    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 673.1k Views 121 Watching
    • fredo6F Offline
      @dedmin said:
      Object disappears when hitting Esc two times while using ThruPaint
      SU 2014 Pro, Win 7 64bit SP1 Ultimate
      [attachment=0:3relfv60]<!-- ia0 -->Video_2014-03-26_132637.wmv<!-- ia0 -->[/attachment:3relfv60]
      Escape performs an Undo. So this may be related to making sure it does not go to far back in the Undo stack. I'll check this problem.
        dedmin
        See the video.
        Video_2014-03-26_151418.wmv
        • fredo6F Offline
          That's a consequence of enabling 'Auto-Exit' when there is a pre-selection (which is not the default).
          Maybe I will use this fast-mode only for Make Curve and Explode Curve, and ignore it for other Tools.
          • fredo6F Offline
            There must be a bug somewhere, but in general, painting boxes correctly in continuity on all its faces is very tricky.
            Trying with your model, I noticed the flipping and I'll have a look at it.
            What I suggest is that you just paint the last face directly, instead of extending it from adjacent faces.
            • fredo6F Offline
              NEW RELEASE: FredoTools v1.8c - 17 Apr 14
              FredoTools 1.8c is a release for MoveAlong v1.0.
              • KrisidiousK Offline
                Krisidious
                You soooo rock...
                By: Kristoff Rand
                  Ben Ritter
                  Thank you again.πŸ˜„
                  • fredo6F Offline
                    NEW RELEASE: FredoTools v1.8e - 20 Apr 14
                    FredoTools 1.8d is a release fixing a problem in MoveAlong v1.0.
                    The issue was about moving a selection containing a huge number of entities, as signaled by rv1974.
                    • OxerO Offline
                      Oxer
                      Thanks for the new version and new tool Move Along πŸ‘
                      I have made a new Spanish Language (Spain) file to include the new tool.
                      • fredo6F Offline
                        Oxer,
                        Thanks. I will integrate in the next release.
                        Also, for info, all the tooltips for inferences in MoveAlong are actually defined in LibFredo6, not in FredoTools. This is why they won't appear in Spanish.
                        • OxerO Offline
                          Oxer
                          Thanks for the info Fredo. I have made the new Spanish Language (Spain) file to LibFredo6, do you want that i upload it here or in LibFredo6 topic?
                          • fredo6F Offline
                            Oxer,
                            Better in the LibFredo6 thread.
                            • OxerO Offline
                              Oxer
                              Ok.
                              • fredo6F Offline
                                NEW RELEASE: FredoTools v1.9a - 15 May 14
                                FredoTools 1.9a is a release for
                                • DrawAlong 1.0,
                                • MoveAlong 1.1,
                                See main post of this thread for Download of FredoTools.
                                • cottyC Offline
                                  cotty
                                  Great update!!
                                  Thank you.
                                  my SketchUp gallery
                                  • OxerO Offline
                                    Oxer
                                    New Spanish Language File for FredoTools - v1.9a - 15 May 14
                                    P.S: If you have like preference Spanish Language (Spain) simply change the ES in filename to --> SP
                                    • fredo6F Offline
                                      Oxer,
                                      Thanks very much. This will go in the next update.
                                      • fredo6F Offline
                                        NEW RELEASE: FredoTools v1.9b - 17 May 14
                                        FredoTools 1.9b is a release for
                                        • DrawAlong 1.0b,
                                        • MoveAlong 1.1b,
                                        It includes:
                                        • a fix for VCB inputs in architectural units in DrawAlong and MoveAlong
                                        • an updated translation in Spanish-Spain (ES) by Oxer
                                        • fredo6F Offline
                                          NEW RELEASE: FredoTools v2.0a - 18 Jun 14
                                          FredoTools 2.0a is a release for
                                          MoveAlong v1.2,
                                          DrawAlong v1.1.
                                          • fredo6F Offline
                                            NEW RELEASE: FredoTools v2.0b - 07 Jul 14
                                            FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin)
                                            • 23
                                            • 24
                                            • 5 / 24
