    Follow me modeling problem
    14 Posts 6 Posters 879 Views 6 Watching
    • benjanowitzB Offline
      benjanowitz
      Thanks guys, but I'm almost giving up...
      I've tried to put exactly at the center and it's always the same:
      a real mess!!
      I've attached to you the skp file, give it a look, if you want...
      bbbbb.skp
      • BoxB Offline
        Dave's right, I can reproduce your error by selecting the profile then the circle. You need to do it the other way around as Dave has described.
        I would think carefully about your Level Of Sketchup choice in your profile.
        How experienced you appear to be makes a difference to how questions are answered.
          benjanowitz
          Thanks everyone, I was mistaken tha way of follow me works...
          Another quick question: How do I manage to have on the bamboo the arc top, like this one:
          Instead of this:
          Thanks again!
            Are you sure of your section ?
            Intersect a sphere ?
              The profile in the SKP file you posted already had the required shape. Why go through another process to make it? As I wrote before, you don't need anywhere near as many segments in your curves as you've drawn. 😒
                benjanowitz
                All those segments are motivated 😄
                I usually export 2d views of my projects in PDF and then open them in Illustrator.
                So the more segments I have the better the quality and precision of editing is.
                  Then, as I already told you, you'll have to scale your model up in order to get the faces to be created.
                  If you're going to use the drawing as a 2D thing, I don't see any point in making it 3D first.
                    benjanowitz
                    Cause I'm doing my thesis with a particular graphic approach: almost b&w or less colors possible.
                    So in order to achieve this, I have to export my "3d views", as a snapshots and then edit them on illustrator (via PDF, which is fully editable) and giving them Black fill and White lines as strokes.
                    this is an example:
                    http://www.sanrocco.info/i/axo/SR_Mistakes_Figini.jpg
                    • pbacotP Offline
                      This work?
                      As far as the bamboo is concerned, the example is a 2d graphic representation--not a real 3d view. The arc in the top is suggestive, not real. To simulate you have take the 3d view, then blank out the arc in the top in AI.
                        benjanowitz
                        You guys are great. Thanks everyone, seriously.
                        Yea, I know about changing colors in the Style menù, but not every object in the 3D-2D view is all black, sometimes there are some primary colors. So I have to put them on AI...
