    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 146.7k Views 85 Watching
      bimbachi
      after instal / load errors:
      Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RSloader.rb
      private method gsub' called for nil:NilClassError Loading File PiGa_RichSection.rb private method gsub' called for nil:NilClass
      and ruby console :
      RS: START DEBUG
      RS0.4.1|2.479|
      Start Logfile____ __________________________________________
      /var/folders/vp/czvv48md4dz_zv8rgyxm_0h40000gp/T//RichSection_log.txt
      RS0.4.1|0.154|
      RichSection plugin __________________________________________
      #<SketchupExtension:0xecfc6d8
      @name="RichSection",
      @registered=true,
      @version="V0.4.1-RC-2014.04.20-20:30 DEMO",
      @loaded=false,
      @path="/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RSloader",
      @copyright=" 2013, All rights reserved for RichSection plugin : Name, code and functionality are the intellectual property of the author. Distribution, reproduction or integration of code or functionality, even partly, is only permitted with the explicit permission of the author",
      @description="Creats 'SECTION materials' based on 'layer' or 'nature' of groups and components (if section is a closed polygone). PROJECTs elements above the sectionplane as pointed lines. SECTION and PROJECTION are placed in a 'RichSection' group, respecting the same (nested) structure as the model. Switching layers 'on' and 'off' will swich the corresponding 'RichSection' information.",
      @load_on_start=false,
      @creator="Piet Garmyn, Luxembourg (pgarmyn)">
      RS0.4.1|0.004|
      User info____________________________________________________
      {"PATH"=>"/usr/bin:/bin:/usr/sbin:/sbin",
      "GOOGLE_GILD_RUNTIME_FRAMEWORK_ABSOLUTE_PATH"=>"/Library/Google/Frameworks/Gild.framework",
      "TMPDIR"=>"/var/folders/vp/czvv48md4dz_zv8rgyxm_0h40000gp/T/",
      "SHELL"=>"/bin/bash",
      "HOME"=>"/Users/tignaciuk",
      "USER"=>"tignaciuk",
      "LOGNAME"=>"tignaciuk",
      "SSH_AUTH_SOCK"=>"/tmp/launch-AjI9WA/Listeners",
      "Apple_PubSub_Socket_Render"=>"/tmp/launch-qOUkYE/Render",
      "DISPLAY"=>"/tmp/launch-hvrCBq/org.macosforge.xquartz:0",
      "COM_GOOGLE_CHROME_FRAMEWORK_SERVICE_PROCESS/USERS/TIGNACIUK/LIBRARY/APPLICATION_SUPPORT/GOOGLE/CHROME_SOCKET"=>"/tmp/launch-Qsk4v0/ServiceProcessSocket",
      "__CF_USER_TEXT_ENCODING"=>"0x1F6:29:42",
      "__CHECKFIX1436934"=>"1",
      "IG_ROOT"=>"/Applications/Google SketchUp 8/SketchUp.app/Contents/Resources"}
      RS0.4.1|0.040|PiGaRSection.start_debug :
      RS0.4.1|0.008|Logging to RubyPanel : true
      RS0.4.1|0.006|Logging to File : true
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/repair_broken_lines.rb:27: warning: don't put space before argument parentheses
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/repair_broken_lines.rb:42: warning: don't put space before argument parentheses
      (eval):2837: warning: parenthesize argument(s) for future version
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:16: warning: already initialized constant VERSION_PATTERN
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:21: warning: already initialized constant COLOR_GL_POLYGON
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:25: warning: already initialized constant COLOR_ALPHA
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:29: warning: already initialized constant RAYTEST_WYSIWYG
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:22: warning: already initialized constant TEMP_PATH
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:23: warning: already initialized constant THEME_DEFAULT
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:24: warning: already initialized constant THEME_GRAPHITE
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:31: warning: already initialized constant EVENT_WINDOW_READY
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:43: warning: already initialized constant EVENT_CALLBACK
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:70: warning: already initialized constant EVENT_OPEN_URL
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
      (eval):344: warning: don't put space before argument parentheses
      (eval):444: warning: don't put space before argument parentheses
      (eval):666: warning: don't put space before argument parentheses
      (eval):1221: warning: don't put space before argument parentheses
      (eval):1403: warning: don't put space before argument parentheses
      (eval):1627: warning: don't put space before argument parentheses
      (eval):2702: warning: don't put space before argument parentheses
      (eval):2703: warning: don't put space before argument parentheses
      (eval):2824: warning: don't put space before argument parentheses
      (eval):2845: warning: don't put space before argument parentheses
      (eval):935: warning: don't put space before argument parentheses
      (eval):936: warning: don't put space before argument parentheses
      (eval):939: warning: don't put space before argument parentheses
      (eval):943: warning: don't put space before argument parentheses
      (eval):1520: warning: don't put space before argument parentheses
      (eval):2496: warning: don't put space before argument parentheses
      (eval):2498: warning: don't put space before argument parentheses
      (eval):2531: warning: don't put space before argument parentheses
      (eval):2533: warning: don't put space before argument parentheses
      (eval):2973: warning: don't put space before argument parentheses
      (eval):2983: warning: don't put space before argument parentheses
      (eval):2994: warning: don't put space before argument parentheses
      (eval):3004: warning: don't put space before argument parentheses
      (eval):3102: warning: don't put space before argument parentheses
      (eval):3129: warning: don't put space before argument parentheses
      (eval):3138: warning: don't put space before argument parentheses
      (eval):3143: warning: don't put space before argument parentheses
      (eval):3220: warning: don't put space before argument parentheses
      (eval):3223: warning: don't put space before argument parentheses
      (eval):3226: warning: don't put space before argument parentheses
      (eval):3268: warning: don't put space before argument parentheses
      (eval):3269: warning: don't put space before argument parentheses
      (eval):3324: warning: don't put space before argument parentheses
      (eval):3325: warning: don't put space before argument parentheses
      (eval):3506: warning: don't put space before argument parentheses
      (eval):4556: warning: don't put space before argument parentheses
      (eval):4635: warning: don't put space before argument parentheses
      (eval):4997: warning: don't put space before argument parentheses
      (eval):5052: warning: don't put space before argument parentheses
      (eval):5096: warning: don't put space before argument parentheses
      (eval):5100: warning: don't put space before argument parentheses
      (eval):9026: warning: don't put space before argument parentheses
      (eval):9026: warning: parenthesize argument(s) for future version
      (eval):191: warning: don't put space before argument parentheses
      (eval):291: warning: don't put space before argument parentheses
      (eval):758: warning: don't put space before argument parentheses
      (eval):906: warning: don't put space before argument parentheses
      (eval):692: warning: don't put space before argument parentheses
      (eval):699: warning: don't put space before argument parentheses
      (eval):719: warning: don't put space before argument parentheses
      (eval):739: warning: don't put space before argument parentheses
      (eval):746: warning: don't put space before argument parentheses
      (eval):766: warning: don't put space before argument parentheses
      (eval):786: warning: don't put space before argument parentheses
      7
      (eval):3119: warning: parenthesize argument(s) for future version
      (eval):3142: warning: parenthesize argument(s) for future version
      key = Units
      value = 0.0
      and log files attached
      cheers
      RichSection_log.txt
      RichSection_log_140421-201054.txt
      RichSection_log_140421-200134.txt
        pgarmyn
        Thanks Bimbachi
        I'll work on it.
        Please, for readability,, don't copy the whole log in this post.
          Phil Rader AIA
          Got it loaded on my mac I'll kick the tires on it later. Thanks for the Mac version
          http://www.philrader.com
            pgarmyn
            Sorry, its not working yet on Mac.
              pgarmyn
              Hi all
              This version is for testing, and feedback please.
              • on mac
              • for those on Windows having problems to run this plugin
              This test version has logging switched on by default.
              A log-file is created, and can be opened.
              • Open the file (and save as) : Menu/Plugins/RichSection/Open logfile....
              • Copy the file. The file location is shown at startup (panel opening)and in the Ruby panel.
              Logging can be switched off in Menu/Plugins/RichSection/Settings.
              Please send the complete log file (RichSection_log.txt), not just the last lines.
              Thanks.
              %(#FF0000)[file deleted, not woking yet on
              april 24, 2014]
              • KrisidiousK Offline
                Krisidious
                I just couldn't believe that only I was having this problem and pgarmyn was not able to fix the issue. I removed all my plugins one more time and now the plugin works. I'll have to add the old ones back until I find the culprit of the conflict.
                By: Kristoff Rand
                  Krisidious
                  Ok... SO far I have narrowed it down to Artisan and EcoScorecard that are causing conflicts with Rich Section.
                  By: Kristoff Rand
                    pgarmyn
                    Thanks for testing and reporting this conflicts.... 👍
                    I will mention it in 'known issues' for this plugin
                      pgarmyn
                      Hi all
                      • on mac
                      If problems, i would be glad to receive the complete log file (RichSection_log.txt), not just the last lines.
                      I also added the spanish translation made by Santiago Molina (caronte01). Thanks Santiago, also for the other corrections! Everything ok in the spanish dictionary?
                      Thanks.
                      %(#FF0000)[file updated, on
                      april 26, 2014]
                      RichSection V0.4.3-RC for testing only
                        bimbachi
                        this time after instal all looks like ready to work. 😄
                        I started do same testing and learning how it works and ... crashed
                        however mac version is progress 😄
                        logs attached
                        cheers
                        RichSection_log.txt
                        RichSection_log_140427-140711.txt
                          pgarmyn
                          logs attached
                          cheers
                          Looks promising .... i was almost losing hope ! This is big news for me 😄. Thanks for testing and reporting bimbachi ❗
                          Can you give me some more information : What did produce the crash? Can you reproduce it again? What is the output in the ruby console?
                            bimbachi
                            logs attached
                            cheers
                            Yes it looks fine, give me some time to understand plugin functions, will keep you informed
                              caronte01
                              Hi Piet,
                              Great news, it works on the mac!!!!
                              Well, most of it. The console still shows some errors, and it is very slow(core2duo macbook from mid 2010), compared to my work pc (Core I7). Probably has to do with logging.
                              I can update an existing rich section, and I am currently creating a new one, but it is veeery slow (projection depth default should not be no limit, it makes rs veeery slow). Also, parameter change sort of works, but it will not update changes directly. The section has to be manually updated after closing the dialog.
                              Legend creation works
                              Info, does not work, it stops expecting start, but no indication on how to (enter, double click, right click)
                              What else should I check?
                              Great work!!!!
                              S
                              rs log
                              I'll keep testing
                                caronte01
                                Hi Piet,
                                I had a quick look at the translation. It needs some small adjustments. I'll fix it as soon as possible.
                                Cheers,
                                Santiago
                                  pgarmyn
                                  @caronte01 said:
                                  Hi Piet,
                                  I can update an existing rich section, and I am currently creating a new one, but it is veeery slow (projection depth default should not be no limit, ....it makes rs veeery slow). Also, parameter change sort of works, but it will not update changes directly. The section has to be manually updated after closing the dialog.
                                  Great work!!!!
                                  S
                                  [attachment=0:1sf5tz6w]<!-- ia0 -->log.txt<!-- ia0 -->[/attachment:1sf5tz6w]
                                  I'll keep testing
                                  You can try out without logging (RichSection/Settings >> file & console >> No), and switch only on for debugging if errors occure.
                                  I still have to make some more videos:
                                  • projection : for most, it can be swiched of; it make sense for plan view (i use it to show the beams under the next floorslab in grey pointed lines)
                                  • info : select the tool, a RichSection sectionplan (or the sectiongroup), and than (without shift) a group or componentinstance of your model. An info panel should explain which sectionmaterial was or will be applied, and why it was applied.
                                  • update on/off : only for moving, turning the sectionplan; for model changes : still manual update
                                    What else to test : use it and report what sequences don't work (error, crash, not as espected)
                                    About the spanish translation : you can do it in the excel file (without testing, and send it to me) or the .rb file (notepad, you can test). Keep a copy of the original rb : a missing \ or " will prevent the plugin to start.
                                    Thanks for reporting and translating
                                    Krisidious
                                    For some reason I'm not getting the faces of the section. The section cuts, it adds the projection but no faces.
                                    By: Kristoff Rand
                                      bimbachi
                                      @pgarmyn said:
                                      What did produce the crash? .... What is the output in the ruby console?
                                      crash probably related to complex "projection"
                                      this is ruby just after new restart of skp:
                                      RS0.4.3|0.567|Logging to RubyPanel : true
                                      RS0.4.3|0.005|Logging to File : false
                                      RS0.4.3|0.001|PiGaRSection.userFileLocations MAC : /Users/tignaciuk/Library/Application Support/SketchUp 8/Sketchup/Materials
                                      RS0.4.3|0.001|RSdefaultRSMats /Users/tignaciuk/Library/Application Support/SketchUp 8/Sketchup/Materials/RichSection-v0.3/#default.mat.skp : true
                                      RS0.4.3|0.001|Start loading lang files : /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/
                                      RS0.4.3|0.001|proc loadlang :
                                      RS0.4.3|0.001|loadlang EN : /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RichSectionLangEN.rb
                                      RS0.4.3|0.001|loadlang file exists : true
                                      RS0.4.3|0.003|Nesting:[] :
                                      RS0.4.3|0.001|Nesting:[PiGa::RSection] :
                                      RS0.4.3|0.001|language loaded : EN
                                      RS0.4.3|0.002|Define context menu :
                                      RS0.4.3|0.001|Define toolbar + menu :
                                      RS0.4.3|0.003|rsMenu.add_item(:RS_menu) : #Sketchup::Menu:0x12402bb4
                                      RS0.4.3|0.001|rsMenu.add_item(cmdCreate) : 50346
                                      7
                                      key = Units
                                      value = 0.0
                                        bimbachi
                                        (mac) same for me, it apears only after manual update
                                          pgarmyn
                                          For SU 8 and Mac, you need the last test version. It will become the next official version.
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p522628
                                          You can switch off logging in the settings.
                                          Still problems?
                                            Krisidious
                                            Yes, that's the version I'm on.
                                            By: Kristoff Rand
                                            • 19
                                            • 20
                                            • 7 / 20
