    Bad wall rendering
    renderpluginsextensions
    11 Posts 7 Posters 1.1k Views 7 Watching
      PsyHope
      Hello,
      please help, i have this problem for quite a while and it's taking me back in my work.
      When i render indoor scenes i get noisy weird splashes on the walls (see attachment).
      I tried changing material, adding texture and changing camera settings but nothing
      seemsto work.
      Please if you know whats going on answer...
      Thanks ... 😄
      • cottyC Offline
        cotty
        You should mention the used renderer...
        my SketchUp gallery
          PsyHope
          vray renderer
          • BoxB Offline
            I know nothing about Vray, but check that you don't have the wall faces reversed. Some renderers can't cope with back faces.
              PsyHope
              Already checked both normal and reversed. thanks anyway
              • F Offline
                Factorycat
                This is to do with 'subdivs'. There are many settings in VRay which could be tweaked to improve your render. To start click on your light source and under the rollout look for 'Sampling' increase the subdivs from the default is 8. Increase this to 16 and take a test render. The higher you go the longer the render will take.
                There are lots of tutorials out there on Google and YouTube that will help you with this.
                  thegreek87
                  Nomeradona done a quick tutorial on his website
                  http://sketchupvrayresources.blogspot.co.uk/2011/07/trick-removing-splotches-in-vray.html
                  http://www.nicholasvaisey.co.uk/.
                  • JonFarJ Offline
                    JonFar
                    try increasing the subdivs and samples in the Irradiance map, here:
                    the values will depend on the scene and will increase rendering time a little bit but try something like
                    HSph. subdivs to 64
                    Interp. samples to 40
                      PsyHope
                      i think the problem i solved.
                      i set HSph. subdivs to 64 and Interp. samples to 40 and everyrhing rendered ok.
                      i ll try more renderings and get back
                        PsyHope
                        HSph. subdivs to 64 / Interp. samples to 40
                        that fixed the problem...
                        thanx
                        • TedVitale_CGT Offline
                          TedVitale_CG
                          There are a bunch of tutorials on the website: http://help.chaosgroup.com/vray/help/sketchup/150PB/tutorials.htm
                          This topic is covered by our interior rendering tutorial. Take a look, there's a lot of really helpful tutorials there. Also, let me know if there are specific tutorials you would like me to put together!
                          Ted Vitale
                          Owner | Creative Director
                          http://www.voxl.vision
