    • Anmelden
    SUbD - Non-destructive subdivision with creases and quads
    Geplant Angeheftet Gesperrt Verschoben Plugins
    79 Beiträge 25 Kommentatoren 14.6k Aufrufe 25 Watching
    Lade mehr Beiträge
    • Älteste zuerst
    • Neuste zuerst
    • Meiste Stimmen
    Antworten
    • In einem neuen Thema antworten
    Anmelden zum Antworten
    Dieses Thema wurde gelöscht. Nur Nutzer mit entsprechenden Rechten können es sehen.
      zuletzt editiert von
      Play piano during a sketchup session is a real task! 💚
      Seems you master the 2 actions with brio! ☀
      Does all this Ruby 2 ?
      1 Antwort Letzte Antwort Antworten Zitieren 0
      • panixiaP Offline
        panixia
        @thomthom said:
        Last on the todo list.
        @thomthom said:
        The one in the QuadFace Tools toolbar?
        yes.. that one.. 😎
          Well, you know - I have so much spare time to kill that I figured - "why not?". 😉
          I've only been developing in SU2014 Windows. Other platforms and SketchUp versions will be tested once I reach the stage of beta testing.
          At the moment I'm not sure if it will require SketchUp 2014 or not.
            @panixia said:
            Hey, if you insist on throwing money at me before it's done - by all means! 😄
            @panixia said:
            yes.. that one.. 😎
            It's a tool to draw non-planar quads. It's still in beta stage, but works ok.
            • panixiaP Offline
              panixia
              😆 I would have bought it since day -1.. as far as i can see is just as perfect as it is to buy..
              • pbacotP Offline
                Keep coming back to this thread, but each time there's only more drool on the floor.
                • andybotA Offline
                  andybot
                  any chance "loop cut and slide" is possible? There's add loop in Quadface Tools, but specifying where within the quad the loop goes would be HUGE! Anyhow, just dreaming 😄
                    Can you elaborate more? "slide"?
                    You mean like a insert loop by offset from reference edge?
                    • andybotA Offline
                      andybot
                      It's a Blender command. It allows you to place a loop by percentage distance between adjacent loops. Offset by distance from edge would be nice too 😄
                        jaceguay
                        Yes, it would be very usefull.
                        • StinkieS Offline
                          Stinkie
                          Oh, wow!
                            cuttingedge
                            😄 the hope for a cleaner model in SU acceptable to the high standard cg world.
                            • panixiaP Offline
                              panixia
                              the workaround i use in order to mimic this is to select the ring then use "connect edge" with 2 segments and the proper pinch, then "remove" the unwanted loop
                                Yea, that's awkward - need a better function.
                                • panixiaP Offline
                                  panixia
                                  maybe. but we love you anyway. just don't worry about this and focus on sub-d 💚
                                  can't wait 🎉
                                    Long time, no post. I just updated the topic with a new video 😄
                                    Live crease adjustment on the limit mesh
                                      Cool! 🤓
                                      • StinkieS Offline
                                        Stinkie
                                        Indeed. 👍
                                          Teasing! 😄
                                            Teasing! 😄
                                            • 4 / 4
                                            • Erster Beitrag
                                              Letzter Beitrag
