    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 90.0k Views 41 Watching
      The path is still wrong.
      So it's still wrong also on the documentation, see the image above.
      I don't know what I must put! πŸ˜•
      There still seems to be no difference between the third and forth header level.
      I will see that I can make...
      There is still colored text where it shouldn't be.
      I can't with my sytem make the same than the colored arounded text πŸ˜•
      The colored text is now also bold which makes it even harder to read the document.
      Easy to change πŸ˜„
      The attributes for moving parts are sometimes bold, sometimes not.
      Easy to change πŸ˜„
      There are now missing line breaks at the balise page.
      Damned! 😲
      It's not near perfection.
      Perfection is not for this world! πŸ˜„
      It's not even decent.
      I have yet seen worse! πŸ˜„
      • eneroth3E Offline
        eneroth3
        It should say what it said before you changed it! 😑
        There was already correct headers in the document. You only had to change the text inside the existing elements. 😑
        I can't with my sytem[sic] make the same than the colored arounded[sic] text πŸ˜•
        Then don't use that system. It was already correct. You only had to change the text. Not recreate the document from scratch. 😑
        Also that doesn't even answer what I said. text is colored where it shouldn't be colored. You even changed it to different colors where there shouldn't be any colors in the first place. 😑
        You we're the one saying it was near perfection, thus bringing the term perfection into the conversation and now you say it shouldn't be perfect. 😑
        I've found so many errors it's embarrassing. And that's just about formatting, exact quotes and other things I as someone not speaking French can see. I have no idea what the grammar and spelling is like. I have no idea if the text says what it should say. It could just as well be a cupcake recipe. I don't know if you would even notice if it was a cupcake recipe since you don't seem to have understood the text in the first place when you translate text quoted from the context menu within the plugin.
        My website: http://julia-christina-eneroth.se/
        • OxerO Offline
          Oxer
          I have created a Spanish Language File with all strings to translate. It's a .txt file that it includes the English string and the corresponding Spanish string:
          "English Text"="Spanish Text"
          The strings are organized by files i.e. main.rb, balise.rb, balise - index.html, ....
          I hope that this file can help you to give support to translate the plugin to all languages.
          • eneroth3E Offline
            eneroth3
            [attachment=0:kyjytomg]<!-- ia0 -->Spanish Language.txt.zip<!-- ia0 -->[/attachment:kyjytomg]
            Thanks πŸ‘ . If I add a language system to the plugin I'll include this πŸ˜„
            • OxerO Offline
              Oxer
              It's a pleasure, you are doing a great work with this incredible plugin. πŸ‘
                My translation is perfectly understandable by French people : i have tested it!
                Hundred persons on many forum 😎
                And after some corrections from your advices anybody who read it can use your terrific plugin with great pleasure! β˜€
                It's a quasi copy cat! πŸ˜„
                The story of color text / emulation as my system can't make exactly the same is that we say in French des "Queues de cerises" ! πŸ˜„
                http://2.bp.blogspot.com/-9MeoXNsyt48/T51O1VT5OPI/AAAAAAAABtM/HT30cvyRoNA/s330/cerise%2Bqueue.jpg
                About perfection : that is just a touch of humor πŸ˜„
                PS I even made publicity for your plugin at the Paris Maker Faire this past week-end! β˜€
                Where they where John Bacus and Omar-Pierre Soubra! πŸ˜‰
                This last one said to me (in French πŸ˜„ that your plugin will be put in front on the next Sketchup exibitions everywhere on the world! πŸ˜‰
                • eneroth3E Offline
                  eneroth3
                  Version 0.1.12 is now published! πŸ˜„
                  The main new features are a better interface to save rolling stocks to library and support for translations (big thanks to Oxer for Spanish translation now shipped in the extension πŸ‘ ).
                  Download
                  The new interface for saving rolling stocks along with the improved documentation has made it easier to add rolling stocks to the library. Now rolling stocks can be saved from within any model instead of having to be alone. Images are also automatically generated now even if it's a bit buggy and a better image can be generated manually (more info in documentation). The new dialog for saving rolling stocks now suggests IDs for them so the user doesn't need to worry to much about that either.
                  To save a rolling stocks to library, select it (after it's initialized) and run Ene_Railroad.ss_2_rs_library to open the dialog (graphical interface to open dialog is planned for a later version).
                  The translation system allows for translated versions of all strings within the plugin itself. The documentation will however stay in English since it constantly changes.
                  You can change between available languages in Plugins > Railroad > Change Language.
                  To translate the plugin download the attached file, add the language name and your name at the top 2 lines. The syntax for the translation is "original string"="translated string". When adding the translation remember to look at the string in its context inside the plugin and be consistent with reoccurring terms such as track and rolling stock. Save the file as <language code>.l10n inside the folder "lang/" in the plugin's folder.
                  If you want to I can include the translation in the next version πŸ˜„ .
                  I hope to see pictures of people's own rolling stocks posted here now πŸ˜„ .
                  template.txt
                  • OxerO Offline
                    Oxer
                    Incredible work, all work fine on Mac & SU2014. πŸ‘ πŸ‘
                      Cool new version! β˜€
                      Let see if I will make better this time! πŸ˜„
                      Translation of the text file multi language done! β˜€
                      Must be inserted on the dialog boxes for verification!
                      (because French text is some bigger than English )
                      Tomorrow will be made. πŸ˜„
                      • deaneauD Offline
                        deaneau
                        german language have longer words πŸ˜‰
                        german language is ready
                        dean
                        • eneroth3E Offline
                          eneroth3
                          dean
                          It already supports Spanish which has short words but a lot of them so I think it'll work πŸ˜‰
                            mwm5053
                            Downloaded new ver. and still get empty dialogue boxes.
                            2011 iMac
                            SU 2015 Pro, 2017 Make
                            V2 Twilight
                            macOS Sierra 10.12.5
                            • eneroth3E Offline
                              eneroth3
                              Odd 😲 . What OS version is it? Do you know if it's older or newer than Oxer's?
                                Aerilius
                                I remember there was the set_html issue (although it was reported not to happen anymore). Is that a possible cause?
                                • OxerO Offline
                                  Oxer
                                  I have the last version of OSX 10.9.4 & Safari 7.0.5, updated yesterday and for me all work fine.
                                    mwm5053
                                    Currently using a computer with 10.7.5 Lion & Safari 6.1.4 which is latest for Lion I have a Macbook Pro with 10.9.4 but don't have access to it right now.
                                    2011 iMac
                                    V2 Twilight
                                    • deaneauD Offline
                                      deaneau
                                      _2014.07.02_14h37m22s_005_00836.wmv
                                      now i have my first truck test finished.
                                        Cool but seems wheels don't rotate! πŸ˜‰
                                          All works fine but this box is a little bit smaller!
                                          (and French texts are full inside)
                                            French Interface πŸ˜„
                                            fr.l10n linked
                                            fr.zip
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
