    [Plugin] DrawAlong - v1.2a - 12 Oct 14
    32 Posts 15 Posters 37.9k Views 15 Watching
      Epic. Thanks Frederic
      • F
        function
        fredo is on fire! moveAlong, now this! thanks fredo
          rv1974
          truly outstanding! 😲
          • pbacotP
            Looks stupendous!
              Again a new French hit! 😎
              This time video is not bilanguage! πŸ˜‰
              • PixeroP
                Pixero
                Wow! Another amazing tool from the master.
                I'd like to be able to draw freehand on a plane without inference. Would that be possible?
                • Bob JamesB
                  Bob James
                  I know for sure what's going to happen to my shortcut "L" 😎 πŸ˜†
                  • fredo6F
                    It should. That's the intention.
                    • PixeroP
                      Pixero
                      Am I missing something?
                      I meant like the freehand tool but without inference and on a plane.
                      Would be great for drawing outlines to trees and such on image planes.
                      • fredo6F
                        DrawAlong does not work in freehand mode, but rather pick and drag.
                        But FreehandOnSurface does support both modes, with and without inferences.
                        • cottyC
                          cotty
                          Video:
                          my SketchUp gallery
                          • B
                            Ben Ritter
                            Super cool Fredo!!. A big thank you.
                            • B
                              Ben Ritter
                              Fredo, I can enter model units (inches)for a line length, but as soon as I add a unit (feet), it gives me an error message.
                              • B
                                Ben Ritter
                                Disregard Fredo. I tried entering 5' as length and couldn't. I realized I have to enter it as 5'-O".
                                • fredo6F
                                  That's definitely a bug, which by the way existed in other plugins based on my VCB parsing.
                                  I fixed it and will republish.
                                  I am not familiar with the architectural notation, so I assume that the syntax is
                                  <x_in_feet>' <y_in_inch>", with or without a separating space.
                                  So the general case could be for instance: 10.5' 4.2" (which is roughly 3.31m).
                                  Where I don't know what to do is the fractional notation, because the / may clash with the divider. I understand you can enter something like 3' 1/4, but they may be extra syntax. I would need a crash course there.
                                  • pbacotP
                                    In other instances of using SU the / in fractions is not a problem Simplest you can type 5'2 1/2 and it should work. The space between numbers is important of course.
                                    There is another plugin TT Edge tools "divider" tool where the fraction divider is a problem and the tool adds multiples instead of the correct distance. The SU way is to wait for the return key then look for a multiplier input.
                                    I have become used to typing any simple combination of measurements and having it work both in CAD and SU. My CAD app will do simple arithmetic in the input. It's nice where the apps allow some switch hitting (say decimal feet instead of feet and inches--and short hand: leaving out unecesary or obvious key strokes) without worry.
                                    • fredo6F
                                      If I understand the syntax, I think I can make it.
                                      For instance what does mean 5'2 1/2
                                      Is it 5 feet and 2 inch and half an inch?
                                      [EDIT] I made some test in the Ruby console, and I am lost, because 5'2 does not look to be 5 feet and 2 inches!!
                                      "5'".to_l
                                      60.0
                                      "5'2".to_l
                                      138.74015748031496
                                      "5'2 1/4".to_l
                                      148.58267716535434
                                      • pbacotP
                                        That's right. The long hand version is usually 5'-2 1/2", but the hyphen is often dropped. So Ruby treats it differently?
                                        • fredo6F
                                          Less and less clear
                                          in the Ruby console
                                          a = "5'-2 1/4".to_l
                                          -8.8976377952756
                                          Anyway, whatever is the notation, I still don't understand why 5'2 1/4 = 138.74 inches, whereas 5' is just 60 inches.
                                          • fredo6F
                                            I found the explanation finally.
                                            The model was in unit "decimal" metre
                                            So if you type 5'2 1/4 it is misinterpreted by SU. I guess it takes the 1/4 for 1/4 of a metre.
                                            Anyway, if the model unit is Fractional, then it works and the 3 notations below would give 62.25 inches
                                            • 5'2 1/4
                                            • 5' 2 1/4
                                            • 5' 2.25"
                                            I have done the changes and will republish soon
