    Pacific Silver Fir
    34 Posts 12 Posters 3.3k Views 12 Watching
      No geometry for needles. πŸ˜‰
      • olisheaO Offline
        olishea
        So that's instancing inside an instance, bit like inception! Go deeper and instance bugs on the needles πŸ˜† . Yeah i meant just a close up render to see the glory of the details. You should do full geometry skp too so trees can be rendered in other apps as instances. Has sapling plugin improved/developed or is it still the same?
        oli
          the process is a bit involved but the end result in terms of close-ups in controllable.
          i won't go into the whole process as it is incredibly boring.
          but in short i start by creating a section of branch using real geometry. I render out 8 variations as .png....
          ...these a particle systems on a cylinder.
          I then create the trunk using the skin modifier.
          I then add particles and arrays to the trunk to generate the branches.
          job done...
          what's controllable is the initial branch render. So the higher res you go with that the closer you can get with the camera...
          this tree is 5mb as a .skp which isn't too bad considering.
          again my drive to stay away from nested components provides a big performance boost in SU.
            dtrarch
            Rich
            Just super models. πŸ‘ πŸ‘
            Please pub the SU files as even large landscape models can be used for face-me images when turned and scaled a bit in SU.
            Also even big single models can be exported to Artlantis which can handle really big files and be used as ATL objects.
            Thanks for the really good work
            dtr
              You'll have them soon enough in skp and thea format
              • olisheaO Offline
                olishea
                i forgot to say thanks for the mini tut πŸ‘
                oli
                  Ur welcome.
                    Click this to see animation...
                    ....with drag drop proxy support for thea
                    ...materials setup
                    ...skp and .obj formats
                    • cheddaC Offline
                      chedda
                      These look great will they be available anywhere in sketchup format πŸ˜‰ ?
                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                        They'll be in Shop on Monday.
                        Pack includes 15 variants. In .skp and obj. All properly mapped and norm and spec maps included.
                        For Thea users they will be a very efficient proxies in SU.
                        They will be free for Premium members.
                        • Bob JamesB Offline
                          Bob James
                          Super work, Rich, and will be very useful to me since I live on the Pacific coast.
                          Thank you not only for these, but for all the tireless effort you put in to make a great graphics environment for us all. πŸ‘
                          • massimoM Offline
                            massimo Moderator
                            Well I know that Rich loves gardening. πŸ‘
                              Ha ha...
                              And I planted lots of real trees today....
                              Those trees you got look nice.
                              Where you get them?
                              • massimoM Offline
                                massimo Moderator
                                Got them from a nice guy. A rugby and gardening fan.
                                  For those interested.....
                                  404 Not Found
                                  (sketchucation.com)
                                  Includes -
                                  Thea Ready SketchUp proxies
                                  .OBJ files uv mapped
                                  .SKP files uv mapped
                                  Render maps
                                  2D FaceMe components
                                  Free if you are a Premium member
                                  • TIGT Online
                                    Thanks πŸ˜„
                                    πŸŽ‰
                                    • olisheaO Offline
                                      olishea
                                      nice look forward to using them.
                                      oli
                                        dtrarch
                                        Rich
                                        Super collection πŸ‘ πŸ‘ and thank you.
                                        dtr
                                          You are all welcome.
                                          There are 2 materials there for Thea users so u can generate some variants.
                                          Massimo's idea.
                                          Credit goes to him.
                                          • RichardR Offline
                                            Richard
                                            Great stuff Rich, to say I'm impressed is an understatement!
                                            BUILTBRAND.COM.AU
