    [Plugin] 2.5D CAM Plugin 20121202
    80 Posts 32 Posters 96.6k Views 32 Watching
      You must have FULL security permission to 'manage' files in your Plugins folder - t's been discussed at length in several posts here... Do a search...
      If you have a .ZIP archive simply rename it as a .RBZ... and it ought to auto-install OK from the Preferences > Extensions > Install button...
        joewood
        So as I am getting into cnc I thought I try this plugin, but I am not having much luck.
        . reloaded the plugin cnc2.5d v05
        . arc_offset_true is installed(with new download of cnc2.5d) under Tools
        . Tig_smart_offset is also installed but greyed out
        . made the part(24",3",1") with mortise(1",3",.5")a group
        . got the option menu, filled in the appropriate values and hit O.K.
        . that's as far as I got
        . where is the script?
        now what. I know I did something wrong(it is usually me)
        . it says file stored in the plugin folder, can't find it
        ......... thanks .....joe
        • E Offline
          Ellipser
          Thanks for making this file. It worked for me first time.
            tramspotters
            I´ve downloaded your plugin, but nothing works. I´m using the german version of Sketchup with , instead of . for the delimiter. Your scripts puts the coordinates from Sketchup with the ,. This was easy to find and I can make a search and replace with a texteditor. The next problem is that my CNC program complains the missing of M06 and the workplace is set to a strange position although i put the object on the zero point of my system.
            Do you have an idea if this might be a fail?
            Thanks for your help
            Guido
              mtech
              Can't get this to work in Sketchup 2014 😢
              Update:
              Downloaded from sketchucam and it installed and works ok.
              • E Offline
                edgars
                how instal CNC-profile plugin?
                  This is one of the few Plugins not available in the PluginStore.
                  If you download the ZIP file in the first post in this thread, you have three choices - listed from the easiest to the most difficult...
                  1. Use the SketchUcation Toolset submenu from within Sketchup to 'Install Archive' the downloaded ZIP [assumes you have already done the one-off download of the SketchUcation RBZ and manually installed it] - this SketchUcation AutoInstaller works for both RBZ and ZIP archives [after all an RBZ is simply a ZIP file renamed with another suffix!]
                  2. Rename the downloaded ZIP file with a .RBZ file-type suffix, this RBZ archive can the be installed using the Preferences > Extensions > Install... button. This sounds easy... BUT, you will need to set your Windows folder options to show all file-type suffixes, otherwise you could rename it XXX.rbz.zip rather than XXX.zip >>> XXX.rbz and it won't install !
                  3. Extract the contents of the downloaded ZIP file into a temporary folder, then manually move the entire contents of that folder into the SketchUp Plugins folder, ensuring that any files within subfolders remain intact, in the same relationship they had within the ZIP itself. This method is fraught with danger... and many fail because they do not manage this task successfully ! Leaving a mess to be cleaned up later... That is why the new RBZ format, and then the SketchUcation ZIP installer were invented...
                  • wilsonbuilt78W Offline
                    wilsonbuilt78
                    This is a great plugin! I have installed it and its generating gcode. I am now attempting to edit it to write gcode correctly for my SCM router which uses Xilog. I have no programming experience.
                    My first problem is that the stock size that the script generates is incorrect(stock size is required in header of my particular router):
                    Line generated: ( Stock Size: 3.93700787401575 x 3.93700787401575 x 0.62992125984252 )
                    Should read: (100x100x16)
                    I am working in mm and have set the units in model info to mm.
                    Is there a simple fix to this problem?
                    Once I have completed editing the script to output correctly for my router I will make available on this forum for other users of SCM routers.
                    Best Regards
                    Stephen
                      driven
                      Sketchup.format_length( 3.93700787401575).to_f
                      returns 100.0 if model units are set to mm...
                      the script is not doing this, so it needs to be added, by the author or yourself...
                      do a search for Sketchup.format_length and you should find the easiest way to apply it for all the numbers...
                        kevplank
                        I'm running an older Mac with Sketchup Version 8. I loaded the files to my "Plugins" folder of sketchup but it doesn't appear in the drop down menu. ??? Is this just not compatible with this version?
                          It is compatible with SU8. Check to make sure you have Full Read & Write permissions established for the Plugins folder. If not, change the permissions then try reinstalling the plugin. Also, before you install the plugin, make sure unzipping it hasn't wrecked the file structure. The best thing would be to rename the .zip file to .rbz and use Install Extension... from Preferences>Extensions>Install Extension.
                            kevplank
                            Thank you for the quick response!
                            I've tried everything you suggested but I'm running into a snag with the extension install.
                            I deleted the program out of the plugins folder and started all over again. Changed the .zip to .rbz and unpacked it. That all seemed to work just fine.
                            When I try to install the extension I get a message saying "SU was unable to install your extension for some unknown reason".
                            I also made sure I had "read and write" permissions and tried to re-install the pluggin the first way and nothing shows up in the menu bar of SU.
                            Part of the issue might be that when I go to the preferences>Extensions>Install Extension it doesn't allow me to go into the actual application contents folder. So I'm trying to install the extension from another folder. But I'm not sure that should matter.
                            I've tried both methods of installing into the contents>pluggin folder as well as doing everything I can think of with the extension install. Any other thoughts?
                            NEWS FLASH:
                            I was able to get everything installed perfectly on my iMac at my office. I happen to be running Mavericks on that computer with the latest version of SU and everything worked very well. I'm sure there are finer points to getting things to cut the way I want to, but I've already generated Gcode and ran it on my router with no issues. It's just this older version I seem to be having issues with now.
                              What does this mean? What did you do to "unpack it"?
                              Where did you save the .rbz file? It should be in someplace like a Downloads folder or maybe on your desktop.
                                kevplank
                                Like you suggested, I changed the .zip file to an .rbz. I'll try downloading to my desktop, but I had just downloaded it to a folder. The computer that I'm running Mavericks on worked just fine that way.
                                One side note of a question on another topic. I noticed that my tool path is operating basically one "level" of cut at a time. In other words it goes to each hole or machining location at one depth of cut and then goes back over the entire process again at the next depth of cut. I basically just want to cut some bolt patterns on a flat sheet with the current project. Seems like a lot of time is spent with the machine traveling from one hole to another rather than completing each hole before moving to the next. Is this something I'm not selecting properly in the process?
                                  MgRasmussen
                                  I'm just getting my CNC up and running, and I'd like to use this plugin, but I can't seem to get it to load in the new version, Sketchup 2015. I have unloaded it into the correct folder (per Sketchup's own instructions, but it still doesn't want to load).
                                  Did try renaming the files from *.rb to *.rbz, but got an error when I tried to open the extension automatically using the Sketchup plugin installer.
                                  Thoughts?
                                    You can't just rename the rb file to rbz and expect it to work. Change the .zip extension to .rbz and try installing that with Install Extension.
                                      Thoughts?
                                      This toolset comes in a ZIP, if you change the .zip ending into .rbz, then you can install it with the Preferences > Extensions > Install... button.
                                      See this earlier post http://sketchucation.com/forums/viewtopic.php?p=541812#p541812
                                      However, it is an old Plugin and might not be compatible with v2015...
                                      Assuming it is installed properly try this in the Ruby Console:
                                      load "CNC-profile.rb"
                                      Plus <enter>
                                      It should return 'true' OR errors ?
                                      • ely862meE Offline
                                        ely862me
                                        I have no idea what this should mean.
                                        Error: #<ArgumentError: wrong number of arguments (1 for 0)>
                                        C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:86:in deactivate' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in select_tool'
                                        C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in block in <module:CNC>' SketchUp:1:in call'
                                        C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC_Files/CNC_Profile_Defaults.txt
                                        Error: #<NoMethodError: undefined method outer_loop' for nil:NilClass> C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:535:in block in outside_offset'
                                        C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:468:in each' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:468:in outside_offset'
                                        C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:218:in mode' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:79:in activate'
                                        C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in select_tool' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in block in module:CNC'
                                        SketchUp:1:in `call'
                                        Greatly appreciate any help.
                                        Elisei (sketchupper)
                                        Come and See EliseiDesign
                                          @Elisei
                                          Open the file ../Plugins/CNC-profile.rb in Notepad or Notepad++ and at line #86 change:
                                          def deactivate
                                          to
                                          def deactivate**(view)**
                                          Find line #535 and change:
                                          vert = new_face.outer_loop.vertices
                                          to
                                          **if new_face;**vert = new_face.outer_loop.vertices**;else;vert = face.outer_loop.vertices;end**
                                          Save it and restart SketchUp.
                                          See if that helps... 😕
                                          • ely862meE Offline
                                            ely862me
                                            Seems like it is acting better but still no results.
                                            I have attached the model I am working on and also the error in the ruby console.
                                            Thank you !
                                            Girld contour.skp
                                            error.txt
                                            • 3 / 4
