    Low cost compact flat pack home
    30 Posts 11 Posters 4.9k Views 11 Watching
    • RichardR Offline
      Richard
      Here is a scale model of the home. I wanted something robust and solid so tried coreflute, though it is normally a bitch to consider modeling with, I ended up developing a very sturdy concealed joint. This is as sturdy as tupperware, plus if I print the externals or drawing to paper I can actually wrap each wall, and the way it all clips together holds it in place!
      Windows can be cut in, the vertical open flutes then give a trench for a piece of cut acrylic to be snapped in!
      I just need to swap out the pins with some tidy ones and presto! Very quick, clean and solid as!!!! πŸ‘
      BUILTBRAND.COM.AU
      • jeff hammondJ Offline
        how do the sections lock together? bolts and stuff and etc?
        it'd be sweet to design a locking bracket of sorts that works on all the pieces.. one tool.
        [edit] though i guess i'm thinking of it being modular as in it will be set up in multiple locations.. when really, it probably only needs assembled once [/edit]
        that aside, i think it looks awesome.
        πŸ‘
        • RichardR Offline
          Richard
          πŸ‘
          Jeff, the panels are jointed with a vertical 45x90mm timber stud and nail fixed both sides. Pretty fast, and yes just assembled once!
          BUILTBRAND.COM.AU
            hey.. do you watch this show out of new zealand called The Art of the Architect ?
            • RichardR Offline
              Richard
              No mate we haven't get it, i'll see if I can check it out!
              BUILTBRAND.COM.AU
                it's basically just a camera crew following different architects around from development through construction phases of high dollar homes being built in new zealand.. a couple of the episodes have been pretty sweet.. you'll see sketchup being used by most of the architects at some point.
                • RichardR Offline
                  Richard
                  Yeah I checked online mate, though it isn't available in our location! 😞 I'm keen to check it out though!
                  BUILTBRAND.COM.AU
                  • olisheaO Offline
                    olishea
                    Love your models Richard. People normally bastardise coreflute as a modelling material but you've executed it very nicely.
                    oli
                    • RichardR Offline
                      Richard
                      Dont worry mate, I was too! In the end finding a solution to jointing made it viable!
                      BUILTBRAND.COM.AU
                      • david57D Offline
                        david57
                        I was just reading a new article and reminded me of your work.
                        http://www.bbc.com/news/blogs-news-from-elsewhere-27156775
                        • 2 / 2
