    How to fill holes up in Sketchup
    12 Posts 6 Posters 22.1k Views 6 Watching
    • pbacotP
      try drawing a line across the opening between the bottom corners.
      • xiombargX
        xiombarg
          dedmin
          πŸ˜„ Easiest way:
          • ely862meE
            ely862me
            Would be the easiest if the top wasn't arched. πŸ˜‰
            Elisei (sketchupper)
            Come and See EliseiDesign
            • Y
              YoungOSG
              is there a plugin to fix this problem?
              • ely862meE
                ely862me
                You don't need a plugin to close a face. If you use the Line tool as advised you will close the open faces, but the old faces will still be there. Then you have to select the old faces and delete them.
                The easiest way for your geometry should be this: Select Push&Pull Tool, pull one side of the opening to the other side, then press the Space bar key and with your mouse select the remaining top geometry and delete it by pressing the Delete key.
                [web 100%,396:2o480vy3]https://www.screenr.com/embed/2SRN[/web:2o480vy3]
                • Y
                  YoungOSG
                  [quote="ely862me"]You don't need a plugin to close a face. If you use the Line tool as advised you will close the open faces, but the old faces will still be there. Then you have to select the old faces and delete them.
                  thanks ! it works.
                  one question more.
                  after i union walls and roofs ,i get a solid as picture.but it has a interior ,and i just want the outer shell.what should i do?
                  i don't want to delete them by myself.is there any convient way?
                  ![9SK7A}3%S8SET7)2]7E$HCS.jpg](/uploads/imported_attachments/AQzs_9SK7A3S8SET727EHCS.jpg)
                  • cottyC
                    cotty
                    You should stop to ask the same question in different topics!
                    This last one is discussed here http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=58550.
                    my SketchUp gallery
                    • Y
                      YoungOSG
                      sorry. i got it.never again.
                      • ely862meE
                        ely862me
                        Cotty means that if you start a question in one place you don't need to ask again in another place.
                        As for the interior geometry that you want to delete, it should be simple if that inside geometry is not connected to the outside geometry.
                        If the inside geometry is not connected the the outside geometry, triple click on a face and that should select the entire geometry, then if the entire inside geometry is selected press the Delete key, or right click over the selected geometry and chose Delete.
                        These indeed are the most simple operations Sketchup is able to do. I would advise you to check the Youtube for every tool you see inside Sketchup. There are many videos that explain how the tools are working. The user's guide would be too much for you as I see you don't understand much english either but perhaps you could read the manual in your own language if there is one.
                        • xiombargX
                          xiombarg
                          Three videos on how to close a hole! Awesome! πŸ€“
