    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 168.3k Views 41 Watching
    • tt_suT
      tt_su
      ๐Ÿ˜
      • eneroth3E
        eneroth3
        I can hardly believe my eyes when seeing the video. It's really cool!
        I think I can add the settings for how to follow a rolling stock in the advanced animation settings. I don't want to clutter the context menu since it makes it a lot more time consuming to find in it when drawing.
        By 'Translate camera', do you mean moving the camera relative to the train but without rotating and by 'Rotate around selection' the current behavior?
        I can add a reference called session_data to the balises where user can store any data they like during a the Sketchup session.
        Btw, custom signals have been added for the next version:).
        My website: http://julia-christina-eneroth.se/
        • ppoublanP
          ppoublan
          Hi Christina,
          Thanks for the fix for small tracks. It works great.
          I played a little bit with the SU camera target and eye attributes and put the code to be executed between frames.
          Here is a sample of what can be obtained with that :
          Itโ€™s very simple code, but hardcoded, and no idea of any user interface.
          I will try at least to โ€œpackageโ€ some functions so they can be called easily from railroad at each frame call.
          Basically Iโ€™m thinking of :
          • Follow selection
          • Rotate around selection
          • Zoom in / Zoom out
          • Translate camera
            With any train that can be selected as any other object.
            If others want to play and add more detailed/fun rolling stocks, here is the basic Lego pack used in this video to unzip in the Plugins directory (simple track + locomotive and freight):
            ene_railroad.zip
          Yours
          Pascal
          • BoxB
            A fantastic plugin, but it does have something that bothers me. I like to use a limited number of toolbars and only open them up when I need them. Your toolbar, no matter which way you close it, will always reopen on startup unless you have actually disabled the plugin. Could you look at removing this behavior.
            • eneroth3E
              eneroth3
              The plugin should run toolbar.restore within a 0 timer t avoid some bug (apparently called 2902434) but for some reason my code uses .show instead ๐Ÿ˜ฒ . It'll be fixed for the next release but you can manually change it an line 1248 in main.rb now if you want to. I think this was the solution for a bug in SU 8 which doesn't support the plugin so it's probably not needed at all. ๐Ÿ˜•
              • BoxB
                Thanks, it was only a tiny thing in an otherwise superb plugin.
                • deaneauD
                  deaneau
                  WELCOME BACK <joke> JCE (sound like jaycey)</joke> Eneroth3.
                  i have find some bugs and eastereggs in your plugin.
                  more about this via PM.
                  dean
                  • ppoublanP
                    ppoublan
                    Hi Christina,
                    Easier to explain with sample. Here are some functions I used, to be called at each frame.
                    Feel free to integrate/customize/mix as you want within your plugin.
                    Here is the ruby file:
                    camera_animation.rb
                    And samples:
                    rotate around
                    target
                    follow
                    Pascal
                    • tt_suT
                      tt_su
                      So, you created the animations in your videos with your own animation script?
                      Have you published it anywhere other in that comment here? GitHub?
                      • ppoublanP
                        ppoublan
                        Yes for the cameras, not for the trains that are moved by Christina's Railroad plugin.
                        No. Its only few lines of code, that could/should be optimized... and adapted to custom needs. If any of the good developers that are here wants to improve it to make a more complete library it may be great...
                        In fact I think those features are really missing to SU.
                        • tt_suT
                          tt_su
                          I'd encourage GitHub to publish code where you invite collaboration and enhancements from the community.
                          • leolouieL
                            leolouie
                            I have just downloaded the Railroad plugin, but there are no selections in the "Add Track" box. Is there a link to other components?
                            • eneroth3E
                              eneroth3
                              Pascal: The animations look great and I really like the 0.95 ratio thing to make it smoother. It looks just as filmed with a real stadicam. I think this library could grow and be used for much more than the train simulator. I agree with Thomthom about putting it on Github for more people to work on, then I can also add a link to it from the documentation of my plugin ๐Ÿ‘ .
                              That's really odd. What Sketchup version are you using? 2013+ is needed.
                                jonb42
                                I'm having the same problem. I use SU 2013 and 2014 and in neither of them can I place track in a new drawing. When I open your example drawing however I am able to place track - it is as if a library was not loading but perhaps is already loaded in the example drawing.
                                Also in SU 2013 I get a script error - see attached photo. I'm using your latest version 1.13 I think dated the 9th of this month.
                                thanks though for this awesome plugin! I am really impressed and can't wait to place a train track throughout some new building model I want to show off to a customer!
                                Jon
                                • eneroth3E
                                  eneroth3
                                  Jon
                                  Hi Jon
                                  This sounds very similar to an error on Mac that's one user has reported but that didn't occur for others. Can you add this code "puts js" to line 376 in track_insert_tool.rb and post the text printed in the console?
                                  • deaneauD
                                    deaneau
                                    Here an intresting links:
                                    for all ENE-RR-Fans ( eneroth3railroad)
                                    http://gritton.org/greg/rail/docs/clearance/
                                    http://gritton.org/greg/rail/docs/clearance/AAR_plates_with_UIC.gif
                                    this is a svg file UIC & AAR clearance.
                                    for all non railroader.
                                    this is the room that need the train without crash with other objects along and alongside the Track ( /bridge/tunnel/catenary/signals/and other trains.)
                                    http://en.wikipedia.org/wiki/Loading_gauge
                                    http://www.rgsonline.co.uk/Railway_Group_Standards/Infrastructure/Guidance%20Notes/GEGN8573%20Iss%201.pdf
                                    for more search results: insert in google
                                    aar clearance (american) AND/OR uic clearance (european+br)
                                    here a way to go to a simulator (sketchup to trainz(auran.com))
                                    (www.dhobh.net)
                                    sometimes i work/play with this, too.
                                    AND
                                    railworks (Trainsimulator 2012/2013/2014/2015)
                                    Dovetail Games
                                    Dovetail Games. 21,472 followers ยท 20 talking about this. By Enthusiasts, For Enthusiasts Developer of Train Sim World, Train Simulator Classic and Metro...
                                    (www.facebook.com)
                                    http://www.dovetailgames.com/news/2014/jul/21/dovetail-games-announces-train-simulator-2015-for-september-18
                                    sorry not a sketchup plugin avaiable only for blender/3dsmax. ๐Ÿ˜ข
                                    and here my historical project for this games.
                                    404 Not Found
                                    (rail-sim.de)
                                    sorry german language however with pictures.
                                    this is not an egoshooter!!!
                                    dean
                                    (loco driver student/retired)
                                    all parts was build with original blueprints!!!
                                      jonb42
                                      @eneroth3 said:
                                      Hi Jon
                                      Julia,
                                      see attached screenshots.
                                      In the ruby console what you see is left from me running some other plugin - so you can see the console is working. Actually, none of your tools writes anything to the console. You can see I've started the track tool here and nothing shows - except the script error dialog.
                                      The other screenshot is showing where I put the "puts.js"
                                      Another strange thing - while I was looking for track_insert_tool.rb I noticed there was only an instance of this file in the Program files etc SU 2013 Plugins folder, not in the SU 2014 folder. Is the plugin not compatible with 2014 or am I looking in the wrong place? I looked under ProgramData as well and searched c:\
                                      Maybe the install process did not work properly?
                                      thanks
                                      Jon
                                      • eneroth3E
                                        eneroth3
                                        Jon,
                                        Sorry, I gave you the wrong line number because I've added more code above it in my local copy. The code needs to be on line 393 and without quotes:
                                        puts js
                                        I've never installed a plugin from the Pluginstore so I don't know if it puts the files in the wrong location, however if it does the plugin shouldn't open at all.
                                        It seems like something goes wrong when creating the javascript that is later executed in the web dialog so I'd like to know what code is executed (the variable named js). I really have no idea how this can work in my example model but not in new models. That is really odd.
                                        • eneroth3E
                                          eneroth3
                                          Dean,
                                          These links are quite inspiring. I've actually drawn 2 structural gauges (European ones) as rolling stocks included in the plugin that can be used to test tracks.
                                          Do you know any online resources for original drawings?
                                          • deaneauD
                                            deaneau
                                            @eneroth3 said:
                                            Dean,
                                            Yes i know, however your audience / targed group is bigger.
                                            i think you will that all continents of the world know your plugin.
                                            Trainz is an australian game with routs in AUS,USA,GBR,SWE,GER,FRA,RUS etc.
                                            the Game TS 2014 (2015) have routs in USA GBR,;FRA,CHN and in the next version YPN,too.
                                            yes i know some. however only open blueprints.
                                            you must know that blueprints of the GERMAN ICE is not opensource and normally you must pay a license when you show the ICE in your plugin.
                                            i think the best way is to contact DB Deutsche Bahn and ask.
                                            you must tell, that your project isnยดt commercial and you will show kids how i build my railroad in 3d.
                                            AND you and the kids love the ICE. ๐Ÿ˜‰
                                            the same you must write to the british railway etc. this sound in the ears better when you doining somethings with passion and love.
                                            you must know that i was loco driver student and this was very difficult to become any pages in pdf etc.
                                            i would would therefore recommend that you contact any users in the rail-sim.de forum or in the main auran forum.
                                            you can find there a woman ( Sandra-Marion/rail-sim.de). when you need support for a german translation for letters and contact i could help you...however you must do it by your self.
                                            i dont know what you need.
                                            normally the first address for me is the 3d warehouse than safe all side views with measures as pictures and build your loco,airplain,ship or what ever.
                                            some designer for games that give away freeware parts you could contact,too.
                                            here i could help in german language,too.
                                            however some designers could tell you, freeware is not free..you can this use for free in the game, its strictly forbidden to recompile etc.
                                            you must know, that i have 2-3 years to investigate,research for the BerlinWallProject.
                                            i have contacted Soldiers of the EAST GERMAN BORDER PATROLS to become any background knowhow about this.
                                            ok this is and was a very sad political theme/topic.
                                            normally, a Berlin People donยดt search contact to the soldiers of the(Grenztruppen ( East German Border Patrol).
                                            my target was, all kids must see and know what is it the Wall, what feeling before and behind the wall etc.
                                            ok i could visuallize a LIMES, however i cant ask a roman soldier about this ๐Ÿ˜‰
                                            i have contacted the producer of the movie Walled-in (Art-Com)
                                            Redirect Notice
                                            (www.google.de)
                                            every time when i see this movie, itยดs like the same under a very cold water shower or rolling icecubes over my back. ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿ˜ข and this turn me angry and sad. ooops sorry.
                                            blueprints for buildings you must visit libraries or museums about architecture.
                                            the mother of all locos "The Rocket" you could find in Nurmberg (Germany) and in England
                                            http://wn.com/rainhill_trials
                                            ok when you have more questions you could ask.
                                            do you know the innotrans in Berlin?
                                            Page not found
                                            (www.innotrans.de)
                                            in september 23-26 you can see the newest locos ๐Ÿ˜„
                                            i will pay a ticket in the next month.
                                            when you will come to berlin with your boyfriend or girlfriend etc. i could ask the owner off my appartment. he have appartmats for visitors, not so expansive like a hotel, i hope. otherwise we have many hotels/hostels and motels. ๐Ÿ˜„
                                            ok cu
                                            dean
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
