    BuildEdge PLAN 3.0 Now Available!
    55 Posts 15 Posters 13.2k Views 15 Watching
    • aarondietzenA
      aarondietzen
      @utiler said:
      Hi Aaron, happens every time I open it. Not sure what's happening so I hope you have some suggestions!
      Great work on development; its really coming along nicely!! 👍
      Hi Andrew,
      Can you send me the .log files in your C:\Users"user name"\AppData\Roaming\BuildEdge\Plugins\SketchUp\BuildEdgePLAN folder?
      Just email those directly to me (adietzen@keymark.com) and we can see why Java is not initializing on your machine.
      Yes every time I Launch SU! 😮
      So for avoid this I can stay On Su 24 h / 24 h (not very ecologic! 💚
      So an authorisation the firt time will be some better! 😉
      Ok all that explain the remarks! 😄
      Wait! Are you suggesting that you actually DO shut down SketchUp??? I thought you kept it running all day, every day!
      Obviously, that is not ok... for what it;s worth, you are the first person I have heard this from! I will check with our development guys and see how we should go about tracking this down.
      Sorry for the inconvenience, guys, but thank you for the quick feedback! Hopefully I can get you running quickly!
      "Imagination is more important than knowledge..."
      - Albert Einstein
        mwm5053
        Not sure whats going on here when I select add window I get a circle with a slash thru it, the wall has not been committed to SU so I'm able to add doors move them just the add window not working any suggestions
        Problem solved height of window and window height where the same 6'8" I'm not sure how that happened.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • utilerU
          utiler
          Aaron, that was happening a lifetime ago.... no probs now. 👍
          Just Curious...
          • H
            Helle
            I just bought BuildEdge 3.0. I cannot insert any windows, no matter what I do? Tried to change template to inches etc. but nothing matters. Does anybody have a solution, please
              mwm5053
              It did that to me too. Make sure height of window is not the same as top of window. I think when start out default are the same height.
              2011 iMac
              V2 Twilight
              • H
                Helle
                I got it .... it was me.... from the bottom up regarding window height
                  mwm5053
                  2011 iMac
                  V2 Twilight
                  • deaneauD
                    deaneau
                    Hello Aaron,
                    at first i love the Plugin.. in 2013 work fine however at 2014 ...
                    Hello,
                    BuilEdgePlane have a big BUG in 2014. If I insert a windows some dividers will place in the windows and the other dividers will place near on the zero point. so i can not work with this plugin.
                    other problem. the BEP-Windows will be ever active than non active etc. sometimes the value will accepted and somtimes not.
                    please fix this i use 2014 make at home.
                    reagards
                    Dean
                    p.s. look at Sophie some of the dividers will stay there.
                    • U
                      unearthed
                      This looks like it could really save me some time, but this is a worry:
                      Unfortunately, we do authorize the software
                      I live/work in a remote location with local satellite access (which is not 100% reliable) I never purchase software that needs to handshake on startup or requires a livelink. So...is BuildEdge still like this?
                      Growplan - People ∩ Plants ∩ Place
                      windows 7 64b, 4GB RAM, SU 8.0.16846
                      Gimp, QGIS, Vectorworks 12, Bricscad 11
                      • U
                        unearthed
                        Waiting, wainting...still no answer since last week AND I sent the same query as an email.
                        • aarondietzenA
                          aarondietzen
                          Hi Unearthed,
                          Sorry, I don't regularly read through this forum looking for posts about BuildEdge. Also, as luck (bad luck, that is) our "Contact Us" page is broken and we are not receiving emails! For future reference, submitting a ticket to Help Desk through our main site is the best way to get in touch with us.
                          As to your question, as of now, we are using the same security as we were before. You will need to be connected to the internet to initially authorize. After that, it will attempt to check in every few weeks to verify that you have not moved the security.
                          As long as you have a connection at install and are connected occasionally as you run, you should be good!
                          Thanks,
                          Aaron
                          - Albert Einstein
                          • pbacotP
                            That is great-- if it actually works. Continuous connection is not given, even when your provider has promised it. Also I have some software that requires me to refresh the license by going to the website, every time I move my laptop to my office or home. Not too nice.
                            • U
                              unearthed
                              Thanks Aaron, that sounds more useable
                              • aarondietzenA
                                aarondietzen
                                Glad that helps, Nigel.
                                I know that it is not the perfect solution, and that security, of any kind, can be a pain, but we have attempted to create a solution that is as easy as possible and a staff that is quick to respond to customer issues (when our site is not dumping our contact us emails, that is!).
                                Hopefully security does not cause too many issues for you all,
                                Thanks,
                                Aaron
                                - Albert Einstein
                                • deaneauD
                                  deaneau
                                  What about an Bugfix, since i have pay this i have never work withis
                                  404 Not Found
                                  (sketchucation.com)
                                  per email have tell me, that we solve the problem in june or July...now we have August.
                                  the30 day money-backguaranty is end in april. is this service?
                                  have i pay bugs or a plugin? 👎 sorry
                                  • aarondietzenA
                                    aarondietzen
                                    Hi Deaneau,
                                    We ARE working on a new version but, as often happens in software development, it is taking a little longer than I had originally hoped.
                                    Judging from the picture above, it looks like you have a corrupted dynamic component.
                                    Submit a ticket to our help desk here: http://www.buildedge.com/help/index.php?a=add
                                    The guys on the help desk should be able to get this fixed and get your windows looking nice again.
                                    Thanks,
                                    Aaron
                                    - Albert Einstein
                                    • deaneauD
                                      deaneau
                                      @aarondietzen said:
                                      Hi Deaneau,
                                      Thanks,
                                      Aaron
                                      aaron, look march or april, i have send this bug, this is not a corrupted component its more of a bug.
                                      i have only a new document without any other objects. i have have never sent so many bugreports to a developer. 👎
                                      • aarondietzenA
                                        aarondietzen
                                        Hi Deaneau,
                                        Can you Let me know the name that you are submitting these tickets under (you can PM me if you would rather keep that private). I cannot find the issue in our help desk log, so I am wondering if you are having an issue submitting a ticket.
                                        I am sure that, once we get you in touch with our help desk, we can get your issue straightened out and get you running like new.
                                        Sorry for any inconvenience!
                                        Aaron
                                        - Albert Einstein
                                        • deaneauD
                                          deaneau
                                          @aarondietzen said:
                                          Hi Deaneau,
                                          Aaron
                                          you and Brendon.S have had answer.. we are working on this problem....
                                          dean
                                          • deaneauD
                                            deaneau
                                            All problems with the plug in was solved.
                                            thank you at the marvelous support.
                                            regards dean
                                            • 3 / 3
