    Is SU the right method for professional casting?
    4 Posts 3 Posters 339 Views 3 Watching
    • V Offline
      Vigy
      Hi guys,
      I did some 3d drawing for product casting (outsource manufacture), but at the end I decided to redraw them in 2D because I was concerned that the product surface will not have a 100% smooth curved finish (Product has Chrome Finish)
      At first I draw my 3D product in millimeter and changed the segments length less than a millimeter but as I kept on modeling I piled up too many poly lines that SU couldn’t handle it anymore, so I end up drawing it in 2D, then export it in DXF so that my outsource could get the real curved radius dimension correct.
      So I wonder to myself “Is SU the right method for professional casting, or not? 😲
      So what are my alternatives?
      Is it ok (in the professional world) to draw something in 3D with les segments and note the manufacture that it must be with smooth curved finish? If so how will they know when it’s a real radius or just an angle? Or I will just need to draw it in a different program e.g. Max or Blend?
      Thanks in advance,
      Victor.
      • xiombargX Offline
        xiombarg
        Hm. Well, if the casting method first requires a wax or plastic 3D print then no matter what 3D program is used for modelling the end result will be exported as an .stl file which means it ends up in polygons.
        Sketchup can work for this, but just be sure to model in a relatively large size and then scale down when finished. Also for a totally smooth model you will need a plugin like Artisan to take your model and subdivide and smooth it into thousands of tiny polygons.
        • xiombargX Offline
          xiombarg
          I would also say that in many ways other programs are more "adept" and aimed at high polygon modelling, but depending on how familiar you are with these other programs generally their interfaces are much more complex and have a high learning curve.
          I would also say that it's probably a good idea to supply a 3D model or file ready to go as it is supplied to them.
            slbaumgartner
            In the "real world" it is a matter of your understanding with whomever you are providing the designs to. I don't know that there is any generally accepted practice. I'm sure it depends on whether your client is adequately knowledgeable about SketchUp. It also depends on the form in which your user expects to receive the model. You may have to convert it to something else, such as stl, before you send it on. In that case is it your problem to decide how your objects were meant.
            Unless you annotate the model or provide separate documentation of your intent, someone using the model will have to provide their own interpretation. As noted, for some cases you can protect yourself by modeling at finer granularity (smaller Edges) than you know the user will require. Of course, this causes the model to have a very high Entity count.
            You are faced with a fundamental aspect of SketchUp's design: it might be termed WYSIAYG (what you see is all you've got). In some other applications, an object is defined in an abstract mathematical form (e.g. center location, normal vector, and radius for a 3D circle) and is converted to line segments when and as needed. For instance, when rendered to the display, a circle needs to be converted to a raster image with pixels appropriate to the resolution of the display. On a different display, a different raster representation will be generated.
            In SketchUp, there is no such higher-order abstract model. The Edges and Faces representing a shape are all there is. OK - picky point - a sequence of Edges can be joined together to form a polyline or polygon, but there is still no abstract model of the polygon as such.
            So, for a circle, a user needs to know how to find the center and measure from there to a vertex to discover the original as-drawn radius. If it really matters and they don't have the SketchUp expertise to do this, you will have to do it for them and annotate the model.
            This whole thing is a fundamental aspect of SketchUp's internal design, and part of how it obtains its much-treasured interactive user interface. Changing to the abstract-model-rendered-when-needed paradigm would be an end-to-end redesign of all the basic mechanisms of SketchUp.
            Steve
