    Low cost compact flat pack home
    30 Posts 11 Posters 5.8k Views 11 Watching
    • KrisidiousK
      Krisidious
      Well, yours might be the low end, but it looks like the top end... I would much rather have one of yours.
      By: Kristoff Rand
      • RichardR
        Richard
        Though to be honest mate, it seems simple but I've pulled my hair out to get all to work with such standard material sizes so as to minimise waste. Seems that you are always chasing a lost 100mm (4") and then something doesn't line up and I am so anal with things not aligning. And that even goes to standard dining tables etc aligning when placed with window doors and joinery grids. I've got to get over it I think!
        BUILTBRAND.COM.AU
        • pbacotP
          Richard,
          You'd never make it in remodel. You'd go nuts cause nothing is square, lines-up, or even fits (sometimes).
          • KrisidiousK
            Krisidious
            That's the truest form of efficient housing, is to incorporate size standards throughout. However, it doesn't help if those bidding don't take that into consideration and want to be efficient. I've done that one my starter homes and then I see the bids and I'm 😲
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              @pbacot said:
              Richard,
              pbacot... My two favorite words in remodel... field verify.
              By: Kristoff Rand
                AirWindSolar
                Imagine working solar array design with a guy who insists on trying to wedge modules into a space with less than an inch of tolerance, then throws a tantrum when it won't work because his sales rep that did the site eval was a foot or more off with the measurements.
                Takes about a half dozen of them from the same rep before the tantrum can be redirected at the "poor overburdened" sales rep, too. Never mind that most of them are now hauling around $2-300 worth of just measuring equipment, (measuring wheel, digital measure, etc.) and the install crew is able to get excellent measurements with a $20 tape measure.
                • GarethG
                  Gareth
                  You've taken on the purest form of housing, by that I mean 'simplicity' is the purest form.
                  It is difficult and extremely challenging.
                  When I was a student in the '70's we had an assignment to design a caravan.....I believe it was one of the most difficult things I have ever had to do.
                  I have never enjoyed designing large houses for the wealthy....they are invariably indulgent and wasteful of materials.
                  By the way mate, there is nothing wrong with being a bit OCD and anal about modules, wastage, grids, zones etc....that is exactly what is required to produce good work...! πŸ‘
                  • jo-keJ
                    jo-ke
                    I like the clear render with just indirekt light.
                    http://www.zz7.de
                    • RichardR
                      Richard
                      Mate stuff ups would drive me NUTS!
                      BUILTBRAND.COM.AU
                      • RichardR
                        Richard
                        @pbacot said:
                        Richard,
                        Pull down the bit's that don't align!! Easy! πŸ˜„
                        BUILTBRAND.COM.AU
                        • RichardR
                          Richard
                          Thanks Gareth, yeah like yourself, I love to create space rather than wonder how to fill it! Make the big from the small!
                          Certainly reducing waste comes back as returns or savings when a home is to be mass produced. That has also be fun, thinking of how everything can go together with least effort and detail. Whilst considering how to have it be assembled by anyone without error!
                          BUILTBRAND.COM.AU
                          • RichardR
                            Richard
                            Here is a scale model of the home. I wanted something robust and solid so tried coreflute, though it is normally a bitch to consider modeling with, I ended up developing a very sturdy concealed joint. This is as sturdy as tupperware, plus if I print the externals or drawing to paper I can actually wrap each wall, and the way it all clips together holds it in place!
                            Windows can be cut in, the vertical open flutes then give a trench for a piece of cut acrylic to be snapped in!
                            I just need to swap out the pins with some tidy ones and presto! Very quick, clean and solid as!!!! πŸ‘
                            BUILTBRAND.COM.AU
                            • jeff hammondJ
                              how do the sections lock together? bolts and stuff and etc?
                              it'd be sweet to design a locking bracket of sorts that works on all the pieces.. one tool.
                              [edit] though i guess i'm thinking of it being modular as in it will be set up in multiple locations.. when really, it probably only needs assembled once [/edit]
                              that aside, i think it looks awesome.
                              πŸ‘
                              • RichardR
                                Richard
                                πŸ‘
                                Jeff, the panels are jointed with a vertical 45x90mm timber stud and nail fixed both sides. Pretty fast, and yes just assembled once!
                                BUILTBRAND.COM.AU
                                • jeff hammondJ
                                  hey.. do you watch this show out of new zealand called The Art of the Architect ?
                                  • RichardR
                                    Richard
                                    No mate we haven't get it, i'll see if I can check it out!
                                    BUILTBRAND.COM.AU
                                    • jeff hammondJ
                                      it's basically just a camera crew following different architects around from development through construction phases of high dollar homes being built in new zealand.. a couple of the episodes have been pretty sweet.. you'll see sketchup being used by most of the architects at some point.
                                      • RichardR
                                        Richard
                                        Yeah I checked online mate, though it isn't available in our location! 😞 I'm keen to check it out though!
                                        BUILTBRAND.COM.AU
                                        • olisheaO
                                          olishea
                                          Love your models Richard. People normally bastardise coreflute as a modelling material but you've executed it very nicely.
                                          oli
                                          • RichardR
                                            Richard
                                            Dont worry mate, I was too! In the end finding a solution to jointing made it viable!
                                            BUILTBRAND.COM.AU
