    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 368.5k Views 89 Watching
    • P
      poiseis
      still waiting for su2014 !!! Hurry Didier it's my best plugin (actualy after 1001bits)
        rv1974
        Folks, the best tool in in this field (scattering) so far is Chris Fulmer's Repeat Copy (on Smustard.com). Works way better than compospray (will work with preselected set, will paint
        upon the stacked balconies, has 'no repeat' function.. etc)
        I really recommend to burn the giant sum of $10 and get it.
        • majidM
          majid
          I like the wonderful plugin, waiting for update ๐Ÿ‘
          • C
            chc3826
            2014 SketchUp compo Spray Ruby Install error
            Error: #<SyntaxError: c:/users/user/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:511: Invalid break
            c:/users/user/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:520: Invalid break>
            compoSprayToolbar.rb ํŒŒ์ผ ๋กœ๋“œ ์˜ค๋ฅ˜
            Error: #<NoMethodError: undefined method compSpray_env' for main:Object> C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/compoSprayToolbar.rb:7:in <top (required)>'
            Please make it possible in the 2014 version.
              404 Not Found
              (sketchucation.com)
              • OxerO
                Oxer
                I have installed the plugin in /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools and the plugins works fine now on Mac 10.9.4 & SU2014.
                Thanks you very much for the info!! ๐Ÿ‘
                • mtripleM
                  mtriple
                  you are welcome my friend, iam just looking for pro coder to help me with sketchyphisics to work on 2014 cuz im noob, if any one can help plz.
                  compospray workin 2014
                  • OxerO
                    Oxer
                    It would be great to run Sketchyphisics on SU2014 but I haven't idea about ruby code or programming, sometimes I help to translate the plugins or I test the plugins on Mac.
                      dtrarch
                      Mtriple
                      Thanks for figuring out how to get Compo Spray to work in SU 2014
                      This is really a GOTTA HAVE tool from the past.
                      Just to make clear the fix as I understood it.
                      Here is what I did to make it work
                      1-I copied compoSprayToolbar.rb and the folder CompoSpray to Program Files(x86)/Sketchup/SketchUp 2014/Tools
                      2-I also copied them both to xxx/Roaming/SketchUp/Sketchup2014/SketchUp/Tools
                      To get it to work.
                      Open SU 2014
                      goto View/Toolbars and select select the [X]Components Spray option box.
                      There it was and in working order too.
                      This might also be a fix for other Didier plugins as well
                      Whew!
                      Thanks again Mtriple the Great.
                      dtr
                        JamesCE
                        I did what dtrarch said(I am not getting an error message when launching anymore) but..
                        Wwhen I go to View/Toolbars and try to select the [X]Components Spray option box it is not there. I have other extensions installed but Components Spray is not listed. I can also pull up the tool bar for CompS but it does nothing when I try to use it.
                        On step #2 I could not locate the tools folder. I tried to find xxx/Roaming/SketchUp/Sketchup2014/SketchUp/Tools
                        but my file structure is set up like this xxxx/Roaming/Sketchup/Sketchup2014/Sketchup/ -- and there is only a plugins and classifications folder.
                        Am I looking in the wrong spot? Any suggestions?
                        Thanks in advance
                        • mtripleM
                          mtriple
                          now it will work fine on 2014,
                          Dropbox
                          (www.dropbox.com)
                          after updating some files, the problem solved, it was ::: in 2014 plugins folder named as "Tools", in older versions it was "plugins" .
                          prove
                          http://i375.photobucket.com/albums/oo199/mtriple1/cs_zps37ffe11b.jpg
                          • mtripleM
                            mtriple
                            up up ^^^
                              I'm NOT sure that putting any non-SketchUp files into Tools is a good idea...
                              You might well have limited permissions to add files to that folder too...
                              However, to find ANY of SketchUp's folder use this in the Ruby Console:
                              Sketchup.find_support_file('Tools')
                              To find something else simply change what is inside the ''...
                              • mtripleM
                                mtriple
                                what dtrarch saying :
                                Latest files : https://www.dropbox.com/s/5sc2ghd6t5amrgh/cs.zip
                                for windows:
                                copy Latest files after unzip to :
                                "Program Files(x86)/Sketchup/SketchUp 2014/Tools"
                                dont copy the Latest file to next link unless first step didnt work :
                                "C:\Users*ur username*\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
                                idk for mac maybe the same ask Oxer .
                                  dtrarch
                                  Hello mtriple
                                  As just a marginal CodeHead I did what you recommended but could not get the Icons to show so I also just stuffed the folder and .rb into RoamingxxxxSketchup2014/Plugins/Tools.
                                  My cut and try screen shots FYI ?
                                  As TIG observed maybe just the CompoSpray.rb file is needed or ???
                                  No error or problem as it stands for me.
                                  dtr
                                    I am perturbed that you seem to have a mash-up in your main 'Tools' folder. ๐Ÿ˜ฒ
                                    This is mine...
                                    Everything else in the default Plugins folder, or custom-plugins folders set to load from $:...
                                    The 'Tools' folder is reserved for a few standard SketchUp rb files, and in v2014 the Ruby Libraries...
                                    Making another Tools subfolder elsewhere is plain weird ???
                                    There are several old files in there too [i.e. pre-v2014!] - the v2014 dynamiccomponents loader is NOT that name etc, and the extensions, sketchup and langhandler ruby files are the ones in Tools and should never be duplicated elsewhere ๐Ÿ˜ฎ Old files like date and rational rb are also outmoded in v2014...
                                    If it's inside the Plugins folder nothing within it will auto-load, unless it is explicitly added to $: ๐Ÿ˜•
                                      dtrarch
                                      Understood re /Tools
                                      The SU2014 & updates were per download installs.
                                      The only thing I did copy to the /Tools folder was the CompoSpray folder & .rb
                                      You figure where the other stuff came from.
                                      Does not seem to cause an error or interrupt other plugins.
                                      Hmmmm?
                                      dtr
                                        JamesCE
                                        I am having the same problem as I had before.
                                        If I copy the latest compspray files to my plugins folder here:
                                        I get this error when opening SU. Also the toolbar isn't listed and CS isn't there.
                                        If I copy the latest files here:
                                        I am able to pull up the toolbar for compspray but the only thing that works are the CS settings. I also could not find compspray in the SU system preferences/extensions window.
                                        Any ideas on what I'm doing wrong?
                                        • TedVitale_CGT
                                          TedVitale_CG
                                          I'm having the same problem on my end as well.
                                          Ted Vitale
                                          Owner | Creative Director
                                          http://www.voxl.vision
                                            dtrarch
                                            Hi mtriple
                                            Thanks for the new fix
                                            Now OK to install in SU 2014 in xxx/Roaming/(SEE SCREEN COPY)
                                            Works now in SU 2014 Plugins folder. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                            dtr
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
