                    • leolouieL
                                      leolouie
                                      I have just downloaded the Railroad plugin, but there are no selections in the "Add Track" box. Is there a link to other components?
                                      • eneroth3E
                                        eneroth3
                                        Pascal: The animations look great and I really like the 0.95 ratio thing to make it smoother. It looks just as filmed with a real stadicam. I think this library could grow and be used for much more than the train simulator. I agree with Thomthom about putting it on Github for more people to work on, then I can also add a link to it from the documentation of my plugin 👍 .
                                        That's really odd. What Sketchup version are you using? 2013+ is needed.
                                          jonb42
                                          I'm having the same problem. I use SU 2013 and 2014 and in neither of them can I place track in a new drawing. When I open your example drawing however I am able to place track - it is as if a library was not loading but perhaps is already loaded in the example drawing.
                                          Also in SU 2013 I get a script error - see attached photo. I'm using your latest version 1.13 I think dated the 9th of this month.
                                          thanks though for this awesome plugin! I am really impressed and can't wait to place a train track throughout some new building model I want to show off to a customer!
                                          Jon
                                          • eneroth3E
                                            eneroth3
                                            Jon
                                            Hi Jon
                                            This sounds very similar to an error on Mac that's one user has reported but that didn't occur for others. Can you add this code "puts js" to line 376 in track_insert_tool.rb and post the text printed in the console?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
