    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Fooling about
    38 Posts 6 Posters 6.1k Views 6 Watching
        Both are sound files driving displacement on a sub-d mesh.
        Interesting effect
        • massimoM Offline
          massimo Moderator
          πŸ‘ πŸ˜„
            With what all this is made ?
              @Pilou
              Musique et Blender
                AaaH! ok! πŸ˜„
                • olisheaO Offline
                  olishea
                  I really wish I had my volume turned down. I nearly fell out my chair!! Really like the first render. So simple but well executed. πŸ‘
                  oli
                    @oli
                    close to the ideal voronoi workflow
                      @olishea said:
                      Can you do it with any shape object?
                      Yes, within reason
                      @olishea said:
                      do you know a way of reliably exporting quads from SU?
                      It begs the question.... export to what format into what app?
                      • olisheaO Offline
                        olishea
                        Sweet! it's really not easy is it! I don't know why I even tried doing it in SU all those months ago. Can you do it with any shape object?
                        I managed to do it wings but I find it easier in meshlab, although it still takes hours.
                        Also, do you know a way of reliably exporting quads from SU? Always bloody triangles! πŸ˜†
                        Here is a voronoi bangle. Only Β£180 to 3D print. πŸ˜•
                        oli
                        • olisheaO Offline
                          olishea
                          SU to OBJ to meshlab
                          SU to OBJ to wings
                          SU to STL to meshlab
                          SU to STL to wings
                          Even wings to OBJ to meshlab results in triangles. Which is the most appropriate file type?
                          Untriangulation works perfectly in wings, but when I export again the quads turn into tris.
                          oli
                            STL doesn't support quads unless the tri'd face is coplanar
                            OBJ does.. You can export to Blender Quads as OBJ with QuadFace Tools. But firt the mesh needs to be QF compliant
                            • olisheaO Offline
                              olishea
                              Ah i see! thanks for the info, really helpful. One day we will see real quads in SU. One day.
                              oli
                                Quads in SU is easy once u adopt the strategy.
                                AutoSmooth helps a lot. So does vertex tools.
                                • olisheaO Offline
                                  olishea
                                  Yeah because I'm making sure my model contains 100% quads before subd and almost 100% quads after subdivision and even then they are actually triangles when I export it. Even if the model is symmetrical, the triangles are not. I wouldn't even be bothered if the triangles were somehow symmetrical along the mirror line! I always have to remesh my SU export. Can you perform isotropic surface remesh in blender? now that's how you'd get a perfect voronoi or snakeskin every time! πŸ˜†
                                  oli
                                    I don't yet refind but someone had made an animation like the "waves wire lines" with Soap Skin Bubble! πŸ˜„
                                    • olisheaO Offline
                                      olishea
                                      I remember it was awesome!! Back in the day eh Pilou! πŸ‘ πŸ˜„
                                      oli
                                        Yep! β˜€
                                        That was this guy! Amr Sallakh 😎
                                          • olisheaO Offline
                                            olishea
                                            what was the question? nice wind!
                                            oli
