    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 37.5k Views 21 Watching
    • Bob JamesB Offline
      Bob James
      @the.pjt
      3Pts_Tools is a great tool set (yours and Sam's) and the toolbar.
      Comments:
      1. Works fine in SU13, but the cylinder creation is somewhat counter-intuitive: In the Box Tool the base is created first, then the height. In the Cylinder Tool it is the opposite: the height is created first, then the radius. Not a deal-breaker, but it would be better (IMO) if they were both in the same order; base, then height.
      2. In SU13 it works whether in the 'standard' plugin folder or in an 'additional' folder. In SU14 it does not load successfully in either location: I get load errors in either folder.
      • sdmitchS Offline
        sdmitch
        In the case of the cylinder, the definition of the height also defines the normal for the cylinder. If you were only doing cylinders oriented along one of the axes, then you could just as easily do it the other way.
        I think I have found and fixed the bug in Rotated Box that caused the box to be displaced when dimensions were keyed in.
        http://sdmitch.blogspot.com/
          dedmin
          Can the default be NOT to add to a group? It is very frustrating!
          • sdmitchS Offline
            sdmitch
            Yes of course. Using Notepad, change the line "@group_box = true" to "@group_box = false".
              dedmin
              β˜€ πŸ‘
                dedmin
                Love this - using it all day long to build furniture from ply and sheet goods!
                One wish - to draw the height of the box from the center, not just up or down.
                Thanks.
                • sdmitchS Offline
                  sdmitch
                  Thanks.
                  Do you mean the height value entered would be half the desired height? Would this always be the case?
                    dedmin
                    Thanks.
                    I mean - the value entered would be the desired one, just drawn in half up and down.
                    • sdmitchS Offline
                      sdmitch
                      @dedmin said:
                      Thanks.
                      I'm sorry but that makes no sense.
                        dedmin
                        For instance - to draw a shelf centered on the side. This is Rhino:
                        • sdmitchS Offline
                          sdmitch
                          [attachment=0:u6oxrafv]<!-- ia0 -->selection_toys.gif<!-- ia0 -->[/attachment:u6oxrafv]
                          Thanks for the graphic. At least it makes sense now.
                          I have sent you, by Personal Message, a modified copy that I think does what you want.
                          • designerbursaD Offline
                            designerbursa
                            Toolbar 😎 rotated box plugin πŸ˜‰
                            Rotated_Box.zip
                            • 4 / 4
