    Low cost compact flat pack home
    30 Posts 11 Posters 5.5k Views 11 Watching
    • RichardR Offline
      Richard
      Yes mate we have some companies doing some AMAZING stuff. By rule of thumb though they are a STACK more expensive. The design I'm working on is a the lowest end of the market! Have never figured quite why as the transport is not a killer! I've often wondered if it is the offsite space cost when building!
      BUILTBRAND.COM.AU
      • alvisA Offline
        alvis
        well, the house is designed for any climate? much usable living space?
        • RichardR Offline
          Richard
          Mate the home is really well insulated with double glazed windows. Though it isn't desgined for the worst of climatic conditions it should preform well.
          Living space wise, it's designed. The home comes with ALL joinery including living area entertainment system furniture, plus it's designed around the most common sized furniture.
          BUILTBRAND.COM.AU
          • KrisidiousK Offline
            Krisidious
            Well, yours might be the low end, but it looks like the top end... I would much rather have one of yours.
            By: Kristoff Rand
            • RichardR Offline
              Richard
              Though to be honest mate, it seems simple but I've pulled my hair out to get all to work with such standard material sizes so as to minimise waste. Seems that you are always chasing a lost 100mm (4") and then something doesn't line up and I am so anal with things not aligning. And that even goes to standard dining tables etc aligning when placed with window doors and joinery grids. I've got to get over it I think!
              BUILTBRAND.COM.AU
              • pbacotP Offline
                Richard,
                You'd never make it in remodel. You'd go nuts cause nothing is square, lines-up, or even fits (sometimes).
                  Krisidious
                  That's the truest form of efficient housing, is to incorporate size standards throughout. However, it doesn't help if those bidding don't take that into consideration and want to be efficient. I've done that one my starter homes and then I see the bids and I'm 😲
                  By: Kristoff Rand
                    Krisidious
                    @pbacot said:
                    Richard,
                    pbacot... My two favorite words in remodel... field verify.
                    By: Kristoff Rand
                      AirWindSolar
                      Imagine working solar array design with a guy who insists on trying to wedge modules into a space with less than an inch of tolerance, then throws a tantrum when it won't work because his sales rep that did the site eval was a foot or more off with the measurements.
                      Takes about a half dozen of them from the same rep before the tantrum can be redirected at the "poor overburdened" sales rep, too. Never mind that most of them are now hauling around $2-300 worth of just measuring equipment, (measuring wheel, digital measure, etc.) and the install crew is able to get excellent measurements with a $20 tape measure.
                      • GarethG Offline
                        Gareth
                        You've taken on the purest form of housing, by that I mean 'simplicity' is the purest form.
                        It is difficult and extremely challenging.
                        When I was a student in the '70's we had an assignment to design a caravan.....I believe it was one of the most difficult things I have ever had to do.
                        I have never enjoyed designing large houses for the wealthy....they are invariably indulgent and wasteful of materials.
                        By the way mate, there is nothing wrong with being a bit OCD and anal about modules, wastage, grids, zones etc....that is exactly what is required to produce good work...! πŸ‘
                        • jo-keJ Offline
                          jo-ke
                          I like the clear render with just indirekt light.
                          http://www.zz7.de
                          • RichardR Offline
                            Richard
                            Mate stuff ups would drive me NUTS!
                            BUILTBRAND.COM.AU
                            • RichardR Offline
                              Richard
                              @pbacot said:
                              Richard,
                              Pull down the bit's that don't align!! Easy! πŸ˜„
                              BUILTBRAND.COM.AU
                              • RichardR Offline
                                Richard
                                Thanks Gareth, yeah like yourself, I love to create space rather than wonder how to fill it! Make the big from the small!
                                Certainly reducing waste comes back as returns or savings when a home is to be mass produced. That has also be fun, thinking of how everything can go together with least effort and detail. Whilst considering how to have it be assembled by anyone without error!
                                BUILTBRAND.COM.AU
                                • RichardR Offline
                                  Richard
                                  Here is a scale model of the home. I wanted something robust and solid so tried coreflute, though it is normally a bitch to consider modeling with, I ended up developing a very sturdy concealed joint. This is as sturdy as tupperware, plus if I print the externals or drawing to paper I can actually wrap each wall, and the way it all clips together holds it in place!
                                  Windows can be cut in, the vertical open flutes then give a trench for a piece of cut acrylic to be snapped in!
                                  I just need to swap out the pins with some tidy ones and presto! Very quick, clean and solid as!!!! πŸ‘
                                  BUILTBRAND.COM.AU
                                  • jeff hammondJ Offline
                                    how do the sections lock together? bolts and stuff and etc?
                                    it'd be sweet to design a locking bracket of sorts that works on all the pieces.. one tool.
                                    [edit] though i guess i'm thinking of it being modular as in it will be set up in multiple locations.. when really, it probably only needs assembled once [/edit]
                                    that aside, i think it looks awesome.
                                    πŸ‘
                                    • RichardR Offline
                                      Richard
                                      πŸ‘
                                      Jeff, the panels are jointed with a vertical 45x90mm timber stud and nail fixed both sides. Pretty fast, and yes just assembled once!
                                      BUILTBRAND.COM.AU
                                        hey.. do you watch this show out of new zealand called The Art of the Architect ?
                                        • RichardR Offline
                                          Richard
                                          No mate we haven't get it, i'll see if I can check it out!
                                          BUILTBRAND.COM.AU
                                            it's basically just a camera crew following different architects around from development through construction phases of high dollar homes being built in new zealand.. a couple of the episodes have been pretty sweet.. you'll see sketchup being used by most of the architects at some point.
