    [Plugin] SketchUcation Tools 2.6
    212 Posts 58 Posters 136.7k Views 58 Watching
    • 3 Offline
      3rdEye
      Hi @ all,
      I installed SketchUcation Tools 2.6 on a Win 8.1 machine in SU 8, when I start Su 8 the SketchUcation Tools 2.6 is creating the following file:
      C:\Users\Username\AppData\Local\temp\SCF\f_43864.vbs,
      and while my firewall asks me if i want to let it access the internet - and I say yes, SuTools is creating the next .vbs with a random number which makes my firwall asking - and so on...
      Why is that happening? Can I stop that?
      thanks, regards,
      3rdEye
        @3rdeye said:
        Hi @ all,
        thanks, regards,
        3rdEye
        v2.6.0 sends small data packets to the SCF server etc.
        In v2014 it can use Ruby2 methods.
        But in v8 it has to make temporary vbs files to do this in your ../Temp/SCF folder.
        They are automatically erased afterwards.
        If you add an 'exception' to your Firewall [or AntiVirus App] 'exceptions' list] it should let them pass unchallenged ?
        With a wild-card like: C:\Users\Username\AppData\Local\Temp\SCF\*.vbs
        I'll also PM you with some other ideas... BUT some VBS files must run to have all of the PluginStore functionality...
          JGA
          @rich o brien said:
          Can you tell us your Internet speed?
          It's fair to middling - part of a corporate network.
          TIG's given me some homework to test - I'll give it a go at the end of the day.
          Tweaks worked, problems relate to our internet access setup
          Regards,
          JGA
            JGA
            This a great plugin, especially the manager sections. I was wondering if the My Setup section could be explained in more detail?
            I don't seem to be able to download directly from the PluginStore into Sketchup with the plugin (I blame our IT security), but no bother through my browser. I then install through the archive installer. So far, so good.
            However, when I look at the My Setup, it doesn't note the Installed plugins. My profile is listed but Bundles has a solitary " (I'm presuming this is paid content).
            All of these I'm not fussed about, but is there a way I can manually update the list of installed plugins, so the Updates list can be used?
            Thanks again for sharing a great plugin.
            Regards,
            JGA
            • TandemT Offline
              Tandem
              Is there a page or post that explains the process of adding a plugin to the SketchUcation Plugin Store and Tools Plugin?
              • aadbuildA Offline
                aadbuild
                I"ll have to get PlusSpec available for everyone here.
                Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                https://www.plusspec.com
                • erikBE Offline
                  erikB
                  Finally updated from V8 pro to 2014 pro. Installed extension sketchUcation Tools 2.6, and get a lot of loading errors. Made sure (I think) all the 'rights' on the different directory's are set to 'full'. Still no luck. The toolbar appears but I can not install any plugins. Any thoughts anyone ?
                  System Win 7(64), SU 2014 pro
                  erikB
                  errors listing :
                  Error: #<LoadError: cannot load such file -- open-uri>
                  c:/users/sony/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in require' c:/users/sony/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in module:SCFapi'
                  c:/users/sony/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:22:in <main>' C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in eval'
                  C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in load' C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in block in <top (required)>'
                  C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in each' C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in <top (required)>'
                  C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                  C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in register_extension' C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in module:SCF'
                  C:/Users/SONY/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:16:in `<top (required)>'
                  • Dan RathbunD Offline
                    Dan Rathbun
                    Did you install SketchUp 2014 on a drive other than the SystemDrive ?
                    It might help if you could open the Ruby Console and type
                    puts $LOAD_PATH
                    Paste the output here.
                    I'm not here much anymore.
                    • erikBE Offline
                      erikB
                      Dan,
                      this is the result in the ruby console :
                      puts $load path
                      Error; #<SyntaxError; cannot load such file -- rubygems.rb
                      <main>; syntax error, unexpected tIDENTIFIER, expecting end-of-input
                      puts $load path
                      SketchUp;1;in `eval'
                      nil
                      I suspect now it has something to do with the trialversion of plusspec I had running and is now removed. They needed the rubygems. Perhaps I deleted something I shouldn't have done while removing the pluspec plugin.
                      The installation was done in the system drive.
                      erikB
                      • erikBE Offline
                        erikB
                        Sorry Dan my mistake I did a typo.
                        I I start SU I get the error codes as I mentioned before. If I continue the toolbar appears. I I then open the ruby console an click on the sketchucation plugin the ruby console says :
                        puts $load_path
                        nil
                        I I try to install a ruby (p.e. comments) the ruby console says :
                        c:/users/sony/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf-rbztools.rbs:1098:in require' c:/users/sony/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf-rbztools.rbs:1098:in loadHandler'
                        c:/users/sony/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf-rbztools.rbs:442:in loadFromURL' c:/users/sony/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf_dialog.rbs:72:in block in new'
                        SketchUp:1:in `call'
                        Thank you for looking in on it.
                        erikB
                          I think it's because you are using v2014 on a PC AND you open a SKP by double-click to launch SketchUp... AND that SKP is on a drive that is NOT where SketchUp.exe is installed. 😮
                          This is a known issue with v2014M0. 😒
                          This confluence of events causes SketchUp to add incorrect paths into $: for the two Ruby Lib folders at startup.
                          Then any of those Ruby scripts which are called by a ' require' can't be found.
                          It is expected to be fixed in the coming update v2014M1...
                          Because of this path-mess, some Plugins will not work if they use the new Ruby features available with Ruby2 which is shipped with v2014 - so in v2014 when the SCF PluginStore tries to use open-uri to ping data and download RBZ's etc it will fail...
                          Meanwhile, there is a fix = http://sketchucation.com/forums/viewtopic.php?p=519331#p519331
                          Download and place this .rb file into the v2014 Tools folder - typically it's
                          C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools
                          Then the $: will be reset as SketchUp starts, so that it always include the correct Ruby Lib paths [at least for non-Asian users]... 🤓
                          • erikBE Offline
                            erikB
                            Thanks TIG, you'r a miracle worker (as usual). 👍
                            Works like a charm now. Many thanks. Did not read that earlier post because I wasn't on 2014 so it did not matter. Had better done a search. 😳
                            erikB
                              Dan Rathbun
                              And, if you re-read what I said, .. I said to type:
                              puts $LOAD_PATH
                              (... notice how the global variable name is in ALL CAPS ?)
                              You can also (as TIG mentioned,) type
                              puts $:
                              (because $: is an alias for $LOAD_PATH.)
                              When things are good, the output will look like (except the username will differ,):
                              puts $;
                              C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib
                              C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific
                              C;/Users/Dan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                              C;/Users/Dan
                              nil
                              • erikBE Offline
                                erikB
                                Sorry Dan, lesson learned. 😳
                                I now get the same output in my ruby console. 👍
                                erikB
                                • F Offline
                                  FritsBee
                                  I was a SU 2013 user. And I didn't want to go to SU2014 because the plugins works different.
                                  I made the step and went to SU2014 but after installing SketchUcation 2.6
                                  It installs whell but after restart SU I get errors.
                                  These are the errors:
                                  c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in require' c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in module:SCFapi'
                                  c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:22:in <main>' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in eval'
                                  C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in load' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in block in <top (required)>'
                                  C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in each' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in <top (required)>'
                                  E:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' E:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                  C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in register_extension' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in module:SCF'
                                  C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:16:in `<top (required)>'
                                  What did I do wrong?
                                    @Frits
                                    The answer was a few posts earlier http://sketchucation.com/forums/viewtopic.php?p=524358%26amp;f=10#p524358
                                    Please read that... 🤓
                                    I suspect you have the same issue...
                                    If you start SketchUp from the SketchUp.exe rather than a SKP on another drive you should not experience the error.
                                    Adding the special 'fix' rb file into the Tools folder should resolve the issue until an update of SketchUp is released... 😒
                                      paddyclown
                                      Hi all, I have an odd anomaly...
                                      When I click on the button for sketchucation plugin store (i have v 2.6.0) I get the error
                                      "Navigation vers la page Web annulée
                                      Essayez la chose suivante :
                                      Actualisez la page. "
                                      (navigation to webpage cancelled, try following: reload page) - which I try to no avail...
                                      I went into the java config tool on my PC and tried activating/deactivating stuff & nothing doing, I also checked that sketchucation was authorised in the noscript plugin for firefox...
                                      very odd... it used to work
                                      thanks if anyone has a bright idea
                                        On a PC all web-dialogs use IE, irrespective of your preferred browser - like Firefox.
                                        Check your IE Internet Options settings...
                                        Allow javascript etc...
                                        Has your system or IE been updated recently ?
                                          paddyclown
                                          TIG yes, thanks; tried everything I can think of in IE (it is fully up to date as is my OS - I always let windows update do it's thing) I reset the security parameters in IE and checked in the JAVA config & all seems activated as it always was 😞
                                          The worst is it works on another computer running windows7 (which I hate) hého, maybe I should reinstall IE if I have some time to waste...
                                          It would be cool if in SU we could tell it to use Firefox or whatever as the browser....
                                          thanks anyway
                                          best,
                                            Gábor
                                            Might this explain the cause?
                                            http://answers.microsoft.com/en-us/ie/forum/ie11-iewindows8_1/navigation-to-the-webpage-was-cancelled-message/a9d1ea43-6f53-4f59-94b6-247eb3e757f1
                                            • 11
                                            • 8 / 11
